  • June 26, 2025, 07:40:09 PM
Author Topic: HELP Identifying Engine  (Read 1804 times)
Online Dennis Adamisin
« on: March 22, 2019, 10:52:21 AM »
Going through Dad's stuff, came across an engine I cannot identify.  Beautiful casting, ABC, has an "11" stamped on the lug - perhaps 11cc?
(sheesz, outrunners are easier..!)
Re: HELP Identifying Engine
« Reply #1 on: March 22, 2019, 11:06:45 AM »
Denny that looks like a Skif. (Ukraine?).  It’s said to be a descent stunt engine and similar to the Discovery Retro .76.  That forward slanted plug would be scary with your Hot Shot battery.
Trib
« Reply #2 on: March 22, 2019, 11:48:28 AM »
If it is a Schnurlie (probably so) with a flat top piston, why not turn the cylinder head around? Put the glo plug in the back.
« Reply #3 on: March 22, 2019, 05:11:17 PM »
I think it's loop scavenged like a giant Fox .35.  The rear exhaust is for a muffler-not a pipe,  I believe, like the retros.  This is the European trend it seems where there isn't nitro around.  It should be able to turn very large props if that's your desire.  The ones I've seen mounted in airplanes were side mounted like a retro-ala the Shark.
Offline Jim Carter
« Reply #4 on: March 23, 2019, 01:08:05 PM »
Hey Dennis!  Man, you were a great help to me when I was building my Legacy conversion so I figure the least I can do is volunteer to help you with your engine.  Just send it to me and I'll do all I can to help  ;)  LL~ LL~
« Reply #5 on: March 24, 2019, 07:55:05 AM »
Yo Jim C!
Nice to hear from you, and thanks for offering to help me out with the slimer engine!  How about I mail it out to the numbers on your Visa card...   n~  VD~  (you're welcome!)
See ya in Carmichaels?
« Reply #6 on: March 24, 2019, 12:27:31 PM »
Don't forget the 3 digit code on the back. S?P
« Reply #7 on: March 24, 2019, 12:30:07 PM »
   Nobody's ever going to be collecting obsolete electric motors.
     The needle valve looks a lot like the ones I see on Rustler/Merco engines, so I would guess that this might be the work of Sergei Belko.
« Reply #8 on: March 24, 2019, 07:21:48 PM »
  LL~ LL~ LL~
Offline Lauri Malila
« Reply #9 on: March 25, 2019, 12:35:43 AM »
Dennis,
Can you please remove the head and show some details of scavenging? If it has PDP-porting, the strongest candidate as maker of this engine is Vladimir Kalennikov. He flew in Soviet team in 80's.
Lauri
Offline Jim Carter
« Reply #10 on: March 25, 2019, 09:32:29 AM »
Yo Jim C!
L.O.L.!!  Hello my friend!  I want to take you up on that but the last time I took the Visa card out of the wife purse, it was to pay the doctor for the 6 weeks of in-patient traction when the wife found out how much I spent getting the Legacy built and flying!  LL~ LL~  At least I still have it .... she said "Yes, Keep it ...... as a Reminder  %^@"!!    LL~ LL~
« Reply #11 on: March 28, 2019, 10:21:53 AM »
Dennis,
Lauri
Dennis,
I was wrong. Actually, Yuriy Yatsenko was wrong as V. Kalennikov was his guess and he is most often correct.
Correct answer is Vladimir Strakhov from Samara, Russia. Your engine is an earlier version of "Skif 9,5", from year 91-93.
Lauri
« Reply #12 on: March 28, 2019, 11:44:37 AM »
With the forward-slanted glo plug, it would be wise to install a remote glo connector.  I think I used one made by Sullivan.
Offline Pavlo Kravchenko
« Reply #13 on: March 30, 2019, 01:56:37 PM »
That's right. This is a Skif 9.5 cc motor. Russian pilot of the USSR and Russia national team member Vladimir Strakhov.
« Reply #14 on: March 30, 2019, 02:01:28 PM »
Another curiosity of Skif is quite high prop pitch. I think Albert uses pitch around 8". Seems to work.
And Skif silencer is the best I've seen. L
