  • July 17, 2025, 12:21:46 AM
Author Topic: Help identify these engines  (Read 1250 times)
Offline Robert Zambelli
« on: August 09, 2017, 08:13:23 PM »
I guy gave me a box of around 75 engines, glow, spark and Diesel.
To either donate to the Brodak museum or sell and donate the proceeds.
Going through them, I came across these two.
1.5 CC and 2.5 CC, both with a stylized letter "T" on the bypass.
Could they be Taipan?
If so, what can anyone tell me about them?
Re: Help identify these engines
« Reply #1 on: August 09, 2017, 09:58:28 PM »
definately Taipan , Id think . steel fins around 1970  . other looks ' Glo chief ' ish , Earlier . Maybe . Both valuable to Burford nutters , who should chime in .
« Reply #2 on: August 10, 2017, 07:10:07 AM »
Hi, Matt - thanks for the info.
The larger engine has the same "T" as the smaller one.
Although similar, it's definitely not a Glow Chief.
They look a bit rough and are missing needle valve assemblies but both have excellent compression.
I'll try and run them before I put them on auction.
Do you have any idea how they perform?
Offline Garf
    • Hangar Flying
« Reply #3 on: August 10, 2017, 08:46:32 AM »
This is the Taipan 1.5cc.
Offline Brian Hampton
« Reply #4 on: August 10, 2017, 08:04:57 PM »
The 1.5 is an early model Taipan series 67 Mk1 with the bright finished crankcase and one piece crankshaft. Later engines had a sand blasted finish and a removeable screw for the prop. The 2.5 is a Taipan Mk2 and is the least common version because it was the last of the 3 variants. The giveaway is an unbridged exhaust port. The Mk3 was released in '69 so yours will be from just before that.
« Reply #5 on: August 12, 2017, 10:07:53 AM »
Great info, Guys - thanks for your help.   #^  #^
After I run these engines, I'll post how they do.   y1
