Apologies if this is off topic but i'm intrigued by use of pipes with stunt applications? As I understand it, a tuned pipe will 'reinforce' power in a narrow band - usually max rpm for racing applications, are these pipes being 'tuned' for lower rpm's to coincide with usual stunt rpms? And doesn't this rely on a super steady engine run to avoid being 'off the pipe' and losing power? Just trying to understand the thinking behind it as a lot of this stuff is like the 'dark arts'
It's hardly the dark arts, nothing has been documented in more excruciating detail than tuned pipe operation and setup.
What you do is set the band of maximum enhancement to be at an RPM slower than you run in flight. If the engine slows down, the enhancement goes up, if the rpm goes up, the enhancement is reduced. The effect is to act as regulator of RPM rather than an power enhancement. It's entirely unnecessary to enhance the power of even a schneurle 40, much less a 75, in order to fly a stunt plane, so the power enhancement feature is not important aside from being able to use it as a regulator. In level flight, I think the pipe is probably have a net negative effect on the level flight power, that is, it would have more power at the in-flight RPM if you ran open exhaust.
If you like math, figure the open-exhaust torque and hp curves being modified by a sine wave which peaks at an RPM lower than you would run in level flight. Frank Williams has plots of the difference the pipe makes.
p. s. corrected typo, thanks Allan
