  • July 22, 2025, 02:23:49 PM
Author Topic: Head Shims : Source Please ?  (Read 1052 times)
Offline Robin_Holden
« on: September 18, 2009, 03:56:40 AM »
Greetings all from a drizzly Charente in S.W.France.
Can anyone help with a good source of cylinder head shims please ? Someone who doesn't mind sending overseas.
I'm hopeless at making my own !
Very much obliged for any contributions ,
Robin [ ex-pat Brit in the Charente full of ex-pat Brits ]
Offline Ralph Wenzel (d)
Re: Head Shims : Source Please ?
« Reply #1 on: September 18, 2009, 05:51:52 AM »
Jim Lee (See his ad in Vendor's Corner) offers a gasket cutter. I don't have this gadget, but everything else I've bought from him is topnotch, and he really stands behind his products, too!
Ralph Wenzel
AMA 495785 League City, TX
« Reply #2 on: September 18, 2009, 08:25:20 AM »
Ralph , very much obliged for the information,
Thanks ,
Robin.
Offline Phil Coopy
« Reply #3 on: September 18, 2009, 10:11:18 AM »
Actually Robin, if reducing the compression is what you are after,  adding head shims is not the best way to go in terms of 2 cy performance if the head has a squish band, because it moves it away from the piston reducing the squish effect.  Better method is to hog out the combustion chamber a little just above the piston.  Carl Shoup introduced me to this trick and with LA engines it works great. I have a jig built to do it on a lathe but you can do it easily with a Dremel and burr.
Pics below show a before and after of an LA40 head.
Phil
« Last Edit: September 18, 2009, 06:16:19 PM by PHIL COOPY »
Offline Phil Coopy
« Reply #4 on: September 18, 2009, 06:18:08 PM »
bump
« Reply #5 on: September 18, 2009, 06:56:51 PM »
Todd Ryan sells custom made head shims.  H^^ Steve
ryancompetition at aol dot com
