General control line discussion => Open Forum => Topic started by: howard shenton on March 23, 2020, 06:43:53 PM
Want to build a larger version of this model for a friend.
Need mag. for proportions.
Send email or attach picture to your reply.
Thank you for any help,
Are you looking for plans drawn for a model, or do you want reference material and 3-views to do your own plans. Lots of information available on the He 219 on eBay and Amazon. Some of the books listed have really good 3-views.
Walt Musicano did a large model of the airplane in the Nov/Dec 64 issue of American Modeler. Plans showed Fox .59's.
This model will be for a semi scale stunt plane of about 50 -60" wing span.
The flying Models Design was smaller and was smaller but designed as stunt model.
Yhanks for your
Howard
Done! Will send via E-mail.
The plans are on Outerzone along with the article.
Scott
found te "Q" site but could not find te FM 219 plan.
Emai is not working now.
how did you get to the plan
Howard
Howard:
Go here:
https://outerzone.co.uk/plan_details.asp?ID=1933
The May 74 Flying Models issue has the article of Joe DeMarco's He 219 Profile. Used a pair of .15's. From the article, "The model was designed primarily as a multi-engine Slow Combat plane." It has a 38 1/2" span. Really thin airfoil of less than 12%.
Scott
That is the Morel Aviation plan which I have, A scale model
That is the plan I am looking for.
Replied to your Private Message,
Thanks Again
Howard
Scott
Sorry, I should have explained better.
You take those plans and use my Special Secret Stunt Design Formula. Here's an example:
1) Cut out side view of HE-219
2) Chop it up to shorten it and/or stretch it, as needed, to glue onto a set of Thunder-Gazer plans, using T-G moment-arms and rib and tail-rib shapes
3) Use "White-Out"to cover over anything that doesn't look like a T-G 219
4) Build per plans
5) Win Walker Cup
Please don't share this secret with anyone as I plan to use the SSSDF as my path for future success. :D
All
If you sent mr any emails yesterday thay have been wiped out by the rehab facility or something else,
If you sent me the info from your personal message, it got lost.
Send aging if possible..
Howard
