  • July 17, 2025, 11:17:27 PM
Author Topic: Harry takes a dive...  (Read 2289 times)
Online wwwarbird
« on: February 16, 2011, 10:03:48 PM »
 This is kind of wierd. I've had this same 1/16" Harry Higley wire bender for quite some time, it's a very handy tool. I've used it countless times with excellent results and no problems, at least any that were the fault of the tool. ;D
 For some unknown reason, it went belly up tonight while bending the tailwheel wire for my Super Combat Streak. The little pins you see are supposed to be pointing straight up. It shouldn't have been the wire because I was using a leftover piece of wire that had been bent with this tool a couple of times previously. Ya got me. ???
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Harry takes a dive...
« Reply #1 on: February 17, 2011, 08:40:01 AM »
Nothing lasts forever.  At least not in one piece.
--Ray
AMA902472
« Reply #2 on: February 17, 2011, 08:48:23 AM »
I'd try and send it back.
  • Gravitywell
« Reply #3 on: February 17, 2011, 10:19:22 AM »
Looks heavy enough....just throw it back.  Would get there faster than the mail! n~
Seriousely though, could you drill the old rods out and just replace them with new 1/8th inch music wire?
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Dick Pacini
« Reply #4 on: February 17, 2011, 11:12:10 AM »
Those are probably dowel pins that are available at commercial hardware suppliers, like McMaster-Carr.  Home depot or Ace Hardware might carry them, too.  Pinch them up in a vise, one at a time, and pry the mounting block off.
On the other hand, contact Harry Higley.
AMA 62221
« Reply #5 on: February 17, 2011, 11:13:45 AM »
  On the other hand, you can get a new one for about $5!
http://www.hobbylinc.com/htm/hig/highwb332.htm
Offline W.D. Roland
« Reply #6 on: February 17, 2011, 01:05:43 PM »
Use it left handed?
Bet you just wasn't holding your mouth right. n~
David
David Roland
51336
Online wwwarbird
« Reply #7 on: February 17, 2011, 04:44:34 PM »
 Naw, I'll just get a new one.
 I got plenty of mileage out of it, I just thought it was weird how it went all of a sudden.
« Reply #8 on: February 18, 2011, 12:25:00 PM »
HI Wayne,
Very strange!  But when metal fatigues it usually fails very quickly.  Just was "it's time"! LL~
Get a new one, for sure....... I like the one that goes in the vise with one pin and a set screw, and has a "handle" to bend the wire.
Big Bear
Offline builditright
  • So happy to be alive!
« Reply #9 on: February 18, 2011, 01:22:29 PM »
should have used the plywood tail skid that was provided with the kit and it may have lived to see another day  S?P na#
Thank you and God Bless
Walter
aka/ builditright
Online wwwarbird
« Reply #10 on: February 18, 2011, 06:23:26 PM »
 OUCH! ;D
