Thanks Charles for your offer! I'll take you up on it.
I wrote out my reply earlier today then pressed the wrong button and poof. All gone. I'll try again.
I love red! I've been trying to get a color scheme that looked decent. Black and Red is the best I could come up with so far. A while back I was into Insignia Blue before that metallic green. What can I say.
The Twister served me well after Dan Banjok worked on trimming it for a few hours. It was built using stock Twister wood. Weighed in at 42 ounces in flying shape. Could have been lighter. The trailing edge and wing spars were webbed. I believe the flaps were 3/16" hard. Yes, half ribs, wing tips, I moved the stab back 2 inches. Halfway Fancherized. Twisters are usually built with moveable flaps. The Fancherized and straight versions both showing them in the plans. FP 40 power. This plane served me well for years. At the beginning of 2012, flying in the cold, the engine burped towards the end of a Pattern. I figured there was enough fuel, like always, to finish the shapes. At the cross of the overhead eight the engine quit. Controline no man's land. Splat. Friends told me afterwards "well sure in cold weather the air is denser and the mixture needs to be richer... you're not going to get the same run..."
The Magician uses a Walter Umland wing kit. I used Midwest plans as a reference. Wing measures nearly fifty inches with wingtips. I forget the wood thickness I used for the flaps. At least 3/16s. The flaps were widened about an inch at the inboard end, the taper towards the tip was opened up until it looked right. The stabilizer lengthened about 30% and moved back 2 inches or so. The fues is a rigid piece of very light 1/2inch. The nose doublers 1/8 inch five ply. Wing spars and trailing edge webbed. It weighs in, ready to fly, between 35 and 36 ounces. Depending upon the contest and the thumb on the scale. Surprised me how light it turned out. Power is a Tower 40. A very good flyer. Light on the controls. Handles the wind well. Dan Banjok told me to fly this plane instead of the Vector we were trying our best to trim out. The plane works very well. Very little trimming needed. The new hasn't warn off.
The bell cranks in these models are floated between two pieces of 3/8" square spruce. (I'm not near my shop this evening, need to measure and be sure.) 1/8" holes are drilled in the top and bottom, the post for the bell crank fits there. The spruce squares are tied into the main spars. The crank is located on the post with wheel colors and two pieces of medium fuel tubing, one top, one bottom. The Tom Morris method. Suspenders and a belt. It works.
The bell cranks are Tom Morris phenolic(?). Kind of look like peg board raw material soaked in epoxy resin. A spot of oil where they pivot and they stay lubed for the life. (Life of my models, anyway.) I use the big control horns and double them, for rigidity and in order to get the geometry right. The new Tanager wing (it was hanging up in my shop for 2 years at least, getting bumped into and chipped) probably won't use the top hole. Whatever works (looks right). The control horns are mounted on thin ply, top and bottom.
Allen Brickhaus was the guy who told me to double the control horns way back when. I wasn't exactly sure what he meant. So I did what you see. I've been bothering Allen for years, asking him why he never took a picture of my builds.
After razzing him again at this past NATs, he went over and snapped a pic. The next day, there it was in the daily news of events, a picture of the doubled flap horns and ball links. Rest of the Magician out of the picture. Allen!
