  • July 08, 2025, 11:35:34 AM
Author Topic: Handle finish.  (Read 3293 times)
Offline redout
Handle finish.
« on: November 08, 2022, 01:42:34 AM »
I'm about ready to test fly my Banshee so looked through my drawer of c/l stuff and found this handle which I must have bought a few years ago. I notice the handle is un-treated ( bare ) wood.
I am thinking with some use, that wood is going to absorb sweat ( especially in the upcoming summer here down under ).
What do you guys do about this ? Do you finish the handle with something to prolong it's life ?
Richard.
Offline fred cesquim
    • Fred Cesquim Aeromodelos
Re: Handle finish.
« Reply #1 on: November 08, 2022, 03:23:25 AM »
i have rounded the corners, doped, sanded, than brushed a  mix of yellow and 2 part clear coat
my logo decal is water slide and was added before the second clear coat(no yellow this time)
Offline Larry Renger
Re: Handle finish.
« Reply #2 on: November 08, 2022, 03:56:20 AM »
Wayer based Urethane works for me. I add some transtint dye. (Available from Rockler)
Offline Steve Dwyer
Re: Handle finish.
« Reply #3 on: November 08, 2022, 05:54:18 AM »
I brush painted mine with a red gloss alkyd paint I had on the shelf. The alkyd is impervious to 10% fuel and the red color is easily seen when placed alongside other's handles stacked up on the flite line. Year's back my hard point replaced my old trusted U-Reely, best move I ever made.
Re: Handle finish.
« Reply #4 on: November 08, 2022, 06:34:25 AM »
Minwax polycrylic.  5 coats.  Cleans up easily and handles the circle abuse well.  Easy to touch up.
Offline Lyle Spiegel
Re: Handle finish.
« Reply #5 on: November 08, 2022, 06:36:54 AM »
i go to Dick Sporting and buy a roll of the sticky gauze that is used to wrap the handle on tennis rack or baseball bat. I wrap the handle grip with a few layers. When ever it gets dirty / soaked from prespiration, just replace with a new wrapping. I like to use red , makes it easier to see the handle in the grass.
Lyle Spiegel AMA 19775
Online Jim Hoffman
Re: Handle finish.
« Reply #6 on: November 08, 2022, 08:20:08 AM »
I use a wrap on the handle to give a good no slip grip surface.  Especially helpful with an oily hand.
I use 3M Coban Self Adherent Wrap.
Offline Maksim Dubovitsky
Re: Handle finish.
« Reply #7 on: November 08, 2022, 09:24:44 AM »
I use Marine (yacht) Polyurethane Clear Coat. Even a sweaty hand does not slip.
Re: Handle finish.
« Reply #8 on: November 08, 2022, 09:44:06 AM »
I keep going back to my unfinished handles as it seems they don't slip in my grip like th finished ones do.  I still use my trusty Hot Rock handle for first flights on new plane.  Then I go to hard point for final trim. D>K
Offline kevin king
Re: Handle finish.
« Reply #9 on: November 08, 2022, 10:22:21 AM »
Sig Dope & 2k Automotive polyurethane.
Offline bill bischoff
Re: Handle finish.
« Reply #10 on: November 08, 2022, 10:22:44 AM »
I use finish-cure epoxy, sanded smooth and burnished to a satin finish with 000 steel wool.
Re: Handle finish.
« Reply #11 on: November 08, 2022, 10:53:13 AM »
I have a variety, if it was going to do it today I would use wipe-pn polyurethane, it's not critical. Then, wrap it with this or some equivalent:
https://www.tennis-warehouse.com/Tourna_Gauze_Grip_Tape/descpageUNIQUE-UGT.html
Offline redout
Re: Handle finish.
« Reply #12 on: November 09, 2022, 03:06:43 AM »
Thanks everyone. There's some good information in all that - certainly things I had not thought of. I like the idea of finishing the bare wood to protect it then applying some sort of grip tape.
Offline Ara Dedekian
  • Ara Dedekian
Re: Handle finish.
« Reply #13 on: November 09, 2022, 06:05:25 AM »
      Me too. The handle on the right has a marine urethane coating providing a no slip grip.
      The handle on the left turned into a disaster using Min-Wax Polycrillic waterbased Urethane. I was looking for a clear finish to let the colors come through. Despite the recommendations by Forum members, it turns into a sticky goo from sweat(?), fuel(?). I had to use alcohol to get it off the handle which then marred the latex paint. Same result on the few times I coated areas on my planes with it.
      Ara
« Last Edit: November 09, 2022, 06:38:07 AM by Ara Dedekian »
Offline Frank Imbriaco
Re: Handle finish.
« Reply #14 on: November 09, 2022, 06:35:08 AM »
I painted my Kaz handles with an area of green on the top and red on the bottom. Some say it's hard to pick up a handle backwards with the safety tong attached to the bottom, but ...
Re: Handle finish.
« Reply #15 on: November 09, 2022, 03:45:39 PM »
Two coats (brushed) of Z-poxy finishing resin on the balsa, sanded after the 1st coat, and wrapped with fishing rod grip tape. I'm not looking for a work of art...like some. 1.5mm CF plate core with the holes bushed works fine. Mine is rather heavy at 25 grams. Some guys make 15 gram handles, but I doubt if I could discern the difference.  HIHI%% Steve
Offline rich gorrill
Re: Handle finish.
« Reply #16 on: November 10, 2022, 03:17:24 PM »
I also wrap handles with the sticky tape, easy to change whendirty and never gets slippery from fuel residue on your hands.
Online Brent Williams
Re: Handle finish.
« Reply #17 on: November 10, 2022, 03:58:33 PM »
Pat Johnston coats his handles with epoxy and sprinkles rough garnet sand on the grip area.
No tape.  Feels very grippy.
Offline kevin king
Re: Handle finish.
« Reply #18 on: November 12, 2022, 03:25:33 PM »
Here you go.
Re: Handle finish.
« Reply #19 on: November 12, 2022, 04:35:01 PM »
Here you go.
  I have a couple of those. Nice for sport flying, or easy does it fun type racing events. I wish they didn't have the slant to them but I can deal with it.
Re: Handle finish.
« Reply #20 on: November 12, 2022, 05:23:24 PM »
Kevin King!  You, for sure, are awarded the Concours D'Elegance for handle beauty!  The plaque enshrining it should be in the mail soon!
Ted Fancher
Offline kevin king
Re: Handle finish.
« Reply #21 on: November 12, 2022, 11:47:43 PM »
Haha Ted, thank you, and you got my vote on the nicest cowl ever built!
Offline Istvan Travnik
Re: Handle finish.
« Reply #22 on: November 14, 2022, 04:45:43 PM »
My 40 years old handle made of PVC (vinyl) plastic.
In recent years I cover it with fine soft leather, (which used to cover tennis rackets), but with inside surface out.
In 3-4 years it got oily, dirty, ugly: I change it. (Glued by CA)
Offline Fred Cronenwett
    • Lafayette Esquadrille
Re: Handle finish.
« Reply #23 on: November 15, 2022, 07:42:53 PM »
I put gloss clear polyurethane on my handles
Fred Cronenwett
AMA CLSCALE7 - CL Scale
