  • June 21, 2025, 01:15:50 AM
Author Topic: ???how???  (Read 1301 times)
Offline Bootlegger
???how???
« on: April 17, 2010, 03:40:00 PM »
Did u get the push rod into the B/Crank of the wing on the PT 19 arf ?  I have tried different way's without any success..  HELP...!!!               HB~> HB~> HB~>
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Andrew Borgogna
  • Andy
Re: ???how???
« Reply #1 on: April 17, 2010, 08:00:25 PM »
The reason it won't go in is because the part is built wrong!  This has been talked about before, you have to make a new part with the bottom  bend going in the opposite direction for it to work.  Why this part is still being shipped wrong I will never know, but it is.  If you want any additional help contact me by personal email, I will give you my phone number and I can talk you through the issue.
Andy Borgogna
Andrew B. Borgogna
Offline Larrys4227
Re: ???how???
« Reply #2 on: April 18, 2010, 04:24:59 AM »
I've built 2 of these PT-19's for other modelers ... theres an addendum inside the box, or taped to the outside explaining the problem and a few choices on what to do about it. Its easy enough to make a new one ... just use the correct sized rod.
Larry
Offline Bootlegger
Re: ???how???
« Reply #3 on: April 18, 2010, 06:18:05 AM »
 #^          Thanks fellow's, Larry what size is the wire for thr push rod?  Look's like 3/32".. :!
Gil Causey
AMA# 6964
Re: ???how???
« Reply #4 on: April 18, 2010, 07:19:07 AM »
3/32 is what I use on most of the bigger planes.   H^^
Offline Bootlegger
Re: ???how???
« Reply #5 on: April 18, 2010, 10:08:59 AM »
  Andy, correct me if I misunderstood, the lower bend has to be changed 180 deg to be correct?  And thanks for the help... H^^
Gil Causey
AMA# 6964
