  • July 04, 2025, 04:57:12 PM
Author Topic: Some fun with the computer  (Read 1468 times)
Offline Bob Zambelli
« on: April 10, 2008, 02:22:12 PM »
I got to playing with the Solid Edge program.
Here's a model of the Brodak .25 crankcase.
It took around two hours to accomplish.
The program will also provide all physical parameters - CG, radius of gyration, three axis moment of inertia and weight. I need only enter the specific gravity of the material.
Really fun!!!!
Offline linheart smith
Re: Some fun with the computer
« Reply #1 on: April 10, 2008, 04:40:19 PM »
Bob,
Did you have to draw the Three Views?
linheart
« Reply #2 on: April 10, 2008, 09:44:29 PM »
Biob,
great rendering. I drew my FP 40 in 3d as well but in Autocad. I dont have solid edge but hear its actually much better for rendering 3d,, well duh thats what it was designed for. are you going to render the innards too? In fact, the initial layout for my 109 stunter was done in 3d so I could get a feel for the proportions and forcast the overall effect. I enjoy working in 3d but in autocad its a bit cumbersome. I hope to get solid works, or Inventor so I can explore 3d modeling a bit more in depth.
keep playin its fun to see what you can do!
« Reply #3 on: April 10, 2008, 10:44:37 PM »
I used a linux version of Inventor. Pretty cool.
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #4 on: April 11, 2008, 07:56:44 AM »
With these sophisticated modeling programs, you might be able to calculate the 2/4 break!
Great stuff, I wish we could get it for about $99.95..
L.
"Invention, by necessity, is a mother.." -Frank Zappa (?)
« Reply #5 on: April 11, 2008, 08:45:51 AM »
Hi, Gents. Good questions.
Solid Edge is parametrically driven. When you open a new drawing, it defaults to three intersecting planes. To create the first feature, you pick a plane and extrude from it. For a cylinder, you draw a circle, assign a diameter and length. That can serve as the engine cylinder centerline.
Then, extrude another cylinder from a perpendicular plane and you have a crankshaft C/L.
Continuing, you just keep adding features - bore, exhaust port, bolt holes, fins, intake and so on. If something needs to be at an angle, you just create an angled plane and extrude the feature from that.
The program runs under windows and is the most user friendly modelling program I've ever used.
Mark - all the innards are indeed rendered.
Offline don Burke
« Reply #6 on: April 11, 2008, 09:07:08 PM »
Do you have a good source for the software the only reasonable price I found required a student or teacher ID.
don Burke AMA 843
Menifee, CA
Offline Steven Kientz
« Reply #7 on: April 12, 2008, 11:56:10 AM »
Has anyone used Turbocad, is it easy to use? I'm looking for some software to draw rib shapes( can't draw anymore-inherited tremor). I tried using Paint on our computer ,but not very useful.
Steve Kientz
AMA 855912
Offline Robert McHam
« Reply #8 on: April 12, 2008, 03:07:04 PM »
Sounds like a hopped up version of Google Sketchup. More likely the other way around.
The Google Sketchup is absolutly free for those who want to play with it.
Robert
« Reply #9 on: April 12, 2008, 05:26:23 PM »
Bout time we got some serious cad happening again. You see this stuff all the time on the RC Universe sight,(They are phenomenally good). I used SolidWorks for a time, but got away from it because it is not as readily adaptible to laser cutting as DWG. Solid Edge is generally considered to be the easiest parametric modeler to use because it is designed specifically to transition you from Autocad 2D. That has been there main Marketing strategy. If I were going to attempt a stunt engine today, I would use Solidedge\Solidworks for the modeler and use rapid prototyping to get my initial parts. I would then get my g code parts off that.
