  • July 14, 2025, 06:30:51 PM
Author Topic: gyroscopic precession  (Read 8778 times)
Offline Alex Becerril
« on: July 02, 2012, 02:42:53 PM »
Hi All
which of these two factors affect the Gyroscopic Precession (yaw to the inside of the circle) more?:
a- Prop number of blades
b- diameter
c- prop weight
Re: gyroscopic precession
« Reply #1 on: July 02, 2012, 02:50:08 PM »
Hi All
b- diameter
c- prop weight
All the above affect GP
If your having problems with GP the lighter the prop the better for less GP (although it may not perform as well) If you can thin out the outer parts of your blades..without... them getting too flexible that will help.
Also the smaller diameter of the same will give you less  GP
3 blade seem to be better with GP since the force manifest itself 90 degrees ahead of the blades
« Last Edit: July 02, 2012, 03:22:45 PM by RandySmith »
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #2 on: July 02, 2012, 03:15:08 PM »
All above and the distribution of the prop's weight along its diameter..
(3-blade vs 2-blade may have something to do with moment of inertia as well.)
L.
"What is now proved was once only imagined." -William Blake
Offline Douglas Ames
« Reply #3 on: July 02, 2012, 03:38:33 PM »
<snip>
?? - Are you sure it might be because your 3-blades are light-weight carbon vs. a heavier (larger dia.) 2-blade?
AMA 656546
« Reply #4 on: July 02, 2012, 03:43:38 PM »
No the 3 blades are better on GP than the same CF 2 blades that weigh less
But one advantage of the 3 blades is that you can, and do, normally run a little less diameter
« Reply #5 on: July 02, 2012, 03:46:22 PM »
As explained, all of the factors listed affect gyroscopic precession.  Gyroscopic presession is a funtion of moment of inertia.  Moment of inertia is a function of a mass and the square of the distance from a center of gravity of the rotating mass.  Props with lighter tips would be better to reduce groscopic precession than props with heavier tips of the same diameter.  Lighter props with smaller diameters are better than larger heavier props to reduce gyroscopic precession.  A multi-blade prop with a smaller diameter will be better to reduce groscopic redcution than a hevier 2-balde prop of a greater diameter if its moment of inertia is less than the two-blade prop. This response is in regard to the question of what most affects gyroscopic precession, not necessarily what is the best prop to use for a given model/engine combination.
Also, gyroscopic presession causes a model to yaw to the right on inside turns and the model will yaw to the left on outside turns with a counter-rotating engine/prop (viewed from the front).
Online Dick Pacini
« Reply #6 on: July 02, 2012, 03:53:49 PM »
Hi All
b- diameter
c- prop weight
Um, I count 3 choices.  Is this a trick test? LL~
AMA 62221
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #7 on: July 02, 2012, 04:30:33 PM »
Run reverse rotation then it won't be as much of an issue. I'm converting all my larger Saitos and most of the electrics are running reverse.
Online Howard Rush
« Reply #8 on: July 02, 2012, 05:25:03 PM »
Has anybody ever calculated the amount of rudder it takes to counteract the yawing moment from the spinning prop in an hourglass corner? For the amount of elevator it takes to counteract the pitching moment from flying level in a circle?  I ask the latter because today I'm rigging my elevator for a backwards-running motor.  I see the same qualitative stuff over and over, but nobody seems to own a pencil.
Folks look at a prop like it's a uniform disk.  It's not.  What does the yawing moment from a two-blade prop do during a turn relative to a three-blade prop, and how does this affect my score?
« Reply #9 on: July 02, 2012, 05:39:51 PM »
Three blades eliminate the vibration from one blade flying at a higher angle of attack in a turn.  Any number of blades over 2 does this according to NACA reports.
The left handed prop probably does better for you.  It puts the precession to work for you in the third turn of the hourglass and the upper left corner of outside square corners.
« Last Edit: July 02, 2012, 05:57:52 PM by phil c »
« Reply #10 on: July 02, 2012, 06:42:42 PM »
Well, get cracking!
http://en.wikipedia.org/wiki/Gyroscope
AFAIK (and I may just be bloviating here; I ain't gonna do the math), the major difference between a spinning stick and a spinning disk with the same radial distribution of mass is that the spinning stick will tend to deliver it's torque in thumps (well, more likely as a raised cosine w.r.t prop position).  The whole behavior of a gyroscope is really the ensemble average of the behavior of a collection of point masses; in the case of a stick vs. disk the difference is that the instantaneous behavior is different than the time-average, so a two-blader would induce more vibration.
« Reply #11 on: July 02, 2012, 07:31:56 PM »
And a 4-blader, a 5-blader or a contra-rotating 3 or 4-blader???
The later must have huge amounts of precession, just look at the empennage design of a Westland Wyvern. Dihedral in the stab, finlets and a huge vert. fin/rudder.
AMA 656546
« Reply #12 on: July 02, 2012, 07:57:46 PM »
Question for you Howard must be :
Will 3B be optimal for Electric Counter rotation ?
Id be very interested to see electric setups with a 12 " 3B Undercamber thin carbon prop - might yeld excellent speed control.
I noticed little to NO GP Prec in Bob Hunts electric model in flight, and from what I can recall there was very little in the way of rudder offset.
« Reply #13 on: July 02, 2012, 08:16:34 PM »
Hi Doug,
The Wyvern has a big rudder and fin because of the propellers mass, and the fact that it and most propeller driven airplanes of that era are too short in tail moment to be very stable. It's the same reason the Red Baron RB-51 racer had to have it's fin enlarged even though it ran a CR propeller.
The CR propeller blade work to cancel gyroscopic precession.
Chris...
« Reply #14 on: July 02, 2012, 08:34:53 PM »
A 4 blade Contra rotating prop has almost zero GP
« Reply #15 on: July 02, 2012, 09:08:57 PM »
  Assuming the props are properly designed and the mass properties are right, the precession is ZERO for a contra-rotating props.
Offline Doug Moon
« Reply #16 on: July 02, 2012, 09:09:23 PM »
And the Badass factor would be off the scale!
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Eric Viglione
« Reply #17 on: July 02, 2012, 09:52:40 PM »
Yeah, and so would the noise I think!  :o
« Reply #18 on: July 02, 2012, 09:59:41 PM »
  Better have fast fingers to flip it through compression, however.
« Reply #19 on: July 02, 2012, 10:02:48 PM »
Spinner  flip  works !
Online Matt Colan
« Reply #20 on: July 02, 2012, 10:11:13 PM »
In one of Windy's videos, there's a flight of Randy flying a Magnum with Contra-rotating props back in the early 90s.  The sound and coolness factor was up there,even on video!!
« Reply #21 on: July 02, 2012, 10:15:37 PM »
If its electric just press the Go Baby Go button.
Online Howard Rush
« Reply #22 on: July 02, 2012, 10:19:09 PM »
Yup.  The general equation for moment from a spinning prop in a corner has a bunch of jive in it.  I was hoping you would tackle it.  Maybe Tom will.  I'd like to be able to plot yaw moment vs. time for different props, RPM, and such.  Brett probably does this stuff every day at work.
« Reply #23 on: July 02, 2012, 10:56:17 PM »
I flew the Magnum at the NATs and other contest with the contra rotating props.
The Magnum was flown in many many configurations, It has a skinny fuse and when I ran big motors (64) and 13 inch props it had very bad GP, you could watch the wheel pants moving fore and aft.. When  I set it up with a contra prop, that all went away completely, It was so clean in the corners and rounds that it really was transformed into a far superior Plane from before.
I still have it, and it maybe used again as a test bed for another system.
« Reply #24 on: July 02, 2012, 11:39:57 PM »
     Oh, no, I am arguing over whether you should define the requirements for a part before buying it, or after. Surprisingly, I am not  winning that one right now.
« Reply #25 on: July 03, 2012, 12:09:54 AM »
I'll bet that you're on the side of boring predictability.
You know, trying to negotiate the requirements for a part after it's bought and paid for creates a lot more jobs.  For lawyers.  So it's not all bad.  It keeps them from splashing mud over the tail lights of their Escalades and M3s and going around braking hard at intersections.
Online Howard Rush
« Reply #26 on: July 03, 2012, 02:22:11 AM »
I was assigned to write the requirements for the last-generation 737 flight controls.  I set a personal goal of getting the requirements written before the first flight, and I almost made it.
« Reply #27 on: July 03, 2012, 08:47:15 AM »
All I know is the more blades, the more cuts you  get before ralizing you are being cut. LL~ LL~ LL~
« Reply #28 on: July 03, 2012, 09:24:34 AM »
And just how do you know that, Doc? HB~> HB~> ~^ ~^
« Reply #29 on: July 03, 2012, 02:15:42 PM »
I think he learned...."first hand".   S?P
« Reply #30 on: July 03, 2012, 02:39:36 PM »
I always start my engines standing up.  I flip the plane over if it has an inverted engine.  I always tell my "helper" what we will do beforehand.  Once started, I get behind the engine and turn the plane over (if needed) while the helper gets a new hold on the model.  THEN I remove the battery.  The helper holds the plane standing up until I give the release signal when they then put the model on the ground and release in one motion.  Since this is usually Aaron, we have it really well worked out and the only "bite" has been when an engine kicked back and the Bolly prop cut my uncovered finger.  No stitches, though.  I will not reach over, or around, a prop under any circumstances.
One thing I noticed about the only electric system we have is that you do not ever get near the prop and the model never needs to be turned over! LOL!!
BIG Bear
RNMM/AMM
« Reply #31 on: July 03, 2012, 02:58:14 PM »
These contra-rotating motors would be killer for a Pro Stunt Ship, but they're above my skill level and paygrade.  :(
The total motor pkg. might be a little heavy though?
http://www.maxxprod.com/mpi/mpi-266.html
AMA 656546
« Reply #32 on: July 03, 2012, 03:11:18 PM »
Yet I have heard stories (and seen icky pictures, and the scars on my RC club president's arm) that attest to the fact that electrics will bite, too.
You gotta treat those spinning steak-knife thingies with respect, no matter what's doing (or about to do) the spinning.
« Reply #33 on: July 03, 2012, 06:00:39 PM »
I understand that part, Tim.  I have a whole lot of respect for things that can cut off body parts!
BIG Bear
RNMM/AMM
« Reply #34 on: July 03, 2012, 08:41:37 PM »
Will, you want to see the scars????    Dennis is partly right. H^^
Offline Doug Moon
« Reply #35 on: July 03, 2012, 08:52:25 PM »
I get it that GP yaws the model in and out during the turn and the mass of the prop is one of the larger reasons for this.
What is it that causes larger diameter props to open up the corners?
And why is it that I can run a 12.5 3 blade and have pretty stout stick force but a larger 13.25 2 blade will have less stick force in the corners even though the diameter is larger?  I can guess at it but I would rather just know.
Doug Moon
AMA 496454
Offline bob branch
« Reply #36 on: July 04, 2012, 06:28:14 AM »
Just a note on the noise factor, they are not noisy. Counter rotating props have been used with considerable success in world championship RC Pattern competition with electric power and they have very strict noise level limits.
bob branch
« Reply #37 on: July 04, 2012, 06:33:52 AM »
Doc, I'd rather not - I don't even like to look at my own!  (Ask Jeff Traxler about his red trimmed finish on his old profile.) ~^ ~^
Offline kbf1kbf1
« Reply #38 on: July 04, 2012, 02:48:16 PM »
Anyone know if this video or other videos of C/L models with contra-rotating props is on YouTube?
Kevin Ferrell
Online Matt Colan
« Reply #39 on: July 04, 2012, 04:27:18 PM »
I could put it on Youtube, but the video is at my Grandparents, so it will be a couple days before I could do it.
Offline dale gleason
« Reply #40 on: July 04, 2012, 04:55:01 PM »
I'm having trouble seeing the apparent advantages to be had with a reverse rotation prop in stunt applications. A number of people who don't fly have pointed out how it is extremely positive in overhead tricks.
The GP is in an unfavorable direction when cornering on outside tricks....is this correct? If it is, since there are more inside tricks than outside tricks in the pattern, standard rotation would seem more better, to me.
Speaking redundantly, it looks like reverse rotation lends itself to improved outside cornering, but there are more inside corners in the pattern......
I hope someone can shed some light on this anomaly before I get my new electric ship designed which will be flown clockwise.
dg
Offline Bob Reeves
« Reply #41 on: July 04, 2012, 07:23:38 PM »
Hi Dale,
As one that recently made the transition with my 4 stroke I may be able to help. What you are saying is correct however the two most demanding corners in the pattern are the two at the top of the hourglass, both of which are outsides. I really didn't notice any difference on insides but sure noticed the difference at the top of the hour glass and the vert eight.
« Reply #42 on: July 04, 2012, 08:32:00 PM »
Hi Dale,
  The effects of yawing are asymmetrical. If it noses out, the line tension is (at least temporarily) increased, increasing the yaw restoring torque, limiting the motion. If it noses in, the line tension goes down, reducing the restoring force, and allowing more motion. So you can tolerate A LOT of nose-out than nose-in.
« Reply #43 on: July 05, 2012, 07:30:41 AM »
I toiled late into the night last night trying to get this figured out (assymetric recovering forces)....I didn't have much luck. I'm wondering about  trying a ROJett 67 with a reverse crank (was a Carrier possibility a few years back), but the lack of "cutting edge" props is problematic.
dg
« Reply #44 on: July 05, 2012, 01:22:35 PM »
   If the line tension was constant, the restoring torque from the leadouts is
     line tension*distance from CG to leadout guide*sin(yaw angle)
   and just define a value K as the line tension*distance so you have a "coefficient of restoring force" , so for small angles this becomes:
      K*yaw angle.
  In unperturbed level flight for my airplane, say, the value of K  is about 10 lbs*28" or about 280 in-lb/radian. But the line tension is a function of the yaw angle, too, and it goes down as the yaw angle goes negative (nose-in) and up as the yaw angle goes positive (nose-out). So, the K is not really a constant, but changes as the yaw angle changes- so the value of K goes down for nose-in yaw and up for nose-out yaw. For example say 9 lbs at some nose-in yaw angle, and 11 lb at some nose-out yaw angle. For the nose-in case K goes down to 252 in-lb/rad and the nose-out case it's 308. Asymmetrical.
    Of course, if you knew how much the line tension changes as you change the yaw angle, you could put that function in where the line tension goes, have some function of the yaw angle and then simplify and get rid of the need for the "constant" K that isn't really a constant. In reality that isn't a known function - not because it's magical but because we just haven't worked it out. There are other restoring torques that aren't asymmetrical, like the fin/rudder and dihedral effects, and others that are not simple functions of the yaw angle (like, some of them have to to with the yaw rate and yaw angle past history)  so to build up the entire equations of motion is a very difficult task.
« Last Edit: July 05, 2012, 07:32:14 PM by Brett Buck »
Online Howard Rush
« Reply #45 on: July 05, 2012, 02:38:43 PM »
I'm fixing to measure line tension in flight, but I have a contest coming up, so it will be awhile.  I guess the range of pitch rates we fly is too big to assume linearity of delta line tension vs. pitch rate.  Hence Keith Trostle's extremely clever cam-programmed rudder on his Bearcat.
« Reply #46 on: July 05, 2012, 03:14:22 PM »
Is there a need for such a thing as a reverse Rabe rudder for a reverse running prop.?
...or would it just be a trimming nightmare?
AMA 656546
« Reply #47 on: July 05, 2012, 07:34:53 PM »
   The best feature of Keith's mechanism is that the degree of adjustment is more or less infinite, meaning the movement can be made relatively small. That's not possible with the original, and most people wind up with WAY too much travel.
« Reply #48 on: July 05, 2012, 11:32:04 PM »
Howard : Why do you want to measure line tension ? To be of what benifit ?
I have a pretty good idea of force.. this is based on a more simplistic measurement device known as a scale.
I wanted to know how much line tension I was feeling in the process of flying the bomber. DIRECTLY after one flight I had someone inside the circle with such a scale, whereby I said " pull till I tell you when its the same "..
I was staggered at how much it was..
To be honest I havent done a comparision of a modern ship, but I could give a fairly accurate level for what I feel.
  • Red Hot Lover
    • Stephanie Miller
« Reply #49 on: July 07, 2012, 10:51:29 AM »
The "counter-rotating" prop I saw in a video had the second prop just free wheeling.. It certainly looked cool, and seemed practical, but I don't remember it being overly noisy.
However, how about the efficiency of such props, free wheeling or driven? I know we tend to not be terribly concerned with propellor efficiency in CL Stunt (exception for electrics, right). But it seems like a lot of energy would be lost just correcting the airstream.
Of course, with a driven version, you have the gears associated with the reverse drive, which means mechanical loss of efficiency not even considering the aerodynamics of the system.
Interesting thread.
L.
"Sometimes you get shown the light in the strangest of places if you look at it right." -Jerry Garcia
