  • May 31, 2024, 09:06:21 PM
Author Topic: GSCB Vintage Combat festival 9-22-19  (Read 8818 times)
Offline Tom Luciano
« on: August 21, 2019, 05:42:56 AM »
Get the old girls ready! It's time for the most exhilarating day of the year!
This year I will donate 6-8 la 25 powered Voodoos for anyone who wants to try combat. Two planes will be sitting on the 3rd circle fueled waiting for you to take a crack at it. These are completely disposable, so get out and try combat for the first time or knock 50 years of rust off.
Bring out those Vintage Combat planes and show, sport fly, compete in our speed runs, or our newly introduced speed stunt with combat planes. It's a day of fun and comradery enjoying the designs of the past. The LS stories alone are priceless!
Super Satan with stunt pattern at 118mph.
Double Diamond on a 122mph speed run.
AMA 13001
Offline Mike Ferguson
Re: GSCB Vintage Combat festival 9-22-19
« Reply #1 on: August 21, 2019, 06:30:48 PM »
Cool. I will do my best to have my Nemesis done for then. Howard's welcome to fly it if he happens to stop by.
Offline Tom Luciano
« Reply #2 on: August 21, 2019, 06:58:23 PM »
Mike,
 Thats great! I met Howard at the nats and busted him I would build him a plane if he wanted to come. He said he would bring his own G21 to mount on it. You got me off the hook! Lol
Tom
« Last Edit: August 21, 2019, 07:32:28 PM by Tom Luciano »
AMA 13001
Offline Tom Luciano
« Reply #3 on: September 02, 2019, 04:36:09 AM »
Here is a reprint of the Speed Stunt rules;
The following is our guidelines/rules. We want to keep it light and encourage participation.  Fly at whatever speed your comfortable with;
The objective is to perform the stunt pattern maneuvers in minimum time, from first entry to completion of the 4 leaf clover. In order to permit nostalgia combat airplanes to fly without oversize fuel tanks, only one full lap between maneuvers is required. The maneuvers are not scored per se; rather the pattern is reviewed by the timer to see that all maneuvers are completed in order.
Model Eligibility Any model designed, sketched, published, constructed or offered for sale in kit form prior to 1980 which could have been used in combat is eligible, the older the better. The use of original survivor aircraft is specifically encouraged. There is no prohibition of foam wings or plastic covering, but the competitors are at liberty to abuse the fakers who ignore the tradition of silk and dope .
-Fight Takeoffs and landings are not judged, hand launch is expressly permitted.
-Hand signal required on prior lap of the reverse wingover.
-Timing starts at entry into the reverse wing over and stops at the last crossing of the intersection of the 4 leaf clover.
- Four inverted laps are required.
- One and a half laps are required after the exit of the hourglass prior to entry into the overhead eight.
- Any or all of the following are permitted: level flight height as high as practical, short lines, or smaller maneuvers; all to minimize flight distance and time.
-An entry not completing all maneuvers shall receive no score, but will be accorded as many attempts as time permits.
Speed Runs
-Any engine that is non-schnuerle ported basically the 36x and g21-35 engines are the cutoff and any vintage combat design prior to 1980.
- No nitro content limitations
-  60' lines center to center meeting current line diameter requirements
- 10' high maximum level flight
Award given out for Speed stunt, speed runs, and the famed LS blown up Fox Award!
Most important rule is to have a "BLAST!"
Hope to see ya there!
Tom
AMA 13001
Offline Bob Hunt
« Reply #4 on: September 02, 2019, 08:32:07 AM »
Hi Tom:
Very much looking forward to the Vintage Combat Festival!  #^
I've pulled out of mothballs the Lester Grogan-designed Sweet Sweep that I started a few years ago and have it into finish now. It will be electric powered. Attached are a few photos of what it looked like last night. I pulled everything apart this morning and started doping! It will be finished for the event for sure. My plan is to enter it in the Speed Stunt event and also in the top speed event.
Later - Bob Hunt
Offline Bob Hunt
« Reply #5 on: September 02, 2019, 08:33:30 AM »
Here are a couple more photos showing the motor compartment in close up.
Later Bob
Offline Frank Imbriaco
« Reply #6 on: September 02, 2019, 04:35:16 PM »
Bob :
That's just plain frightening to look at.
Offline Bob Hunt
« Reply #7 on: September 02, 2019, 07:02:36 PM »
 VD~ %^@
Bob...
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #8 on: September 02, 2019, 07:28:03 PM »
Hello
Would like to have a go organizing a similar contest here based on Tom's rules.
From my own experiences trying speed stunt is is a lot of fun and speeds up your reactions somewhat!
Mufflers rules here in NZ as applied to the old 35/36 engines can be tricky as not all like the extra heat
Bob's model look fast and mean. Nice but where does the 50% nitro go?
Regards Gerald
Offline C.T. Schaefer
« Reply #9 on: September 03, 2019, 05:34:29 AM »
Sweet Sweep =  Sweet Jesus!!   Looks like an awesome rig.   Head to head with the old BB  should be tons o fun!  TS
Offline Bob Hunt
« Reply #10 on: September 03, 2019, 06:31:06 AM »
Gerald wrote: "Nice but where does the 50% nitro go?"
At today's prices, it would go in a safe deposit box...   LL~
Tom: Yeah, it should be a lot of fun. I'm going to test fly it with a somewhat docile electric setup just to be sure there are no trim problems. I'd hate to have to chase this thing around at 100 plus mph on the first flight. A 1100Kv Power 10 with a 1600 4S battery will do the job. Probably an 8 x 8 prop. If things go well with the test rig, then Will DeMauro will install the juice in the form of a 1400-plus Kv motor and a 5S 1300 battery. That should put it in the realm of the BB for speed. Actually the "numbers" suggest 130 plus, but that remains to be seen. Not sure if this 72-year-old body can spin that fast anyway. :P So, no firm predictions.
This stuff is just raw fun! - Bob
Offline Joseph Daly
« Reply #11 on: September 03, 2019, 06:36:17 AM »
Will Demauro and I have sercet weapons coming!!!!!!!!!!!!!!!
Come out and see on the 22nd!
Offline William DeMauro
« Reply #12 on: September 03, 2019, 10:09:14 AM »
Have you guys considered the strength of the prop on a high power electric set up.
Motorman 8)
Yes!!!
AMA 98010
Offline Tom Luciano
« Reply #13 on: September 03, 2019, 11:34:09 AM »
Punch in your GPS for the garden state circle burner field address is 140 Two bridges road Lincoln Park New Jersey
AMA 13001
Online Charles Carter
  • Flying Control Line Stunt
« Reply #14 on: September 09, 2019, 05:33:18 PM »
Nice looking plane.  It looks fast just on the bench.
Charles
Offline Tom Luciano
« Reply #15 on: September 09, 2019, 06:44:15 PM »
Hey Charles,
 Yea, Hunt got his eyes on taking down the old Super Satan!
We Middlesex guys got out yesterday to shake some rust off.  After one flight each we need a lot more shak'n. The jr. Satan, Double Diamond, and Super Satan were screaming!
Best,
Tom
AMA 13001
Offline Bob Hunt
« Reply #16 on: September 10, 2019, 05:29:30 AM »
As Shug Emery would say, "Wooooo Buddy." There are a few of us infidels who are going electric at the Festival this year. We are in no way predicting a take down of the Super Satan, or any of the glow powered models in terms of speed. At least not yet... We may have a shot at the Speed Stunt event. We certainly have a shot at the new event we are proposing: Quietest Model.  VD~
All of this is designed to have that which seems to be most elusive; FUN!
Later - Bob Hunt
Offline Tom Luciano
« Reply #17 on: September 10, 2019, 06:23:47 AM »
There is 1 thing i can guarantee. when you fly the pattern at 100+ mph, it is impossible to not be smiling. You cant help but laugh out loud when your flying the pattern. With electric we'll hear you! Quick anecdote,  if you look at the super Satan video, most tricks are recognizable  but when doing the triangles i didn't like the second leg as it was too steep so, i tried to flatten it. The plane was instantly behind me. I was lucky to save it. This being only the second flight on it. It now has 8 flights lol!
Tom
AMA 13001
Online Will Hinton
« Reply #18 on: September 10, 2019, 10:18:09 AM »
I am totally enjoying this thread!  Around 2001 or 2002 we were urged to have speed limit at the FCM and Allen suggested he and I should enter to support the kind guys who were running it.  I got a fast ship around, put my LA25 on it and did so.  I flew combat exclusively in the 60's, figured this would be a really super way to get back at it. HA!  In the middle of the first match my opponent suggested we just fly level for a few laps as he was getting dizzy.  I COULD HAVE HUGGED HIM!
Wow, does 75 MPH seem blazing now.  Please keep these posts coming and I will cheer for all of you to have a great time.  And I will enjoy the posts, guaranteed. #^ #^ #^ #^
Offline Al Ferraro
« Reply #19 on: September 10, 2019, 10:47:43 AM »
 Later - Bob Hunt
[/quote]
            I guess Ill hold off putting a tune up on my Fox MK VII.  >:D
Al
Offline Bob Hunt
« Reply #20 on: September 16, 2019, 03:00:47 PM »
Hi Al:
Not predicting any speeds until we test fly, but I'll bet I score high in cool factor! I sprayed on a bit of Viper Red and shot a little clear on the beast this past weekend. It's not a "stunt" finish, but it should suffice. I just finished the details of hooking up the controls, installing the adjustable leadout guide, putting in a bit of tip weight, and mounting the motor. Will DeMauro is scheduled to come over on Wednesday to help me finish up the ESC and battery installation, and test fly both of our birds. We'll know more about potential performance then. Again, I'll be test flying this thing with a somewhat mild setup; an E-Flite Power 10 motor and a 4S 1600mAh pack. If all goes well, Will will inject the "juice."
This has been a fun project!
Later - Bob Hunt
Offline Bob Hunt
« Reply #21 on: September 16, 2019, 03:02:22 PM »
Here are a couple more shots of the Sweet Sweep...
« Reply #22 on: September 16, 2019, 05:10:01 PM »
Looks totally awesome.
Offline Andre Ming
« Reply #23 on: September 16, 2019, 05:19:25 PM »
Bob:
Your Sweet Sweep looks "evil"... pure and simple! Wicked "EVIL!!!"  VD~
Hope you all will have a ton of fun this coming weekend.
Andre
« Reply #24 on: September 16, 2019, 05:22:15 PM »
Very Nice Bob!
An inspiring model that should have a very high speed potential once dialed in.
A far cry from my last electric combat model a 5th Revolution (Aeromodellor plan) converted from PAW19 to a 550 size can Kyosho RC truck motor and 8 cell ni-cad (with small AE cells) pack in the 1980's
Looking forward to hearing how the  Sweet Sweep goes
Regards Gerald
Offline Bob Hunt
« Reply #25 on: September 17, 2019, 05:26:32 AM »
Thanks for the positive comments Frank, Andre, and Gerald!
Just a bit more background on this ship: I originally built it just as an exercise to see how I would engineer it to be built in my Lost-Foam Wing Building System. I had previously built an I-Beam wing in the LF system, and reasoned that a severely swept wing would be easy to build in that system, too. It was!
I had originally wanted to build Larry Scarinzi's Sting Ray for the Combat Festival and make that electric, but there were no plans available. The Sting Ray, as most of you reading this know, has a swept forward wing design, and I knew that it could also be built easily in the Lost-Foam process. The Sting Ray - which is a derivative of the Greased Lightning series of models from Larry - has a much thinner wing, and I reasoned that it would be more difficult to "hide" the battery in that design. I'd still like to try that model in the future for electric.
Later - Bob
« Last Edit: September 17, 2019, 05:52:34 AM by Bob Hunt »
Offline Bob Hunt
« Reply #26 on: September 17, 2019, 05:30:22 AM »
Here are a few more of the build photos...
Bob
Offline Bob Hunt
« Reply #27 on: September 17, 2019, 05:34:31 AM »
And a few more...
Bob
Online jfv
« Reply #28 on: September 17, 2019, 07:20:04 AM »
Really neat Bob!  Looking forward to Sunday.  Tried the Speed Stunt pattern with my Double Diamond.  Too fast at about 115 mph for the pattern.  Couldn't keep up, particularly for the square 8's.  Seems like I'm only good to about 100 mph.  I'll have to fly high with one of my more tame planes to try and cut the time and beat Tom, the record holder.  I think I did about 1:32 last year.  Tom was in the mid 1:20's.  If you haven't tried it, it's a real hoot.  Hard to keep from laughing while your trying to keep up and remember where you are in the maneuvers. especially with only one lap between maneuvers.
Jim Vigani
« Reply #29 on: September 17, 2019, 07:58:41 AM »
Looks great Bob I’m looking forward to a flight on that tomorrow.i think we will get it to go plenty fast.
AMA 98010
Offline Al Ferraro
« Reply #30 on: September 17, 2019, 08:12:47 AM »
Hi Al:
Later - Bob Hunt
            Hi Bob, I'm looking forward to see your plane it looks awesome!!!
  Please be careful using the plastic electric props. Here is APC rpm limits from their website.
Thin Electric (E) Propellers
  Maximum RPM=150,000/prop diameter (inches)
So you can only spin a 9 inch APC prop 16,666 rpm.
Al
Offline Bob Hunt
« Reply #31 on: September 17, 2019, 10:42:24 AM »
Thanks for the warning, Al, but I'm certain that we will be using carbon 8 x 7 and 8 x 8 props.
Looking forward to the event!
Bob
« Reply #32 on: September 17, 2019, 11:02:27 AM »
18750 rpm is max, should we opt for the plastic 8x8 or 8x6 . We will most likely run carbon fiber props anyway. I also have my doubts that we will hit those rpm especially with an 8x8 . RPM most likely won’t be a concern. Cooling, battery usage and motor limitations are our biggest obstacles. We will go fast regardless. We will have fun for sure. We will be at least competitive.
AMA 98010
« Reply #33 on: September 17, 2019, 02:28:14 PM »
I told Bob that his ship is gonna screw him into the ground lol.  ~^
Ditto some of the glow ships .
Offline djmachinist10
« Reply #34 on: September 17, 2019, 06:46:54 PM »
Bob, wow!! The sweet Sweep Electric looks fantastic! The nose area is a masterpiece of engineering. I am so glad you finished the plane. Looking forward to a flight report.
Dale Jones
Katy, Texas
Offline Fredvon4
  • Central Texas
« Reply #35 on: September 18, 2019, 10:34:24 AM »
Is it optical illusion in the photos? to my eye the forward of LE ---skeggs/ air dams(?) seem to NOT be parallel to the fuselage but skewed out...
Fred von Gortler IV
Offline Tom Luciano
« Reply #36 on: September 18, 2019, 12:44:23 PM »
Not sure Fred. As I look at it, I find myself seeing a lot of B-52!
Tom
AMA 13001
Offline Bob Hunt
« Reply #37 on: September 18, 2019, 08:12:02 PM »
It's an optical illusion, Fred. I thought the same thing when I aligned them. I double, triple and quadruple checked the alignment of the fences and they are on pretty darn straight.
I flew the ship this afternoon. Will DeMauro came over and helped me with the installation of the ESC, battery and timer. We took both of our planes out to a local RC field and test flew them.The Sweet Sweep flew right off the board with no trim adjustments required, except for the removal of a tad bit of tip weight. We didn't get an accurate time of the ship with the conservative motor setup, but we both think it was north of 8o MPH. Will flew the "hot" setup in his ship and it just blistered around. I'm certain it was going well north of 100! Then his motor burned up leaving a huge cloud of smoke strewn across the sky! It was most impressive. He sure found out where the edge was... He's going to install another motor and tame it down just a bit. Hey, until you try this stuff at it's limits, you just don't know what will work.
We are both looking forward to Sunday!
Later - Bob
Offline Andre Ming
« Reply #38 on: September 18, 2019, 08:52:58 PM »
Looks like this is shaping up to be another EPIC GSCB Vintage Combat Festival!
IF you are within striking distance of this event you better BE THERE!!!
Y'all are gonna' have SO much fun!
Andre
Offline Tom Luciano
« Reply #39 on: September 19, 2019, 06:18:28 AM »
In a collaboration with Phil Cartier,  we developed this VooDoo for this years event. Here is the prototype.  It's half covered now, should be completed tonight. Unfortunately,  work issues got in the way to put more together. This will be there for everyone to fly and enjoy. We can dork it to see how it holds up!
  I want to thank Phil for the help and rushing the cores to me. This could be a fun event nostalgia speed limit or just Voodoo speed limit. Before covering its 15.5oz. This is the original sized Voodoo 36+". I'm hoping it does well. I'll have a speed limit plane there as well to have some matches between the two.
Tom
Tom
« Last Edit: September 19, 2019, 06:48:18 AM by Tom Luciano »
AMA 13001
Offline Bob Hunt
« Reply #40 on: September 19, 2019, 07:42:30 AM »
Tom: Clean your bench off!  VD~
Bob
Offline Al Ferraro
« Reply #41 on: September 19, 2019, 08:08:46 AM »
 Tom, your Stunt Speed flight was awesome!!! Watching the Super Satan zoom through the clover at 118mph was really cool and shows off its amazing turning ability.
  Ill see you Sunday
Al
Offline Tom Luciano
« Reply #42 on: September 19, 2019, 08:47:34 AM »
Bob
You noticed. See the red, white, and blue paint from getting  the crossfire ready for the Nats!
TL
AMA 13001
Offline Tom Luciano
« Reply #43 on: September 19, 2019, 08:57:20 AM »
Look out Im bringing the heat this year!!!! Lol
Remember there are 3 coveted trophies we are shooting for.
1. The Scarinzi speed award
2. The Speed Stunt award
3.The Infamous blown fox award
Defending champs
Speed -Al Ferraro
Stunt - Tom Luciano
Blown Fox- Tom Luciano   SH^
We may need to add a fried motor award! Does anyone know where I can get one.........oh wait, I know!!!
AMA 13001
Offline Tom Luciano
« Reply #44 on: September 19, 2019, 09:33:02 AM »
Thank you, Al!
  Not sure I can pull that off again. Maybe I should put a patch over my eye!!
Tom
AMA 13001
Offline Jim Damerell
« Reply #45 on: September 19, 2019, 09:43:39 AM »
You're not claiming to have actually watched that flight. are you! You weren't even facing the plane most of the time!  LL~ LL~ LL~ LL~Everyone ends up laughing!!
« Reply #46 on: September 19, 2019, 09:51:36 AM »
     I think it's horrible you guys are mocking and destroying Fox motors, they're really good, I never had any problem with them.
Offline Peter in Fairfax, VA
« Reply #47 on: September 19, 2019, 10:00:11 AM »
That broken Fox case is scary.  Did it really break like that while running?
Offline Tom Luciano
« Reply #48 on: September 19, 2019, 11:24:36 AM »
HMM, coming from a professional hurler.....I believe his tongue is firmly pressed in cheek. tsk,tsk…
Yes it did blow that way! As larry presented the award he said "I never seen one blow like that" take a look at the case on the award! It blew identical. We believe this to be the reason why the webbed version came a few years later. Maybe Andre knows the history on why Duke put the web on the exhaust port.
« Last Edit: September 19, 2019, 01:06:41 PM by Tom Luciano »
AMA 13001
« Reply #49 on: September 19, 2019, 11:40:55 AM »
Bob
That's the way most combat flyers build.   the newest plane is in front, the older ones get pushed back off the end of the bench in a pile!  Or they get put into two piles, one for the wrecks that might still be useful, and the repaired, flyable ones get hung from the ceiling.
