  • July 01, 2025, 04:36:19 AM
Author Topic: Found another Coasby design - Flicka  (Read 1712 times)
Offline Robert Zambelli
« on: January 21, 2021, 02:35:24 PM »
Found this buried under some old paper.
I'm not sure where it came from, possible Mr Trostle.
Anyone know anything about it?
OTS legal?
Re: Found another Coasby design - Flicka
« Reply #1 on: January 21, 2021, 02:59:25 PM »
The Flicka, Published in the 1949 Aeromodeller Annual, Plan No. CL363.  I do not have any more than what is on the plans.  40" span designed by J.W. Coasby.
Offline MikeyPratt
« Reply #2 on: January 21, 2021, 03:30:38 PM »
Bob,
Yes it’s will make a great OTS model, I’ve had the plans for years, it’s on my “Must build list”.  Adding landing gear is not a problem with a former at the wing leading edge and run the gear vertically with a 2” wheels, them add a skid or tail wheel and your good to go.  Power it with a Fox 35 Stunt, there should be plenty of room for a 3 or 4 ounce tank.  Now I wish I had started building it long ago.
Later.,
Mikey
Offline John Park
  • Agricola
« Reply #3 on: January 22, 2021, 07:09:01 AM »
If you don't build from it, you can hang that plan on the wall and admire it! Coasby was the in-house draughtsman for AeroModeller in those days, and all his plans were works of art.
« Reply #4 on: January 22, 2021, 10:27:23 AM »
ETA 29, AMCO 3.5 cc Diesel, Yulon 30.
I have all three - I just have to decide.
Probably this one.
« Reply #5 on: January 22, 2021, 11:49:09 AM »
The fuselage resembles His Icarus design plus a canopy. The plans are on Outer Zone along with many others.
Offline Steve_Pollock
Offline Shorts,David
« Reply #7 on: January 23, 2021, 12:46:29 PM »
If there was a category for OTS planes converted to R/C pylon racers, then I might pull a transmitter out of the mothballs and build that thing. It looks fast!
« Reply #8 on: January 23, 2021, 06:31:00 PM »
All good info.
It's definitely on my "to build" list!
I like speed - I have a brand new, never run Dooling 29.
I might put that in it instead of the ETA.
OTS at 85 MPH - sounds like fun.
