  • July 19, 2025, 02:09:06 AM
Author Topic: gotta idea, want thought's.........  (Read 2665 times)
Offline Bootlegger
« on: November 22, 2009, 12:45:34 PM »
  Guy's I am thinking about "double covering" the wing with silkspan, first layer "OO" silkspan, then second with "G M"  silkspan.
  What are your thought's and would you do it another way, and why???
  As usual, Thanks a Lot......
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bootlegger
Re: gotta idea, want thought's.........
« Reply #1 on: November 22, 2009, 03:01:24 PM »
 Thanks Ty, I'm gonna do away with thar idea...
Gil Causey
AMA# 6964
Offline Neville Legg
« Reply #2 on: November 22, 2009, 04:10:34 PM »
Gil, go to www.freeflightscale.com  then the technical tips section,  and see how my mate Mike uses Silk over jap tissue!   Very interesting.
Cheers     Neville
(not) Descartes
Offline Tom Niebuhr
« Reply #3 on: November 22, 2009, 04:51:57 PM »
Gil,
Yesteryear it was common for some people to use two layers of light silkspan.
I have never done it, however.
AMA 7544
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: November 22, 2009, 05:01:50 PM »
I used that technique on a Smoothie I still have. Labor intensive as light tears easily and you have to do it twice. Still, a successful experiment as it filled fast, is light, and as strong as heavy silkspan. Will I do it again?, probably not.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Garf
    • Hangar Flying
« Reply #5 on: November 22, 2009, 05:21:43 PM »
One layer SGM, lotsa dope, OR.............Mono.............................................
Offline pipemakermike
« Reply #6 on: November 23, 2009, 07:22:34 AM »
I have had success with covering just the open bays using the thin mylar (like used on the European combat models) fixed down with a heat sensative glue (thinned Evostick) then covering the whole wing or stab with a single layer of light tissue.  This combination gives much superior puncture resistance, huge torsional rigidity, lighter weight than 2 thickness of light tissue - probably due to the much reduced dope use to fill.  There are a couple of downsides. It can be tricky to get the tissue on without ripples (but I have a similar problem with double covering in tissue).  If using a mixture of clear and colored finish care must be taken with masking tape removal to avoid separating the tissue from the mylar as it shows a slightly different shade of clear.
My friend Brian covers his models in a similar way but used the light tissue in place of the mylar.  He has found that he can get the second coat on without ripples by water shrinking the second layer of tissue then once it is dry and shrunk washing the entire surface with a generous coat of pure thinners.  This seems to stick the tissue down without allowing it to slacken.
http://www.machineconcepts.co.uk/aeromodelling/brians_engine/brian_with_model_after_flight.jpg
Mike Nelson
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #7 on: November 23, 2009, 10:09:03 AM »
For Mylar and silkspan it's easier to use SLC from the Core House, I've done a couple ships covered with SLC then medium silkspan and both turned out great. SLC has the adhesive built in and is suppose to have a finish that can be painted directly. I recommend using a scotch bright pad to scratch the surface then a wipe down with acetone before putting on the silkspan. This insures it will stick and I've not had any masking tape lifting issues.
The result is a silkspan finish that is light and maybe tougher than polyspan. I'm using SLC on the FJ-4 carrier airplane I'm building and going to try painting directly over the SLC with dope. If you would like to see how it turns out I will be posting updates in the Building a fun carrier thread in the carrier section.
Offline Greg L Bahrman
« Reply #8 on: November 23, 2009, 01:28:45 PM »
Hi Bob or anyone,
Does the SLC need primer over it before the color ?? TIA
« Last Edit: November 23, 2009, 02:01:02 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Bob Reeves
« Reply #9 on: November 23, 2009, 03:07:03 PM »
Hi Bob or anyone,
Only on the seams and that's more to cover them than anything.. The recommended primer is duplicator rattle can sandable primer available from most any auto parts house. One warning, it will dissolve with prepsol and/or other degreasers even after it's cured for several days.
I can't seem to get SLC around compound curves so I just cut it anyplace it doesn't lay down, put a coat of finish resin on the edge and any wood left bare to seal the edges and wood. Wipe it off with a paper towel, next day lightly sand and hit with the primer. When the primer is dry sand smooth and it's ready for color. I wouldn't do a whole airplane this way as the primer can add weight real quick but for spot areas it's great.
« Reply #10 on: November 26, 2009, 12:24:13 PM »
Great tip, Bob!
Mongo
