  • July 26, 2025, 05:56:03 AM
Author Topic: teosawki build nearing completion  (Read 2375 times)
Offline pipemakermike
« on: December 31, 2013, 09:06:17 AM »
Well it is all together.  I have to finish fuel proofing it, make the tank and cover the wing then it will be ready to fly.
I have been trying not to get too houseproud about the build as I am still finding out more about the best way to make it.
If all goes well with the flying I plan to cut some more leading edge cores now I know how to cut the leading edge slot and, who knows, I might have a few more of these simple models.
Mike Nelson
Re: teosawki build nearing completion
« Reply #1 on: December 31, 2013, 09:11:59 AM »
Looking good.  You are using SLC from Corehouse for the covering I hope.
« Reply #2 on: December 31, 2013, 09:42:41 AM »
Hi John
I haven't discovered yet how to obtain SLC film in the UK.  Currently I plan to use the same mylar film that the combat guys use.  I have used it before but currently I am struggling to find a suitable adhesive.  When I last used it successfully I used Evostick thinned with Evostick solvent but neither of those are available now in the form that I used them before as the PC brigade has forced a reformulation.  I am open to any suggestions for the adhesive
Mike Nelson
Offline ray copeland
« Reply #3 on: December 31, 2013, 10:27:14 AM »
Looking good Mike! Looking forward to the flight reports.
« Reply #4 on: December 31, 2013, 10:33:54 AM »
Whomever named that plane is a real funny guy, but why would anybody do that? ROFLMBO [the_end_of_society_as_we_knew_it??] ;D
Offline Will Davis
« Reply #5 on: December 31, 2013, 11:08:52 AM »
Clayton Smith. .......The End Of Stunt As We Know It..  Yes ..he was a very funny guy  ..and a great builder
Will Davis
"Carolina Gang"
« Reply #6 on: December 31, 2013, 07:49:13 PM »
Ask Mervyn Jones.
Offline Peter Grabenstein
« Reply #7 on: December 31, 2013, 10:55:37 PM »
Hi John
Hi Mike
"Pattex clear" contact glue was often recommended for mylar in other Combat Forums.
You should find such in Hardware stores like "Bauhaus" or "Hornbach" ,not sure if there is any in the UK ?.
Just apply a thin film at the LE frontend hardwoodspar ,top of all rips ,wingtips and the backface of trailing edge.
After letting dry for a couple minutes , iron on the mylar.
This has been working for others so it should work for you.
If you can not find "Pattex clear" send me pm.
Mejzlik CZ is also a good source for it.
Peter
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
« Reply #8 on: January 01, 2014, 10:31:18 AM »
Mine has gussets but they are smaller than the genuine article.  Bigger next time.
I have learnt a lot with this build about this rather querky design.  I have approached in a "when in doubt do something" frame of mind and I am keeping my 3D model updated with anything I discover for the next one.
Mike Nelson
« Reply #9 on: January 01, 2014, 03:35:16 PM »
Thanks for the enlargement, looks like a cool model. Wouldn't mind finding one of those in a kit.
Offline Willie Johnson
« Reply #10 on: January 01, 2014, 05:20:05 PM »
Looks good Mike.  I've been wanting to build one for a while.  I may give it a shot.  Here's a link that shows some good ideas on how to jig up the combat style wings.  http://combatteam.wz.cz/letadlo/index.html
Willie Johnson
AMA 774461
« Reply #11 on: January 02, 2014, 01:42:07 AM »
Two bigger gussets at each rip plus one or two rips each side more would make this wing much stiffer and
more resistent against warps.
Build allmost the same 10 years ago.
Was a GREAT Flyer with OS FP 25 running 4-2-4 with Graupnerīs grey prop 10x4.
« Last Edit: January 02, 2014, 05:50:44 AM by shoestring57 »
« Reply #12 on: January 02, 2014, 05:41:30 AM »
Hi John
Well, once I have finished this one and got it flying and assuming that it is the good flying machine that its reputation indicates, I am going to build at least 1 more and this time I will have a jig to cut the cores and DXF files for laser cutting the parts so it is not out of the question that I will do more than a couple for me.
Hi Mike
Peter
Hi Peter
I have had a look around for Pattex and it is available from several sources but they all get very expensive when factoring in the transport costs. I am currently trying to source a clear film with a heat activated glue already on it.  I think that I have found a local source (less than a mile away) I will know in a couple of hours.
Also, The wing feels very stiff before covering so I am going to leave it as it is generally but possibly add a couple of gussets to the tiprib/leading edge interface.
Mike Nelson
« Reply #13 on: January 02, 2014, 06:06:33 AM »
Hi John
Hi Peter
Hi Mike
My favorite is "Oracover light" transparent colours, sure Solarfilm transparent will work great aswell.
But be carefull with (melting) styrofoam and excessive heat.
A heatgun  could be better to do the trick.
« Reply #14 on: January 02, 2014, 07:46:24 AM »
Hi John
Thanks for that....I'll be watching. H^^
