Thanks for that tip. More reasons to send Senor Parra some money.
What is the required adjustment?
There are a few MVVS 2.5 Parra Diesels around. The normal ABC p/l is usually replaced by a generic Rossi mk2 set with diesel fits.
Either Iron/Steel or ABC work well. The Parra head has to be individually fitted and a rod that suits the p/l may be necessary. The one in the pics has a standard MVVS rod IIRC.
The top of the liner may need a slight skim so the push/pull head goes deep enough.
The bottom of the MVVS cylinder fin assembly may need a skim as well to get a suitable exhaust duration.
A Fora 15 Diesel "Pioneer" is more powerful and cheaper!
Ray
