  • June 22, 2025, 09:12:31 AM
Author Topic: Goldfish unveiling and a question...  (Read 1521 times)
« on: April 13, 2017, 07:00:40 AM »
If you can attend tonight's NVCL meeting, I'll be unveiling my Goldfish.
But, there is a problem.  Notice in the pictures that the engine (by necessity) is canted outwardly quite a bit.  This precludes use of a standard muffler.  I have to find a muffler with not only a longer stem (if that's what it's called) and also angled away from the engine centerline.  Suggestions?
Re: Goldfish unveiling and a question...
« Reply #1 on: April 13, 2017, 07:02:36 AM »
other notes...
the belly is silver (of course)
and it has options for lead-out adjustments
« Reply #2 on: April 13, 2017, 10:14:14 AM »
Come fly at our field and you wont need a muffler.   Ear muffs maybe. LL~ LL~  Hope she/he flies as well as it looks.
Offline Carl Cisneros
« Reply #3 on: April 13, 2017, 11:26:55 AM »
Scott
only thing I can think of is a tongue muffler.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Offline Steve Thompson
« Reply #4 on: April 13, 2017, 01:09:32 PM »
I really like this fish-plane!
Tongue would be simplest, as suggested.
Maybe...  File stock muffler flange at an angle to fit.  Looks like an older Fox with no lugs, so a strap type mount might allow for mounting with angled flange.
If you do use a stock Fox muffler, it would kind of look like a Remora (sucker fish that you see attached to sharks)!
« Reply #5 on: April 13, 2017, 04:22:43 PM »
A true piece of art!
Online Dan Berry
« Reply #6 on: April 13, 2017, 04:48:47 PM »
Bring it to SMALL in June. We won't require a muffler.
Offline Serge_Krauss
« Reply #7 on: April 14, 2017, 07:42:24 AM »
It's a great design with beautiful execution. I expect it to fly much better than the "Flounder." The tongue muffler seems the right choice to me, especially weight-wise on a low-aspect-ratio model, but I haven't used mufflers - yet - on engines without the mounting lugs. I am really looking forward to flight reports!
SK
« Reply #8 on: April 14, 2017, 01:54:45 PM »
Thanks All!  I've got to figure out how to time my flights as I have crashed my Super Ringmaster many times because I was in the middle of a saber-dance when I ran out of fuel.  Hopefully I won't repeat that practice with my Goldfish!
« Reply #9 on: April 14, 2017, 03:31:59 PM »
Where is your count down timer.   I used to use one when teaching people how to fly RC.   I learned that about 10 minutes is all a new student can handle when first learning.    What size tank and is it uni-flo.  Best bet is take off with full tank and just fly it dry.   Then set your timer for about a minute less.   Granted the engine will lean out when in vertical position but when your timer goes off level out and fly it dry.   On my Bi-Slob's I have run out of fuel because I had the timer by my bad/dead ear.  I think I only have 2 1/2 ounce fuel load.
« Reply #10 on: April 14, 2017, 06:27:59 PM »
Great suggestion, but I've never found anything that looked like it would work.  What kind/brand of timer do you use?  Where did you get it?
« Reply #11 on: April 15, 2017, 11:03:23 AM »
Check housewares at Wally World(Wal-Mart).   Mine has a clip that I would clip to my transmitter or shirt collar.  In fact I still have it when riding the bicycle machine.  Its a West Bend Electronic Timer.
