  • June 29, 2025, 06:47:07 AM
Author Topic: $90.00 for a gallon of Nitrate Dope and a gallon of Nitrate Thinner  (Read 5239 times)
Mike Griffin
Just got off the phone with one of my suppliers for Dope and thinner.  It is now $90.00 for a gallon of Nitrate Dope and a gallon of Nitrate Thinner.  Got to be a better way
« Last Edit: October 03, 2011, 08:55:05 AM by Stunt Supply »
Re: Price of Dope and Thinners went up again
« Reply #1 on: October 03, 2011, 08:19:17 AM »
Another reason to go electric.  LL~ LL~
Mike Griffin
« Reply #2 on: October 03, 2011, 08:46:35 AM »
GOOD POINT DOC
Re: $90.00 for a gallon of Nitrate Dope and a gallon of Nitrate Thinner
« Reply #3 on: October 03, 2011, 12:08:13 PM »
Yea, I just looked up stuff on Aircraft Spruce. Randolph's is a bit less than Certified (a dollar or two). Thinner going for about 37 a gallon. Not cheap, but it is what it is.
« Reply #4 on: October 03, 2011, 01:15:38 PM »
Also, remember that thinner is likely to be available locally.  I use PPG Acrylic lacquer thinner from a store dealing in automotive paint.  This works nicely with Briodak dope products.  A gallon is, I think, about $35.
larry borden
« Reply #5 on: October 03, 2011, 01:24:56 PM »
I use Dupont thinner for everything and its around 35 a gallon.
Mike Griffin
« Reply #6 on: October 03, 2011, 01:33:03 PM »
I just went to Aircraft Spruces site.  I also have bought from them for a while also.
I am seeing $44.10 for a gallon of Nitrate high solids dope and $45.71 for a gallon of Nitrate thinner.  That is about 15-20% higher than the last time I bought it.
larry borden
« Reply #7 on: October 03, 2011, 01:43:56 PM »
Remember, fuel prices are thru the roof and they have to make a profit also.
« Reply #8 on: October 03, 2011, 01:56:56 PM »
Why's that?
Mike Griffin
« Reply #9 on: October 03, 2011, 02:01:41 PM »
Well I guess I am going to have to get better at applying the monokote type coverings.
« Reply #10 on: October 03, 2011, 02:35:13 PM »
I have been using Dupont 3608s thinner for years in both nitrate and butyrate. I bought the last gallon a couple of years ago for less than $20.00. I am running low, so will see what it costs now.
Offline Doug Moon
« Reply #11 on: October 03, 2011, 02:48:27 PM »
Have you tried Sig?
One of the reasons it is high is the HAZMAT shipping.  You could possibly buy it from SIG in smaller quantities to equal what you need and not have to pay the hazmat and it would be less....just thinking out loud here.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Dwayne
« Reply #12 on: October 03, 2011, 03:46:00 PM »
Why's that?
Because you don't need fuel proofing, everyday Krylon works just fine and at my local hardware store it's only 5 bucks a can.
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #13 on: October 03, 2011, 05:00:55 PM »
(Howard is going to point out that nitrate dope is not fuel proof by any means.. which sorta nulls out the "go electric" argument)
I prefer nitrate for attaching silkspan, and use old-fashioned talc mixed in it to make a filler coat. It's stickier and lighter in weight than butyrate, and you can spray butyrate (or most anything else) over it, but not vice versa. It is less tautening (grammar?) than butyrate I believe. Some people use it only on fillets to get better butyrate adhesion and prevent blisters.
IF you spray a wet enough (or "retarder" laden) coat of butyrate over "dry" nitrate, the thinner can dissolve it and you'll get a chemical fight, staged at the molecular level, between nitrate and butyrate. Many people fear that result and avoid nitrate. Also there is the rumor that the slightest scratch in a butyrate top coat can expose the non-fuel-proof nitrate substrate and fuel mist will then destroy your model.
I acknowledge such things can happen and my best advice is "just don't do that"..
Actually, I'd love to find a nice water based non toxic paint with similar gluey, filling, and lightweight properties to replace nitrate dope for use over silkspan. (edit.. I forgot about corn starch)
L.
"Endurance is patience concentrated." -Thomas Carlyle
« Reply #14 on: October 03, 2011, 05:05:51 PM »
    That's pretty much what has happened to my current airplane. It got wet waiting for flying to be suspended, then the pipe heat steamed the joints in the pip tunnel open. Then oil got under the paint, separated the nitrate from the paint and balsa, and then bubbled up.
Offline GGeezer
    • Gizmogeezer Products
« Reply #15 on: October 03, 2011, 06:09:54 PM »
Jim,
DuPont has discontinued manufacturing lacquer based products along with the 3608 thinner. If you can get any, it will be old stock so buy as much as the supplier has.
Orv.
Online Gary Mondry
« Reply #16 on: October 03, 2011, 07:39:33 PM »
Don't forget about Wicks Aircraft either.  I've gotten good service from them in the past.  A gallon of Randolph non-taughtening clear from them is $44.27, a gallon of Butyrate thinner is $28.31.  Nitrate prices are similar.
http://www.wicksaircraft.com/catalog/product_cat.php/subid=8644/index.html
Gary
AMA 10663
Offline billbyles
« Reply #17 on: October 03, 2011, 09:26:59 PM »
I am sitting here looking at an invoice from Aircraft Spruce for a gallon of Randolph butyrate thinner that I picked up last week showing a price of $25.40 for the gallon.
Bill Byles
AMA 20913
So. Cal.
Offline billbyles
« Reply #18 on: October 03, 2011, 09:33:54 PM »
L.
Hi Larry,  nitrate actually tautens more than butyrate but the dried nitrate film has a lower tensile strength than butyrate.
Bill Byles
AMA 20913
So. Cal.
Offline Larry Fernandez
« Reply #19 on: October 03, 2011, 09:40:22 PM »
I have yet to see a 20 point finish with Krylon paint.
Larry, Buttafucco Stunt Team
« Reply #20 on: October 03, 2011, 09:48:06 PM »
I posted a list of part numbers and prices from Aircraft Spruce Specialties, for Randolph and Certified dopes and thinners, on the Stuka Stunt Message Board this morning.
There is also some info on other thinners, on the very same thread
« Reply #21 on: October 03, 2011, 10:03:18 PM »
Nelson's point certainly fits the bill up to the "gluey filling and lightweight" part -- and I'm not sure it doesn't do for lightweight.
I have painted Polyspan with it, but that was for a very casual model that was just stripes on Polyspan.
edit
Of course, in liquid form it's about 4x more expensive than dope -- but if it covers more than 4x as well, I guess you'd get it back both in weight and cost.
« Reply #22 on: October 03, 2011, 10:47:49 PM »
You aren't shaking the can long enough, Larry.  For front-row quality, you need to shake it vigorously for three minutes.  This is difficult for a man your age, but it pays off in the finish.  Hope this helps.
« Reply #23 on: October 03, 2011, 11:15:13 PM »
Ouch, that hurt.
« Reply #24 on: October 04, 2011, 09:42:52 AM »
Why's that?
Don't have to fuel proof every thing.  Of course I never thought about the battery leaking. VD~
  • Red Hot Lover
    • Stephanie Miller
« Reply #25 on: October 04, 2011, 12:07:11 PM »
Electric models are fraught with their own problems. Due to the presence of a strong rotating magnetic field in the engine bay, you need to use a non-ferrous paint. Otherwise it will get magnetized and create a major drag on the motor.. (Avoid iron spinners for the same reason.)
And the coming cryo-fielded motors running off the butane fuel cells will be even worse; even non-ferrous materials will be affected by the ten fold increase in the rotating magnetic field strength.. And liquid nitrogen escaping from its dewar will easily damage the finish. The really exotic setups using helium will be worse, due to the small size of the He molecule and its ability to escape containment. Finally, hydrogen will complicate the problems further.
http://www.ficklegrubberinstitute.com/cryomodelmotors
http://www.stcu.int/documents/reports/distribution/tpf/MATERIALS/TPF/SI_4_06eng1%2025.pdf
Everything has a cost. ;->
L.
"All those who believe in psychokinesis, raise my hand." - Steven Wright
Offline Balsa Butcher
  • High Desert Flier
« Reply #26 on: October 04, 2011, 12:19:33 PM »
You know, I get really tired of "Electric Evangelists" sniping at every post the concerns gas powered issues. WE GET IT! Electrics work really well, probably the wave of the future. But some of us like internal combustion engines and the challenges that go with using them to power our planes.  So pleese, if you have nothing apropos to contribute to the subject, move on! R%%%% As far as the high price of dope goes, isn't spending money the best part of the hobby?  LL~
Pete Cunha
Sacramento CA.
AMA 57499
Offline billbyles
« Reply #27 on: October 04, 2011, 04:03:39 PM »
Right on, Pete!
Bill Byles
AMA 20913
So. Cal.
Dwayne
« Reply #28 on: October 04, 2011, 04:06:57 PM »
F2B doesn't have appearance points
Offline billbyles
« Reply #29 on: October 04, 2011, 04:15:21 PM »
The above quote is pretty much a non-sequitur.
Bill Byles
AMA 20913
So. Cal.
Offline Dan Bregar
  • Field Marshall
« Reply #30 on: October 04, 2011, 06:15:02 PM »
To quote a well known stunt guy, "our real hobby is spending money".  So enjoy !!!  :##
AMA 33676
« Reply #31 on: October 06, 2011, 09:24:54 PM »
Yup!
All seriousness aside, is there any other paint chemistry that will do what butyrate does with respect to filling wood, attaching & tightening up covering & such?
