  • June 22, 2025, 12:54:03 AM
Author Topic: Chill now/ Heat later  (Read 1861 times)
Offline Leester
« on: August 22, 2010, 06:34:08 AM »
I finally got my new garage wired and now installed the A/C Heater unit, only thing left is to insulate and finish but that will take some time. I now can work in my shop/garage in all weather. The unit is 220 electric so it should do a good job, but now where does the car go ???
Leester
ama 830538
Offline afml
Re: Chill now/ Heat later
« Reply #1 on: August 22, 2010, 06:39:24 AM »
Looking good! #^
How big is your new garage??
Hmmm....Cars go OUTSIDE! LL~
"Tight Lines!"
Wes
Wes Eakin
Offline Leester
« Reply #2 on: August 22, 2010, 06:54:20 AM »
Wes,  it's 20' X 20' so the 12,000 btu is listed as the right size.
Leester
ama 830538
Offline builditright
  • So happy to be alive!
« Reply #3 on: August 22, 2010, 07:23:41 AM »
with the new laser I need it cool (cold) when I do my thing, so I just put in a 25,000 BTU in my garage
and when it's in the upper 90's outside that thing keeps it at 72 ;)
Thank you and God Bless
Walter
aka/ builditright
Offline dennis lipsett
« Reply #4 on: August 22, 2010, 07:35:12 AM »
Walt,
What model is that behind the Old Fokker Wing.
Dennis
Offline Leester
« Reply #5 on: August 22, 2010, 08:01:31 AM »
Dennis, behind the BHM Fokker wing is my 25 size MoBest (MiniMo).
Holy Lazer cuter Walter you must have a monster garage for 25,000 btu's or you like it frigid  y1 y1
Leester
ama 830538
« Reply #6 on: August 22, 2010, 11:49:15 AM »
.......... but now where does the car go ???
Nail a tarp on the side and tie the loose corners to the tree. ;D H^^
« Reply #7 on: August 22, 2010, 12:08:37 PM »
When you insulate, put up the best.  The local home supply didn't have what I wanted.  I wanted the silver faced insulation.  Put up the paper backed stuff full depth of the 2 by's.  Then code says I had to put flame retardet material over it.  Shop looks good and as stated a tarp over the car and leave it outside.   LL~ LL~
Offline TDM
« Reply #8 on: August 22, 2010, 12:48:30 PM »
20x20 I am jealous
Offline Chuck Feldman
« Reply #9 on: August 22, 2010, 01:29:39 PM »
Leester,
Good luck with your shop. Mine is 12 x 14 and is insulated and panel. I only need a floor type heater as it doesn't get really cold down here in Florida. Wait a minute it got cold last winter, did I forget? Well anyway the heater did the job. Flying down here in Stuart was greatly reduced due to the cold. Best of luck with your new cave.
Chuck Feldman
AMA 15850
Offline Bill Heher
  • Fix-it
« Reply #10 on: August 22, 2010, 11:55:01 PM »
"but now where does the car go "
- everybody knows that the car goes back-n-forth to the Hobby Shop / Home Improvement / Hardware store!
Bill Heher
If it's broke Fix-it
« Reply #11 on: August 23, 2010, 02:19:30 AM »
I just like it frigid  y1 y1
Walter
aka/ builditright
