  • July 20, 2025, 07:40:57 AM
Author Topic: Going to my archives to finish one of my old designs  (Read 4861 times)
Offline John Miller
« on: September 14, 2011, 12:03:09 PM »
I thought this may be of interest to some who frequent the forums.
I recently finished up the "2 Bits Bipe" as many of you know. I'm currently involved in trimming issues, but, it looks promising at this time.
I was looking through my files the other day, and came across an unfinished design that was the genisis for the "2 Bits Bipe". It's named simply, "2 Bits". I'm guilty of starting many designs and getting them in process, then moving on to another design before I finish it. As I looked it over, I realized that it wasn't bad looking, at least in my opinion, and the "numbers" appeared to be good, so I decided to finish it finally. I'm nearly done, and far enough along to share it.
It was originally designed to use the OS .25VF, and a pipe, thus the name "2 Bits". The new Enya .32 rear exhaust could easily be used with a pipe, or with todays tendency to overpower stunt ships, it might be possible to go up to almost any size engine you desire with a few simple changes to accomodate the larger engines. E-Power would be simple to convert to as well.
Specs are 588 sq. inches, 52 3/4" span, 39" legnth. The airfoil is a dirivative of the NA 63A modified airfoil, which has served well in many designs.
I'm attaching a PDF of the plans for you to look at. Comments are welcome. H^^
« Last Edit: September 14, 2011, 07:55:07 PM by John Miller »
Offline Gerald Schamp
Re: Going to my archives to finish one of my old designs
« Reply #1 on: September 14, 2011, 01:43:24 PM »
John,
Cool look, like the rearward canopy position. Might be a great home for an LA .46 too.
Gerald Schamp
Offline PerttiMe
« Reply #2 on: September 14, 2011, 02:35:44 PM »
Are my eyes lying or does the wing have a pretty big aspect ratio?
Otherwise, I only feel qualified to say I like the look except I don't usually like cheek cowls. Do they serve a purpose or are they mainly for looks?
Offline John Miller
« Reply #3 on: September 14, 2011, 03:37:33 PM »
The aspect ratio is about 5 to 1, about average for a stunter these days.
I like the cheek cowls on the Bipe. They really look better in person, that's why I retrofitted them onto this design. The main funbction is that it stiffens up the nose considerably. One could make good use of them with a side mounted engine, and they could be made functonal as additional cooling scoops for electric systems, by ducting cool air directly onto batteries, and other components. Not a problem, and builders choice whether to include them or not I suppose.
Thank you both for your comments. H^^
  • Gravitywell
« Reply #4 on: September 14, 2011, 06:00:22 PM »
I usually don't like the look of modern stunters, but for this one I'll make an exception.  Very nice. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
« Reply #5 on: September 14, 2011, 06:31:03 PM »
thats a cool looking airplane - now just get someone the cut files for laser cutting and I'll get one!!
Offline Tom Niebuhr
« Reply #6 on: September 14, 2011, 07:10:02 PM »
John,
Looks nice like all of your airplanes. The canopy looks a little like my "Top Hat" which was published in Flying Models a few years ago.
AMA 7544
Offline John Miller
« Reply #7 on: September 14, 2011, 07:32:08 PM »
I tried for a retro look, with some modern touches in a few strategic locations. The aft cockpit location is pure retro, the nose was influenced by the Knight Twister when I did the Bipe. I liked the look on the Bipe, so I fitted the cheek cowls to the mono plane. For simplicity's sake, I fuse mounted the gear, figuring that the pipe, if used, could be slipped between the gear, and the top of the pipe tunnel.
I started this design in 2004, before the 2 bits bipe. I used the basic shapes  from this design for much of the Bipes shapes. In retrospect, considering the origin for the name, perhaps I should have named the Bipe "6 bits", as it is not, like this design, intended for a .25 sized engine.
Once I finish up a little work on the wing drawing, I will make the cutfiles, and I'll definately have at least one laser cut.
Tom, I'd love to see that "Top Hat" in person. Always thought that was a looker. Perhaps you can bring it to VSC. I'll bring the Bipe.
Offline PerttiMe
« Reply #8 on: September 15, 2011, 01:06:05 AM »
I recall the Top Hat is quite a bit bigger.
I'll admit that I thought some may be tempted to adjust the fin shape of the 2 Bits to reflect the styling of some older or retro designs that are usually available in larger sizes only.
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #9 on: September 15, 2011, 12:54:30 PM »
Wow, I really like the look of this model. Specifically the wing tip and flap shapes, the cheek cowls, aft canopy..
It's a great looking design and a fine set of plans.
Looking forward to seeing the finished model(s), and thank you for posting the excellent plans.
Best regards,
L.
"I went to the general store. They wouldn't let me buy anything specific." -Steven Wright
Offline John Miller
« Reply #10 on: September 16, 2011, 06:33:43 AM »
Thanks Larry, your coments are appreciated. I wondered who would notice the wing shapes and their significance.  H^^
Offline Allan Perret
  • Proverbs
« Reply #11 on: September 16, 2011, 06:59:25 AM »
OK, so what is significance of wing shape ?
Airfoil looks unusual, high point is more aft.
60 size would be interesting.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline John Miller
« Reply #12 on: September 16, 2011, 07:22:40 AM »
HI Allen, The wing shape is very close to an elliptical planform,with the swept back tips, which offer benefits of their own. The airfoil is a NA63A modified. The high point is slightly aft of where many are more used to. Considering the flaps, as part of the total airfoil, the high point is fractionally just over 27%. It's basically a laminar flow type, with the ability to penetrate in wind and turbulence.
With today's ideas regarding engine size vs airplane size, I suppose one could use a 60.  #^ y1
Actually, a scale up from 588 sq inches to about 650 would be a 5% scale up, and take about 4 minutes or less to do in CAD. I've had several queries regarding a larger version, so I am open to doing this.
Thank you for your comments, they are appreciated.
« Last Edit: September 16, 2011, 07:49:24 AM by John Miller »
  • Proverbs
« Reply #13 on: September 16, 2011, 11:21:10 AM »
Has the NA63A airfoil been used in Stunt before ?
If you were to do a 60 size, here is another change I would like to see.
I really like the wings elliptical planform.
I think it would look even better if you were to duplicate that shape exactly for the stab/elevator.
OOPS    Just had another look and you are really close with the stab/elev planform to the wing already.   TE of elev is straight, flaps have slight curve, would be easy for builder to make them the same.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #14 on: September 16, 2011, 11:40:12 AM »
John,
I sure would like a set of plans for both the smaller version and the larger 60 size plane. Its way cool I think, and if its ever set up so a kit can from them, mark me down for them also.
You and Pat Johnston really have a handle on some really neat and cool designs, very functional as well.
Gerald Schamp
Offline PerttiMe
« Reply #15 on: September 16, 2011, 12:44:56 PM »
... and the straight leading edge still keeps the construction straightforward. The shape without the complications.
I've been looking at the plans and there must be something I'm missing in the wing trailing edge. There's the 1/8" thick "trailing edge alignment stiffener", slotting into the ribs, and 1/16" trailing edge sheetings that will meet the "stiffener" somehow. Right? Then there's the flaps out of 3 layers of 1/8". Thinking of those thicknesses and comparing the wing plan and the profile in the fuselage plan, I cannot make it add up  ???
Am I missing a piece, looking at different versions, or just not understanding  :##
Offline John Miller
« Reply #16 on: September 16, 2011, 04:00:22 PM »
Thanks again for your comments, and ideas.
The answer about the NA63A airfoil being used in stunt before will take a bit of verbage to answer. I should probably post the answer under the design forum, but I'll give the answer here first.
The answer is yes, it's been used a lot, and on some significant designs. A search on the forum archives, under NA63A, should yield a lot of posts on the major forums, discussing this airfoil and it's use in stunt.
The problem is, that most uses are identified by the modelers name, or the design. Few of us go to the COORD files and pull out a recognised airfoil to use. It should not be surprising, as many airfoils were originally drafted, using one of a few methods in the past.
Methods such as, we hear of the old left tennis shoe trace, and I'm sure that some were drawn that way initially. Then there's the cases where a series of "French" curves were used, not to mention the old T.L.A.R. method.
In my opinion, the airfoils we use generally fall into 3, perhaps 4 types. These types do have very close examples in the NACA archives. The ones we use are so close, in many cases, that there is no fundamental difference between what we are using, and what are in the files.
These 3 are what I would tend to call the BJ (Greenaway) airfoils, (NA63A)  Ted Fancher's Trivial Pursuit is a modern design that I believe uses the NACA 4 Digit airfoils. I thought Aldrich used the 4 digit 'foils, but my good friend Geoff, from Oz, mentioned that George may have used something closer to the NA63A. (I remember him once describing how he traced his tennis shoe, anyone else remember him saying this? )  Then, there's what I call the Pathfinder foil, and possibly a 4th. group of odd ball styles seen a few times then basically abandoned.
As it turns out, designers often copied the airfoils from proven performers. If one pays attention, it's possible to see the airfoil trends arrange and group themselves based on external influences across the country, and I'm sure, throughout the world. For instance, areas that tend for stable air  conditions, tend to wind up using similar airfoils. Conversely, windy, or turbulent areas affected by those conditions. tend towards a different airfoil that addresses the conditions better.
Airfoils are chosen for specific reasons, but will often work reasonably well when encountering different conditions, so there's sometimes a mix going on. based on the designers personal likes.
Let's look first to the 4 digit airfoils. They are most notable for their blunt large radius leading edges. They are a bit draggy, esp at higher percentages. but they seem to make up for that by offering high lift, and reasonable stall characteristics, stalling often at a higher AOA than many of the others we use.  Of the designs we are familiar with today, the Trivial Pursuit is perhaps the best example
The drag can be of use with overpowered designs to help tame the beast. The major drawback may be that they are more easily affected in turbulence as the large blunt leading edge can have less ability to penetrate.
The NA63A, is very similar to BJ's airfoils in both style and performance. This can also be said of a close relative the Eppler168, 169 series.
Modifications are easy to dial in using many of the airfoil lofting programs, but the entire series shares much of the same performance. Now, I'm talking about very close, similar, not necessarily exact airfoils.
The characteristics that these particular airfoils seem to have in common is a smaller radius on the leading edge, compared to the 4 digit foil, even though the percentage of thickness is the same. These airfoils seem to penetrate turbulent air better, and don't seem to be upset as easily as the 4 digit foil. They appear to have less inherent drag, but produce good lift in our use.
These modified airfoils appear in areas where wind, and turbulent conditions are more common. Most noticeable designs are Big Jim's designs, and their derivatives, Randy Smith's SV designs, Gieskes Nobler, and the Moon brothers various designs, as well as Walkers Impacts.
The third airfoil commonly used is the one I call the Pathfinder Airfoil. It was derived fro Aldrich's FlightStreak 'foil, with the rear half forming a straight line tangent to the high point, and the trailing edge. This modification came about to allow building multiple combat wings using a flat surface instead of a jig. It's interesting that some of the top full sized aerobatic designs use a similar airfoil sometimes on both the main wing, and the stabilizer.  These airfoils have now shown up in the COORD files for many airfoil lofting programs.
Designs using these foils are many of the various Pathfinders, and some of Pat Johnston's designs. They seem to work well, and offer a combination of penetration, lift, and decent drag characteristics in our use, as well as simplified construction. I'm of the personal opinion that this 'foil, combined with a fixed trailing edge extension, as used on the Flight Streak, may well be the best airfoil to use in a non-flapped design.
The fourth group has all the failed, strange, or seldom used airfoils from our history. Diamond, high point at the center, sharp pointy airfoils that were unable to make the cut in all the competition.
So, realizing that these airfoils, while not necessarily exact, are similar enough that there is no real difference. As an example, when I drew the plans for Brodaks popular Cardinal Profile, The foil used was the NA63A modified. Gordan Delaney's Pathfinder L.E. uses this same airfoil, sized for the design.
« Last Edit: September 16, 2011, 04:59:51 PM by John Miller »
Offline John Miller
« Reply #17 on: September 16, 2011, 04:12:53 PM »
Sorry to have confused you. I'm actually still finishing up the plans, and there were a few callouts that were not yet placed on the .PDF's I posted. There's a balsa trailing edge installed onto the stiffener, top and bottom that is then shaped to allow the trailing edge sheeting to be applied, solid to the built up trailing edge.  The flaps should be 3/16" thick once the three pieces are laminated. The callout specifying 3 pieces at 1/8" has been change to a center core of 1/8" 4 to 6 lb. balsa, and two outer lamination's of 1/6" inch 8-12 lb. balsa. The harder lamination's over the softer one should yield a light and stiff set of flaps.
I trust this will clear up any confusion I may have caused. H^^
Offline John Miller
« Reply #18 on: September 16, 2011, 04:19:26 PM »
John,
Gerald Schamp
Offline John Miller
« Reply #19 on: September 16, 2011, 04:41:34 PM »
John,
Gerald Schamp
Hi Gerald, nice to hear from you my friend.
First, thank you from both myself, and I presume to speak for Pat, for your nice comment. Pat is very prolific, and I wish him well.
Once the drawings are finished, which should be over the weekend, I'll let you know. I am planning on having some laser cut for sure.
I do have a few questions I'd like to ask  though. I'm thinking that a simple scale up, or down would be sufficient for either smaller, or larger drawings. Of course, the dimensions, and drawn part thicknesses, probably would not match, but I could put together a small drawing showing the motor mount area, and what the bulkhead dimensions will have to be for the various sizes.
This would save a lot of time getting the plans out for the different sizes. I would not have to go through the entire drawing changing the offsets, and dimension call outs.
All that would be needed is to clearly mark which scale, or size the plan set was intended for.
I see a set of three drawings per set, Fuse, Wing, and Pattern. My normal charge is $10.00 a sheet. I'm thinking that I could offer the additional scaled drawings at half price, when the original is ordered, for a limited time.
I'm also considering renaming each scaled version. 2 Bits for the smallest, about 520 sq inches, intended for the .24 and up sized engines. 4 Bits for the 588 sq. inch mid sized version for .36 and up power, and lastly 6 Bits, for the 650 sq. inch largest version. This would better describe the size of each version. Everybody knows that a shave and a haircut is 6 Bits ($.75), 2 Bits is a quarter, and 4 Bits is a half dollar.
What's your take on these ideas?
Offline PerttiMe
« Reply #20 on: September 17, 2011, 02:43:50 AM »
Thanks H^^
I suspected the plan might not be quite finished, but also wasn't sure I was reading it correctly.
Offline John Miller
« Reply #21 on: September 18, 2011, 07:02:28 PM »
Well, I made some progress and a few decisions today regarding the entire X Bit series of designs.
Since the 2 bits was, and is the beginning design from which these others have evolved, It might be best to name them in a manner that relates to the actual size of the plane. So, Since 2 bits in America, refers to a quarter Dollar, 25 cents if you will, The 2 bits will have 500 sq inches of area, and should be good for engines starting with the 20-25 size.
The next size up, now called, 4 Bits, (50 cents) has 566 sq inches, and is suitable for .35, and up. Last of the mono planes in the series, is called 6 Bits (75 cents) which has 650 sq inches, and would use .51 or larger engine. Of course these are just basic recommendations, and realizing that Piped engines are capable of larger power output, the pilot can basically chose the size and plug the power that is desired in.
Now, this brings me to the last in the series, the Biplane. At well over 700 sq inches currently, and still evolving as I fly the prototype, 2 Bits Bipe really no longer fits. I'm considering calling it $1.5 Bipe Pronounced Buck and a half Bipe.
I've already done the scaling to get drawings the proper size. I've decided to go ahead and do the extra work to make each drawing a total stand alone.
The drawings for the 4 Bits, (566 sq. inches) are ready to go at this time. I'll have the 6 Bits ready next, and then follow up with the 2 Bits after that.
The Buck and a half Bipe is almost ready as soon as I finish up with the trimming flights, and should be a great Biplane stunter based on what I'm seeing in test and trimming flights.
Planes will be available separately, with savings for multiple orders. All the plans will be accurate, first generation CAD plots, and not copies or blue prints, though it might be cheaper to do it that way.
I am currently gathering quotes from the cutters so I can arrive at a price for a short kit of each of the designs. Short kits are the cut balsa, and plywood parts needed to construct the model. As most who would order, and build these designs, have their own preferences for control systems, I do not plan on including  them. I will make the system specifications available to vendors where you can order them from.
If you are interrested, as a few have indicated, drop me an email at cadclassics(at)cadclassics(dot)net, or a PM on the forum.
Thanks for your interest
Offline WhittleN
« Reply #22 on: September 21, 2011, 08:34:28 AM »
Is this a modified Pathfinder?  Sure looks like it came out of the same mold - not a bad thing but certainly many of the same design elements.  Just wondering
Norm
  • Red Hot Lover
    • Stephanie Miller
« Reply #23 on: September 21, 2011, 11:09:49 AM »
The NACA00nn airfoils have the high point at 30% of chord. As I recall, Ted Fancher's airfoils have the high point forward of this, perhaps around 20%? (Maybe I need to look closer at his latest ones.)
I wrote an Excel spreadsheet based on the NACA00nn generator which can distort the airfoil to move its high point. I'm not making recommendations, I too believe in copying things demonstrated to work well. I originally chose the NACA00nn for my own airfoils for two reasons: 1) it "looks" like a reasonable airfoil for a CL stunter, and 2) I had the polynomial equation to generate it:
Y = +/-(A * X ^ 0.5 + B * X + C * X ^ 2 + D * X ^ 3 + E * X ^ 4)
with the following coefficients:
  A = 0.2969
  B = -0.126
  C = -0.3516
  D = 0.2843
  E = -0.1015
The +/- generates a symmetrical airfoil, and it is normalized (chord length and thickness = 1). You have to scale the output for the desired chord length and maximum thickness.
My spreadsheet emits a DXF file which you can import to a CAD program. It does not plot or display the airfoil, and it generates data for one rib at a time.
Enable macros when asked, so that it can compute.
L.
PS - I wasn't allowed to post an .XLS file here (why?), so I played a "trick" to attach my spreadsheet, by renaming its extension .DOC - of course, the file will not open properly using Word, so simply rename its extension from .DOC to .XLS and I believe it will work. If not, just email me at larry@cunningham-designs.com and I'll happily email the file to you, it's only 208K.
"Thought is action in rehearsal." -Sigmund Freud
  • Red Hot Lover
    • Stephanie Miller
« Reply #24 on: September 21, 2011, 11:28:28 AM »
I forgot to mention that fooling around with the modified NACA00nn generator and AutoCAD demonstrated a near-elliptical nose shape for these airfoils.. see attachment.
L.
"If you are out to describe the truth, leave elegance to the tailor." -Albert Einstein
Offline John Miller
« Reply #25 on: September 21, 2011, 12:19:31 PM »
Hi Norm
My friend, are you Poking me with a stick? HB~>  Sure do miss you Sundays at the field.
Actually since it has wings, flys stunts on wires, it's really a modified Nobler, like most designs these days. Of course, it's been modified with over 50 years worth of design thinking, which probably does make it share a lot of elements with the Pathfinder as well as the Sultan, and most other modern designs. Since I've been learning the "Old Math Son" at your feet these last almost 10 years, I'm influenced by your designs as well. Drawing plans for Gordy, and working with him on his designs can't help but influence me as well.
The facts are, for this design, is that it was first put to paper, back in 2004, and predates the Pathfinder L.E. Yes, they do share some elements, but that can be attributed to my preferring to draw things that way, and my use of elements stored as blocks in the CAD program, and used in many drawings. For instance, check out the plans I drew for Allen Brickhaus's Legacy, and you'll see the Warren Truss style bulkheads. In reality, that design feature was taught to me by Allen years before the Legacy, when I lived in the Mid West.
Since my favorite airfoil is the NA63A modified, most of the planes I draw use that airfoil, unless, like with Allen, a specific airfoil is asked for.
I've known of the benefits to be had from the reversed, "Flight Streak" style wing tips from a design article I read way back in one of the model mags when I was in my 20's or earlier.
After I bought, and studied a great book by Simmons, on Model Aeronautics, I learned about the relationships of certain planforms that give a good approximation of an elliptical planform, I realised there are ways to achieve that without necessarily using the typical "Spitfire" style wing plan.
 :! Say, let's get together so I can "pick your ideas", for the e-version I plan on for this design. For those who may not know, Norm's E-Sultan is, in my opinion, the best model for electric power there is currently. y1
See you Sunday? H^^
Offline John Miller
« Reply #26 on: September 21, 2011, 12:31:20 PM »
Hi Larry
Thanks for your posts and for making Stunt rib available. I know it was a bit of work, but it appears that you have created a useful rib generating program for those who desire to use the 4 digit airfoils.
I use an airfoil generating commercial program myself, but yours seem to offer a lot for those who may not want to invest in a program such as the one I use. It obviously can produce excellent results. H^^
Offline WhittleN
« Reply #27 on: September 21, 2011, 01:21:38 PM »
Darn Miller
Can’t even get a rise out of you.
Offline John Miller
« Reply #28 on: September 21, 2011, 02:06:11 PM »
I'm mellow, 'cause, as we all know, I only steal from the best. LL~
Offline Gordan Delaney
« Reply #29 on: September 21, 2011, 02:56:17 PM »
Norm`s Sultan is a great airplane even with the IC engines.
Gordy
« Reply #30 on: September 21, 2011, 04:02:04 PM »
John,  I was told that you didn't steal, that only borrowed and never returned the stuff. LL~ LL~ LL~
« Reply #31 on: September 21, 2011, 04:50:15 PM »
Doc,
Didn`t know you new John so well.
 y1 n~ LL~
Gordy
Offline John Miller
« Reply #32 on: September 21, 2011, 04:53:10 PM »
Shhh, think of the reputations of those I borrow from..... S?P LL~
Offline Peter Nevai
    • C3EL
« Reply #33 on: September 22, 2011, 11:48:11 AM »
 ;D
Offline John Miller
« Reply #34 on: September 22, 2011, 04:28:30 PM »
Pete, that's so cool that I stole it for my wallpapers,,,,,,,     ~>      Hope ya done mind.... LL~
