Hey guys, I solved the CA application problems another way. I use pipettes instead of the tubing. They have a very fine outlet, and if you want them for medium or thick you can simply trim the outlet back to a proper opening. A little trial and error on that and you soon get good at doing it. It is sooooo easy to put a tiny drop where you want it with these things. And - they easily reach to the front of the molded leading edges!
I get mine from Stewart McDonald luthier suppliers at
www.stewmac.com at a price of $3.45 for ten. Sometimes I also stock up at the Toledo show, but the stewmac price is as good as you'll find anywhere. Stewmac has a minimum order of $30.00 so if you want them from there just let me know and I'll be glad to order them for you. As a dealer the minimum doesn't apply to me; they like small shops like mine.
Blessings,
Will
