  • July 17, 2025, 06:18:37 AM
Author Topic: Glow Plugs  (Read 5268 times)
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
Glow Plugs
« on: March 17, 2008, 01:47:03 AM »
Hey Guys
Which plugs do the experts reccommend for 2 stroke Stunt engines?  I've heard idle bar plugs are best. eg Thunderbolt RC plug with Idle Bar..
What are the following brands like?  Fox Miracle, Fox RC w/Idle Bar, Fireball, OS, Super Tigre.  Oh and before you ask what engine... I use OS 40 & 46 LAs, Super Tigre G21/46 & Fox 35 all with 10% nitro.
I've been using OS A3s and am not really very happy with them, they dont seem to last long.
Cheers
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Offline Dennis Moritz
Re: Glow Plugs
« Reply #1 on: March 17, 2008, 04:21:46 AM »
We like Enya #3 in my club. Seem to keep the engines like yours lit. Good durability.
Offline Paul Allen
Re: Glow Plugs
« Reply #2 on: March 17, 2008, 04:53:23 AM »
Warren
          Thunderbolt R/C Long will work well in ST 46, ST 60 and the LA's
my ST 51 likes the Fox Miracle. DS 40 likes SIG R/C Longs, I think its a
matter of just trying different brands till you find one that works in your
motor.
  • AUS-14782
    • My Home Page
Re: Glow Plugs
« Reply #3 on: March 17, 2008, 05:09:34 AM »
Hi Paul
I must get onto Brian Eather so I can try some of those Thunderbolt plugs.  BTW  I found out what was wrong with my cranky Pathfinder/ST46 at the HVC.   The spary bar was rotated slightly out of line with the venturi.  Once I lined it up, it now runs steady and holds a setting (down here at sea level anyway).  Also the Strega is back together again... looks like new. Haven't flown it yet.
I'm currently tring to find a good setup for my Vector/LA 40.  Can't seem to get it right.  I had a Fox Std short Idle Bar plug in it and it was going OK, but then Kayla plugged the glowplug into 12V and ka-poof!  I didnt have another so I put in a OS A3 and it was all over the place.  I'm going to try an OS F (four stoke) plug next flight.  In the mean time I'm going to order a few different types to try out.
Cheers
Warren Leadbeatter
AUS-14782
Offline Joe Messinger
Re: Glow Plugs
« Reply #4 on: March 17, 2008, 05:44:01 AM »
Warren,
Take a look at Randy Smith's advice on glow plugs over in the "Engine" section of this forum.  It's at the top of the list when you click on it.
Joe
Joe Messinger
Re: Glow Plugs
« Reply #5 on: March 17, 2008, 06:39:20 PM »
Good tip, Joe! Gives me something else to try next time out (besides smashing mole piles).
As for what glowplug to screw into your donk, Thunderbolts rule! I normally carry 4 stroke and idle bar, tho there are other T-Bolts that will work. Dirt uses the "Regular", which seems out of character. The two seem to cover the bases just fine. I have been running the "free" OS A3's in my .25LA with no complaints. I did notice that they're kinda shorter than a long, and longer than a short. That might make them run a bit cooler than desired. I expect they'd otherwise be about as hot as a Thunderbolt 4 stroke, which is not fitted with the coil shroud like an OS "F".
Must say, I have a poor regard for Fox glowplugs, having seen too many instances where replacing one with a Thunderbolt made such a huge improvement. I believe Brodak carries "Merlin" glowplugs, and I'd suggest trying them, if that's easier for you, as a Brodak dealer in Oz. They have a very good reputation, but we don't get them out here on the West Coast, near as I can tell.  D>K Steve
« Last Edit: March 17, 2008, 07:18:35 PM by Steve Helmick »
Offline wmiii
Re: Glow Plugs
« Reply #6 on: March 17, 2008, 07:04:08 PM »
 Why not order the Merlin's from Randy , he stocks them?
 Walter
walter menges
Offline ash
Re: Glow Plugs
« Reply #7 on: March 17, 2008, 07:05:37 PM »
I got some Merlin 4-stroke plugs to try as an alternative to ASP and OS-F 4-stroke plugs, but wasn't thrilled with the results. Very much rougher running and more needle sensitive than the others and the OS-F yeilded an imediate 200rpm gain when tried immediately afterwards. I suspect the problem was due to the fact that the Merlin plug has a small diameter coil buried deeply in the plug body, while the other two has a fairly open coil near to the outside. On that particular engine it wasn't the answer, but I've seem them do well on others.
T-bolt RC Idle is a gem on LAs.
Fireballs are passable on sport engines, but very unreliable.
Fox plugs seem OK, but I haven't tried one since settling on T-bolts as my default choice.
ASP plugs seem pretty good.
OS No.8 are good if the shortish length is tolerable
OS-F seem very good also.
Offline Jim Thomerson
Re: Glow Plugs
« Reply #8 on: March 17, 2008, 07:30:20 PM »
I have run Fox 2-volt longs for years and see no reason to change.  I do try to remember to put in a new glow plug at the beginning of the flying season, but do not always remember. I did not have good results with the Fox 2-volt shorts in smaller engines, however.
Offline Leo Mehl
Re: Glow Plugs
« Reply #9 on: March 17, 2008, 08:21:21 PM »
I run Thunderbolt plugs in all of my engines. So far they have worked in every engine I own. They cost more now but 4 bucks is ok. They kind of have a builtin warning that lets you know when they are getting old. as soon as you take bettery off the plug if the RPM goes down It is time to replace it. I have never hat one burn out while running a engine in the air, that's reliability! HB~>
  • AUS-14782
    • My Home Page
Re: Glow Plugs
« Reply #10 on: March 18, 2008, 12:51:47 AM »
Joe,
I had forgotten about Randy's engine tips article, thank you for reminding me. There's some very valuable advice there.  It has helped me before with choosing the right fuel.
I have now ordered a few different brands to try out including Thunderbolt idle bar and 4 stroke, Fox Miracle and Fox Std RC w/Idle Bar.
My experience with Std Short Fox plugs has been that they blow very easily.
Thanks guys.
Warren Leadbeatter
AUS-14782
Re: Glow Plugs
« Reply #11 on: March 18, 2008, 08:19:37 AM »
Hi Warren,
We have settled in Thunderbolt and Sig plugs, all in the *hot* range.
Bill <><
Offline Brian Hampton
Re: Glow Plugs
« Reply #12 on: March 23, 2008, 01:02:39 PM »
Warren, I've come in a bit late but try a Taipan 4 stroke plug. I'm using one while running in my Enya 60-IIIB and with straight 75/25 castor there's no discernible drop in revs when I disconnect the power and it still holds a perfect 4 stroke even with the test stand tilted almost vertical near the end of the tank. It could be a while before I fly it and try it though.
  • AUS-14782
    • My Home Page
Re: Glow Plugs
« Reply #13 on: March 24, 2008, 05:26:53 AM »
Hi Brian
Where do you get Taipan Glow plugs from?  I remember they used to be pretty good but didnt they go out of business? Or is someone else making them now?
Cheers
Warren Leadbeatter
AUS-14782
Offline Garf
    • Hangar Flying
Re: Glow Plugs
« Reply #14 on: March 24, 2008, 11:45:36 AM »
Re: Glow Plugs
« Reply #15 on: March 24, 2008, 10:53:46 PM »
Hi Warren
Garf's given the link to where they're made over near Perth somewhere and obviously they're not the original Taipans although they still use that neat colour coded insulator. My local hobby shop here in Adelaide (Model Mania) has them all in stock, the normal plugs anyway, not the special ones for Cox etc.
  • AUS-14782
    • My Home Page
Re: Glow Plugs
« Reply #16 on: March 25, 2008, 12:00:16 AM »
Thanks guys, I had some better flights on the weekend using Fox Idle Bars and OS Type F plugs.  Still waiting on the other plugs to arrive.  I like the look of those hard wired Taipans. I might give them a try at some stage.
Brian, Do you fly with Pete Anglberger and/or the Adelaide crowd?
Cheers
Warren Leadbeatter
AUS-14782
