  • July 16, 2025, 11:26:58 AM
Author Topic: Glow plugs  (Read 2728 times)
Online john e. holliday
Glow plugs
« on: June 23, 2018, 09:53:18 AM »
Noticed in the post about Thunderbolt plugs that the idle bar plugs are not available.   He referred to them as RC plugs.   When I first met the late Ken Wilson of Wilson's RC Hobby shop I was looking for parts for a control line plane.  Told him what I was needing and he hands me a package that said RC on it.  Just to rattle him I said it had to be control line.   He laughs and said here as he crossed out the letters RC and penned in CL on the package.    He is the reason I took a hiatus from CL so my son and I could learn RC.   Up to them his wife is the one that would sell/talk to me when I went in the store.    The reason I went to the store originally was because he carried Aeromodeler magazine.   But it still amazes me that so many things are listed as RC when in my thought it should be listed as for model plane use. HB~>
Offline Terrence Durrill
Re: Glow plugs
« Reply #1 on: June 23, 2018, 10:05:48 AM »
                                                Good point.        D>K       H^^
Re: Glow plugs
« Reply #2 on: June 23, 2018, 04:02:27 PM »
What is really important, of course, is the heat range of the plug.  I've use Enya #3 plugs for many years and they don't have a Idle bar but are very hot and work just fin for stunt.  I'm hoping that one of the Thunderbolt plugs without the idle bar is like that because the Enya #3's have become very hard to find also!
One of the Thunderbolt plugs said "Improves throttle response'  I hope that means it's HOT!
Re: Glow plugs
« Reply #3 on: June 23, 2018, 06:45:48 PM »
The Merlin 2004  HOT Bg Bore  s like that,  That is why I carry and  sell them plus they  are  very wellmade
Re: Glow plugs
« Reply #4 on: June 23, 2018, 09:01:14 PM »
Enya 3 and Thunderbolts are my plugs of choice, but didn't Tbolt quit making and selling them last year? I thought I'd read that , but I've been grounded by the flight surgeon for a while now, so I'm out of the loop at the moment. I hope they're still being made.
Rusty
Re: Glow plugs
« Reply #5 on: June 23, 2018, 09:46:12 PM »
Rusty
Apparently Thunderbolt plugs have been picked up by "Mike's goes Flying".  However they are not, at least for the moment making the Thunderbolt R/C Long that we like for Piped stunt engines!
See at:    Mike%20Goes%20Flying%20%E2%80%93%20Home%20of%20Magnum%20Engines.html
Re: Glow plugs
« Reply #6 on: June 23, 2018, 10:08:03 PM »
Thanks, Randy. This one will suit my needs for my mid-sized stunters. LA .46 Cardinal, etc. As you said, no idle bar. Here's the link :
https://www.mikegoesflying.com/shop/engine-accessories/thunderbolt-standard-long-plug-universal-control-line-and-r-c-plug/
Rusty
Re: Glow plugs
« Reply #7 on: June 23, 2018, 10:19:11 PM »
Hmmmmmm...
I didn't notice what happend to that link I tried to post before.  Switched browsers recently and no end to problems!  I've never been one to leave "well enough alone"  Go Figure!!!
Offline Dave Harmon
Re: Glow plugs
« Reply #8 on: June 24, 2018, 01:54:57 AM »
Ah yes.....Mike Greenshields...owner and son of the founder of the now closed Hobby Shack.
There is an interesting story on how those T-Bolt plugs came to be mfgd.
Online Steve Helmick
Re: Glow plugs
« Reply #9 on: June 25, 2018, 02:33:12 PM »
I've been running the Thunderbolt 4-cycle glowplug, which was discontinued some years ago and replaced with the "4-cycle and Big Bore" glowplug. I believe I've run it in a .46LA, the Magnum XLS .36, as well as the OS .46VF. Possibly also the PA .51 and ST G.51. If I pulled the glowplugs out, I could tell you. The 4-cycle has no idle bar.
I wouldn't know if there was really any difference, because I've yet to use up all the 4-cycle (and R/C idle bar) Thunderbolts I have in stock. They also had a "HD", which apparently meant "heavy duty", but I've not tried them...probably intended for speed and racing...do the R/C guys do that? IDK & IDC!  D>K Steve
Online Tony Drago
Re: Glow plugs
« Reply #10 on: June 25, 2018, 06:57:04 PM »
There should not be a problem on getting idle bar glow plugs. As I recall they were made by O&R as were a lot of other glow plugs for different company's.
Re: Glow plugs
« Reply #11 on: June 25, 2018, 08:04:12 PM »
The  Thunderbolt  4 stroke  plugs were killed off years ago, and replaced by the  BIG BORE  2 and 4 cycle plugs,  both silver body  both no idle bar.  There  is  no big deal  about  idle bar plugs  as  you  can get non idle bar  plugs that work extremely well,  The  Merlin BiG Bore  plugs work every bit as well as the  Old T Bolt Big bore  and  are  about 3 dollars  cheaper, and they are extremely well made
I stock both of these  plus the  SIG RC long  plugs
Re: Glow plugs
« Reply #12 on: June 25, 2018, 09:14:58 PM »
   Those two terms are synonymous. In any case, you don't want the RC plugs, you want the Thunderbolt 4-cycle plugs (which don't have an idle bar). The called them "big bore" later, but as far as I can tell, they work the same.
