General control line discussion => Open Forum => Topic started by: frank williams on January 03, 2019, 09:20:44 PM
Title: Glow Plug Measurements
Post by: frank williams on January 03, 2019, 09:20:44 PM
The wire element in our glow plugs is platinum, alloyed with either iridium or rhodium for increased strength.  The alloys add hardness to the wire and allow it to be produced or drawn more easily.
I’ve always been told that the platinum is the primary catalytic element that ignites the methanol in our fuel, but I think that either the iridium or the rhodium, are capable of providing a catalytic reaction also.  Chemists?
The starting battery heats the platinum wire to make the catalytic action occur more easily to start and once running the platinum / methanol reaction keeps the wire glowing.  (See the demonstration of the catalytic action in the following video.)
                            https://www.youtube.com/watch?v=FSdBB1vBDKY
The plug manufacturers mark their plugs as hot, medium, or cold.  I assume the greater the area of the element wire in a particular plug, the hotter the plug, or the greater the catalytic action.
As flyers, we know by experience some plugs work better for us.  Presumably the hotter plugs are better for our type of modeling use.  We want to run at slower speeds and richer fuel settings.  The “hotter” plugs are assumed to be less likely to “flame out” or “burp” during loaded maneuvers.
But short of testing every plug with enough flights to assess its usefulness for F2B, we rely on the word of the plug manufacturer and other flyers.  A good article that summarizes glow plug heat ranges from different manufacturers is the following. It is coauthored by our own Brian Gardner.
                          http://www.scootworks.com/rdrcdave/gloplugs.html
But there are other plug models and types (hose nose and big bore) that aren’t addressed in this article.
What I would like to do is to physically test the hot plugs to find the hottest of the hot and to rank them.  But, I’m not sure how to do it.
One thought was to measure the element resistance and compare the resistance with the element in the presence of methanol vapor.  Measuring the resistance with my VOM didn’t yield much information.  Obviously, the wrong tool.
What about measuring minimum idle speed of a test engine in an inverted position, and ranking plugs that way?  The assumption is that the better stunt plug will have the lower idle speed.  I haven’t tried that yet.
Anyone have any thoughts on measuring the “hotness” or “coldness” of a glow plug?  I sure like to see a quantitative assessment of current glow plugs.
Title: Re: Glow Plug Measurements
Post by: qaz049 on January 03, 2019, 10:32:02 PM
It isn't just Methanol that has the particular catalytic action with the glowplug element. Ethanol and Petrol (Gasoline) and a whole range of other hydrocarbons work as well.
Post by: qaz049 on January 03, 2019, 10:44:35 PM
I've had some success measuring the relative surface temperature emissions of hot steel using an Infrared photo-transistor and the rather course "Paddle ports" (analog to digital converter) on both the IBM PC and the Apple 2e.
Should be able to do it easily and accurately these days with a much cheaper Arduino or a Raspberry Pi microcomputer.  It would just need a fixture with the glowplug in one end and the transistor in the other with two wires to the computer board.  The result would be a relative Digital number between 0 and 255 for an 8-Bit ADC, 0 to 1023 for a 10-bit or 0-65535 for a 16 bit.
A bit of experimentation with glow plugs of known "heat-range" should determine a baseline for each category.
Post by: Dave Hull on January 04, 2019, 12:26:04 AM
Frank,
Bill Netzeband did an article years ago on glow plugs. You might find some test methods you can evaluate for further use.  I know I have always wanted to update it with modern plugs....
I found the video attached really interesting. What it also implies is that the cleanliness of the plug during testing may make a difference. A used plug with a coating of oil would likely suppress the reaction due to the lack of exposed surface area.  (I thought the guy was pretty gutsy to have attempted that test the first time. I guess chemists are...until they blow up the lab?)
ref.:  http://www.airplanesandrockets.com/motors/how-to-select-the-proper-glow-plug-1963-annual-edition-am.htm
Post by: Dan McEntee on January 04, 2019, 05:40:55 AM
Heat range of the plug is also determined by the size of the "chamber" that the wire coil is in, in addition to the size and length of the wire. There can be long and short hot plugs. Plug length is just determined by how much meat in the head there is to cut threads. You can put a long reach plug in an engine where a short reach belongs by adding a washer or two or some other type of shim. A friend of mine almost lost his first pipe ship because some one told him a shorr reach K&B plug was a hot plug and he tried it in his .40 piped engine. Almost lost it when it flamed out on the first reverse wing over. The plug didn't extend far enough into the combustion chamber. It has all been covered before here on the forums, just gotta find it.
Post by: Jim Kraft on January 04, 2019, 08:16:16 AM
See How we are responsible as model flyers. We had catalytic converters on our engines long before cars. At least we do not need oxygen sensors, yet.
Post by: frank williams on January 04, 2019, 08:35:17 AM
Ty – There are cold plugs that are long reach and hot plugs that are short reach.  In general long or short doesn’t play a part in plug temperature range.  The idea that a hotter plug is longer may come from the four cycle plugs that have an extended nose or what I call “hose nose”.  Of course a longer element wire will have more surface are and be considered hotter.  Maybe that is where the idea of long being hotter.
I use to regularly mill about 60 thou out of the plug seat on the ST60 heads.  This made the plug poke deeper into the combustion chamber.  I felt I got a hotter ignition and a better run on inside maneuvers on the ST.
Also, catalytic converters are a mixture of platinum, iridium, and rhodium.
Gaz049 – Good idea using a PIC with a IR detector …. Remember it’ not just the temperature of the element with a battery attached, but the change that takes place in the presence of methanol vapor.  What we are looking for is the relative effect of one element  vs another as it catalytically reacts with the fuel.
Dave – thanks for the Netzeband article … I’ve been looking for a copy of it.    I found the video very interesting also, everyone should study it to understand that there is no battery involved to make the platinum wire glow brightly.  He did initially heat it slightly with a torch to warm it up, but after that all the heat came from the catalytic reaction.
Dan – I think the “big bore” plugs with the increased recess for the element probably allow the methanol vapors to more easily circulate around the element wire.  I should add that I did strip out a few ST60 heads when I recessed the seat.  Also, the hard inside turn into a wingover, has drowned more that one piped stunt ship.  That turn needs all of the ignition you can get.
Post by: Tim Wescott on January 04, 2019, 09:56:29 AM
Hot vs. cold refers to the length of the path that heat has to take to cool the plug element (more properly, I suspect, it refers to how much thermal resistance there is from element to frame).  A hot plug is one that conducts less heat away from the plug element, a cool plug conducts more.
This is the same rule for automotive spark plugs, BTW.
Post by: EricV on January 04, 2019, 11:38:16 AM
Since there is no electronic ignition in our little 2 cycles, I've always had a belief that the glow plug depth and heat range acted to either advance or retard the ignition timing, just like turning your distributor used to on your old car back in the day. Or if you ever played with a little model external combustion engine, and let the flame get closer and further away, you get the idea.
Compression is the other factor that effects ignition timing, higher compression advances the timing of the boom... so the longer plug not only puts the heat closer to the fuel and compression center, it also takes up a non-insignificant area of the chamber, also raising compression a tad.
In a car, advancing the timing always gave more instant throttle response, retarding the timing killed your low end torque, but gave much better fuel economy, that is why Mallory had the mechanical advance dual point, then vacuum advance came out, then MSD and Electronic ignition, to allow having the best of both worlds with a hot spark and variable timing.
I've always felt you should run the plug that lets you run the fuel you want in order to get the run you want. Oil raises compression too in our motors... but with modern engines, I don't need as much and it kills fuel economy. I don't want to HAVE to run 15% or 20% nitro in my engines, so I run enough compression and mostly synth oil to work with the range I like, 7% to 10% most normal conditions, and 5% for King Orange weather. I can pretty much run 7% year round by switching between an Enya #3 & Enya #4 in cool and hot weather, only needing 10% like at Muncie in July heat or similar days in Florida.
I did some experimenting a while back for a friend and I made a simple tool for measuring glow plug depth, because he was getting flame-outs, and we found we could minimize his particular issue with a particular plug that reached deep into the chamber and protected the element (and Arden hose nose Hot I think? I forget the model number)
But after all that, for me personally, it boiled down to me pretty much running the box stock setup that Randy has recommended from the beginning of time... 5% to 10% nitro range, mostly synth with a bit of castor fuel, Enya #3 or #4, depending on the weather, set the pipe by the chart, pitch the prop until it works, then forget about ever touching it again and go fly.
EricV
Post by: frank williams on January 04, 2019, 12:40:59 PM
  D>K
But I am not actually sure where this thread is going, or why.   D>K
Anyone have any thoughts on measuring the “hotness” or “coldness” of a glow plug?  I would sure like to see a quantitative assessment of current glow plugs.
Is there some way to quantitatively measure which plug is "hotter" than another, as opposed to just reading the label on the package and believing it, or flying them all and making a personal assessment of how it performed.
Post by: Howard Rush on January 04, 2019, 01:59:48 PM
This is a cool project. I like the idea of measuring filament temperature by measuring resistance. Then I guess you could determine catalytic effect as a function of filament temperature and area. Would you want to do the measurement in a running engine, rather than in a flagon of methanol vapor?
If you like, I can probably make you a circuit to measure plug resistance.
I don’t know if filament temperature would suffice to determine plug hotness. Both making the filament more available to the fuel mixture by lowering the plug and making it less available by shielding it (and increasing its temperature) seem to make the plug “hotter “.  Maybe you need to measure ignition advance more directly, as I think Eric suggests. How about putting a pressure sensor in the head and comparing pressure to shaft position on a sillyscope?
Any measurements in a running engine would probably be a strong function of needle valve setting. The upchuck of your experiment could be a thing that enables you to set the needle valve by plug resistance, rather than RPM.
Post by: Tim Wescott on January 04, 2019, 02:27:19 PM
Measuring temperature by resistance should be OK-ish, although it presents all sorts of practical difficulties.  You may need to calibrate the resistance vs. temperature curves differently for different plugs -- I'm not sure how much that'll change with different alloys.  Some sort of take on a PTC circuit should work, although you're starting at a much lower resistance.
Rather than a pressure sensor in the head, you may be able to determine the moment of firing with a ping sensor from a car -- assuming that such things aren't larger than one of our engines.  You could correlate that with engine angle using a magnet in the spinner and a hall-effect sensor.
Post by: Istvan Travnik on January 04, 2019, 04:51:12 PM
Dear Friends,
I do not want to write too much "offtopic" things, but I think the final goal is to better handle the ignition features of our glowplug engines.
Well, not the plug is "everything" in this battle, but many other tiny elements in and around the combustion chamber and cylinder head.
Maybe most of you have  seen "RETRO 60" engine combustion chamber, with that titanium "deflector" or "fender" close to the plug, shading it partially, and glowing dark red during the working time of engine.
Upon this idea I made several inserts into combustion chamber (different material and shape), and I was able to adjust very precisely the ignition features of my engine (MOKI-51, Schneurle, plain piston). I use it for at least 5-6 years. Summarizing, all my glowplug troubles ended forever.
Upon your request I can load up some photos.
Maybe here, or shall I start a different topic about?
Istvan
Post by: Dan McEntee on January 04, 2019, 05:40:34 PM
Dear Friends,
Istvan
      This would be good to see, and not off topic at all I think. Photos would be most informative, and I don't think I have ever seen what you are referring to. It gets my vote.
Post by: frank williams on January 04, 2019, 06:28:13 PM
Istvan
I would very much like to see your photos.  I had heard that different metals (iron for one) in the combustion chamber could effect engine performance by reacting with the methanol vapors.  This was why I never felt that helicoils in the head were a good thing to be doing.
Howard
This could turn into something that might be Scott Bair worthy  He had the only model engine pressure traces that I have ever seen.  For sure some type of bridge would be needed to measure changes in plug resistance.
Post by: Reptoid on January 04, 2019, 08:34:35 PM
This is accurate for spark plugs and affects the heat range greatly.
The cooling path has a much smaller effect on the heat range of a glow plug in a Methanol fuel based glow engine. There are many factors that are indeed hard to measure that affect this; Wire diameter, # of coils, diameter of coil winding, depth of coils in plug body, diameter of hole in plug body, alloy composition of element wire, total surface area of wire, total volume of wire chamber, alloy composition of glow plug stem, and even the color of the glow plug body.
Post by: RandySmith on January 05, 2019, 11:55:36 AM
As mentioned  3 things in general affect heat range
Size of the hole the element sits in
The formula of the wire, ie 30% rhodium wire runs hotter than 20% does
the diameter of the wire
Also the  depth as Frank mentioned has many times ,a good effect, sometimes not
Very thick shims will make them normally run cooler, very thin washers and they will run hotter, or cleaner
I have bought and ran almost all plugs over the years, and tried them in stunt runs, most as as labeled and the companies that make them really do know  hot from cold
A list of them , that are hot and work well for stunt is, and in no particular order :
Glow Bee  Rc long
Glow devil #300 rc long
Enya #3  #4
Merlin 2005
Merlin 2004
Thunder Bolt 4 cycle    ( 20% rhodium)
Thunder Bolt BIg Bore  2  and  4 cycle (30% Rhodium)
Thunder bolt #3 good for  wet 2 cycle runs
McCoy MC55
McCoy MC 59
OS A3   #8
OS type F
Rossi RC Hot
Rossi #1
Rossi #2
Thunder Bolt RC Long
SIG  RC long
OS LC 3
OS #8  is  medium and works well for engines running a hotter  wet 2 cycle
Fireball  HOT plugs are  good  IF you can find ones with good seal, They are mostly BAD on sealing plugs, and  most I have tried Still leak
On Engines I setup, I normally machine a  "heat dam" around  the glow plug,  this makes the glow plug  retain much more heat than normal. Works well  to keep the engine running cleaner, and allows still full use of fins  to help cool the head and engine as much as possible.
Strange looking but in cold winter months I have turned the  loop charge motors head, sideways, so the fins are not as efficent, helps keep heat in the plug too, I do not recommend this  , but it works.
I will add more if I remember them, I did not add  FOX plugs
Post by: Istvan Travnik on January 05, 2019, 02:30:40 PM
Dear Dan and Frank, & Friends,
here are some quick photos on the deflectors (one old, used, one new, unused).
Instead of telling a long-long story, finally I found that aluminum piston engines are too cold inside to achieve the proper behaviour (quick and safe change towards-backwards between 4 and 2 cycles).
With these tiny pieces I can keep temperature high enough in the combustion chamber.
I wanted to keep power high enough, too. I fly now with Xoar 13X6 electric. Engine is .51 . I think it is o.k.
Special bonus: one plug lasts at least for 300 flights.
Post by: frank williams on January 05, 2019, 07:02:10 PM
Istvan
Thanks for sharing the info ....
Are the deflector discs aluminum, titanium, steel or other material?
Does the disc function to "hold heat" in the combustion chamber as well as blocking the plug element from incoming raw fuel?.  The holes in the disk allow for circulation of the charge and sizing of the thermal area for the disc, I assume.
Frank
Post by: Lauri Malila on January 06, 2019, 02:19:12 AM
I use a titanium umbrella. I tried stainless steel but iit won't last very long. Next material to try is zirkonium.
Lauri
Post by: frank williams on January 06, 2019, 08:26:39 AM
Lauri
Beautiful work ...
... can you describe to me the engine run anomaly that the umbrella fixes?
... how is the umbrella attached to the head material?
Frank
Post by: Garf on January 06, 2019, 08:46:29 AM
Maybe this will help.
Post by: frank williams on January 06, 2019, 09:31:38 AM
Garf
Very interesting ..... all a bit different .... Thanks for the pictures ..... how many thumbs did you grind off getting these sectioned?
Frank
The Nelson plug I assume is bigger diameter than the rc car "turbo plugs"  both utilizing a pipe thread seal to improve performance.
At a Nats back in the 80's I got hold of a special head for the Nelson 15 Goodyear motor.  I think it was probably the year before he came out with the plug.  The special head was the same combustion chamber and all dimensions the same except that the drill for the 10-32 tap of the glow plug hole was undersized.  This made for a head that you could not screw the plug in by hand.  It was too tight.  You had to use a plug wrench to get the plug into the head.  That simple change was a 500 rpm max rpm increase.  This took me about 15 minutes to accomplish to r and r the head, so there was no guessing at the experiment.  Obviously ultimate power was being lost through the threads of the head/plug.
Which leads me to .... has anyone in stunt made a head that will accept a "turbo style" plug.  Since the turbo plug is slightly bigger diameter ... could a regular head be retrofitted by drilling and making a seat for the new plug?
The "seat" of the Nelson plug is where the increased performance comes from ... true not a one to one comparison, stunt to speed or racing, but neither want a source of power loss.
Post by: Dave Hull on January 06, 2019, 10:05:10 AM
Frank,
And before someone starts to say that the 500 rpm was due to different heat flux between the nelson plug and the head, I would note that we have found a similar performance change when changing from a head that loosely fit the liner, vs one that was a very snug---but non-distorting---fit.
Randy,
No need to rotate the head to reduce the convective heat transfer on a cold day. On a profile, just slip O-rings over the cylinder fins. Keep adding until you get the thermal control you are after. On a cowled engine, just partially tape over the air inlet. Blenderm tape works nicely. Leave the engine together and happy....
Post by: Brett Buck on January 06, 2019, 10:22:54 AM
Beautiful work ...
  The same one you found and fixed by mounting the ST60 with the cylinder inboard, I think - he fixes it at the business end rather than preventing it from happening at all. The Discovery-Retro has something similar.
Post by: Brett Buck on January 06, 2019, 10:24:38 AM
  Stainless steel doesn't last? Why, fatigue? If so, zirconium isn't likely to be any better.
Post by: Lauri Malila on January 06, 2019, 10:28:07 AM
Frank,
I don't know exactly which mechanism is dominant, but the umbrella somehow keeps burning process more stable, by either pre-heating the mixture before full combustion or just shading the plug from cooling fuel mixture.
Whatever it does, it effectively removes the hysteric behaviour from 4-stroke in beginning of maneuvre and especially after it. 4-stroke mode is inherently unstable and pretty sensitive to temperature variations.
My engine does not do much 4-2-4 shift, but rpm changes from 4-stroke to maximum in more linear way. At the moment I'm working on a baffle-piston version that should behave more in a classical 4-2-4 way, so propably I'll get more clear test results between umbrella- and no umbrella heads.
The umbrella is pressed to #2024 aluminium head *very* tightly, with 0,1mm interference fit (2,00mm dia pin to 1,90mm hole, 4mm deep.
Lauri
Post by: Lauri Malila on January 06, 2019, 10:40:30 AM
Brett,
The stainless steel (316-something) started peeling or corroding after a few dozen flights so I abandoned it.
Zirconium is interesting because when heated in a flame, it forms an extremely hard and slippery oxide layer. If it stays like that in combustion chamber, it may stay cleaner from carbon buildup.
(Zirkonium is also funny because when titanium shavings have a risk of combusting during machining, zirconium does not have a risk. It WILL combust.) L
Post by: Dan McEntee on January 06, 2019, 10:55:49 AM
     Randy Smith,
    "On Engines I setup, I normally machine a  "heat dam" around  the glow plug,  this makes the glow plug  retain much more heat than normal. Works well  to keep the engine running cleaner, and allows still full use of fins  to help cool the head and engine as much as possible."
     Hi Randy;
  Just to clarify, this is opposite of what it sounds like? You just remove material to reduce the heat sink properties of the aluminum? The words "heat dam" implies that something is added or built up like a literal dam to hold heat in.  I have heard of turning the head a bit or 90 degrees before, just have never felt the need to try it. In cold weather I'm usually just trying to keep it out of the dirt and don't pay real close attention to the engine run! Just get it up and down!
Post by: Lauri Malila on January 06, 2019, 11:01:28 AM
Dan,
Just look at the last photo on my post (#20), that's a heat dam. I just did not mill it all the way around, had to leave some material where to press the umbrella. I usually do it with 2mm milling cutter, leaving 1..1,5mm material between groove bottom and top of combustion chamber. L
Post by: Brett Buck on January 06, 2019, 11:37:11 AM
   That's remarkable! I am stunned that anything going on in the very mild conditions of a model engine, with very mild solvents and relatively low temperatures, would have significant corrosion issues. We use stainless immersed in very strong acids and moderately high temperatures for decades with only mild leaching of ferrous metals from the matrix. Titanium does handle it better, but stainless is OK for at least many months/year. And I would expect 316 to be a good choice.
   Let me ask this - is this happening after a few flying sessions (run, put away for a week, run some more, fail)? Or is it simply due to working (fails or degenerates in a single session)?   What sort of passivation or pickling are you using (if any)?  Where does it fail/peel - on the "struts" or on the "umbrella" end?
     I ask because the only way I can see this happening is that the passive layer that normally forms is getting mechanically damaged somehow (fatigue on the "struts" from the vibration and flexing), and is then prevented from re-forming by the oil. It might be improved by reducing the thickness/mass of the "umbrella", reducing the flex and raising the frequency. If it is there to just block the charge from going straight to the plug,  or some internal ballistics effect, the mass shouldn't matter.
    If it functions by creating a heat reservoir, titanium (and maybe zirconium) might not work the same way. It's not obvious whether the relatively poor thermal conductivity of titanium would hurt or help. I presume neither because I think the action is the blocking action (like a super-duper idle bar). I would remove it and try a "hose-nose" plug, myself.
   Fascinating issue, and not what I would have expected.
Post by: frank williams on January 06, 2019, 12:42:48 PM
Just to confuse things a little ..... after watching the platinum wire glow in the video above ... just in the presence of the alcohol vapor ......
..... I hooked an old glow plug with jumpers to a voltmeter ..... I then took a propane torch and briefly heated the glowplog element ... it just took a second to make it glow ......
..... sure enough,   "wait for it" , a voltage was produced (~ a milli volt or so) no battery involved .... some kind of thermoelectric reaction .... interesting, ... very interesting .....
Frank
Post by: Howard Rush on January 06, 2019, 01:16:40 PM
Frank
That would mess up any resistance measurement I could do.
Post by: Istvan Travnik on January 06, 2019, 01:24:35 PM
Uhh,
I think this deflector-story is more interesting, than I expected.
Well, in the ancient times, some good old (and lazy-to-think) friends of mine made me calm: "Schneurle engines are not for stunt, only baffled pistons are...") .
In my praxis the normal steel deflector had been burn in half, after ca. one hundred flights. (Central part became half thick of that I made it.)
I had no problems with aluminum alloy (former Hungarian coins), and no problems with stainless steel, too.
My basic idea was interchangeability (even on flying site), and playing with the shape, mostly with the width of three "bridges", which are conducting the  heat from the center part to the cylinderhead.
Post by: Dan McEntee on January 06, 2019, 01:26:09 PM
   This is an interesting thread. I had never heard of this before and had no idea anyone was using this technology. It makes me ask one question, though. I have used idle bar plugs, (mainly Glow Devil R/C longs) for quite a while, because they seem to run much better and last a lot longer. No real scientific proof, just from my experience. The idle bar is a spot welded on piece of, I assume, steel? It just seems to turn black with carbon over time. My reasoning for using these also included the idea that the idle bar gave carbon and other junk a place to call home, instead of fouling the element. Is it possible that the idle bar is have the same effect as the umbrella and such? Not to the same extent, certainly, but since it is located where it is during the running cycle, and my experience that my engines just "seem" to run better, could that little improvement be from this effect?
Post by: Istvan Travnik on January 06, 2019, 01:33:05 PM
Dear Dan,
I think, that opinion is right which says that the main destructive effect against the coil is some supersonic shockwave which starts from top of the piston. When we shade the coil, this shockwave cannot destroy it too soon.
Since I have no neutrographic microscope (only nuclear laboratories have that) I cannot say "yes" or "no" to this idea but I near to afford it...
Post by: Brett Buck on January 06, 2019, 03:01:00 PM
I m well and truly amazed - if the steel "umbrella" wears away, and aluminum does not,  that certainly does suggest some sort of chemical process.
   Another thing I am amazed about - we have been running schnuerle engines with completely conventional squish band heads, no idle bars, or nothing at all in the head for about 20 years now. We have had exactly one minor problem that we could not solve with external (i.e. setup, venturi type, and oil contest) factors, that having been later completely solved, perhaps by accident, by a proprietary method that has *nothing* to do with the glow head end of the system. My engine will grind through 100 patterns of a row with it set to never touch a 2-stroke with no "anomalies* if I set it that way. And I have had that work that way on three individual engines, two of which are identical and the third very close but with a 4 degree difference in the exhaust duration. They run slightly differently but nothing that suggests I need to cover the plug up.
  So the question becomes ( and I am not saying you guys are wrong, I presume you know what you need to do and have solved the problems) - why is it so different?
   There are at least major three differences:
       We run at generally higher RPM and power levels, and I presume much cooler
      We run at much lower compression ratios (enabled/required by copious amounts of nitro...)
      We have pipe regulation
and one perhaps minor difference - our engines are run with the cylinder down instead of to the side. It runs about the same on it's side, so I discount it.
p.s. are you sure there isn't something else in the fuel beyond just methanol and castor oil? Some sort of chlorine-containing chemical, maybe in the oil or other additives?   I have some experience running items (model airplane engines and otherwise) with non-AMA-approved fuel constituents, also with no ill effects, aside from chlorinated solvents which screwed everything up in short order.
Post by: Istvan Travnik on January 06, 2019, 03:36:26 PM
Dear Brett,
I cannot tell you anything else:
as I tried first pure normalsteel deflector, after aluminum ones (hoping a little bit higher temperature, by worse heat conducting by "bridges",
at the end of flying season I disassembeld, and started to clean the middle part from residue of oil (I don't use Castor, it was some PAG-based).
And after scratching off that black, carbonized coat, I found typical brown iron oxide - Fe2O3 or Fe3O4...
When it was cleaned too, the steel was half thick than original.
Stainless steel deflector cannot get oxidized (my deflectors are 1.00 millimeter thick exactly.)
About Schneurle story of my engines: this is too long, I fly with normal silencer, no pipe.
Istvan
Post by: Brett Buck on January 06, 2019, 03:44:21 PM
Dear Brett,
I cannot tell you any thing else:
at hte end of season I disassembeld, and started to clean the middle part from residue of oil (I don't use Castor, it was some PAG-based).
  Remarkable! You have to be burning the fuel at much, much higher temperatures that we are. I wonder if you are getting *water* in your fuel, specifically, if there is water from the "oil", since it's either water-soluble or at least has an affinity for water. That and the very high temperatures, maybe that is enough.
    I would be curious if the same thing happens if you use castor, or mineral-based synthetic, instead of glycol-based.
Post by: frank williams on January 06, 2019, 04:15:38 PM
Well .....
... at least one of the elephants in the room is ...
... if platinum is good .... why doesn't just a two plug head solve all problems?
Frank
Post by: Istvan Travnik on January 06, 2019, 04:29:02 PM
Dear Brett,
I think this question (about possible water appearance) was solved now automatically: I will bind myself to use MOTUL Micro 2T, nothing else. As I know this is Ester -based, and a little bit more heat resistant than PAG oils.
I won't return to castor, since it is a great effort/pain to make silencers by myself, and I am up to throat cleaning them after castor.
Dear Frank,
In the ancient times Merco (from the UK) made very impressive looking double plugged engines (maybe .35 and .50), without remarkable success in C/L stunt...
Post by: RandySmith on January 06, 2019, 10:04:38 PM
Frank,
Randy,
Hi Dave
I have done that too, however turning the head  was quick and easy, especially if you do not have the right size O rings,  Both work OK , You can also use a slice of beer can  and 2 pieces of copper wire
Regards
Post by: RandySmith on January 06, 2019, 10:12:01 PM
     Randy Smith,
     Hi Randy;
Dan
Yes  the  aluminum is  removed from around the outside of the glow plug head area,   so it now  filled with  air, instead  of solid aluminum, which pulls heat from the plug, The  removal of the  metal  makes the plug run hotter.
LOL if you really want a "hot" chamber, machine a head button out of a ceramic material, ..extreme heat increase.
Post by: Dave Hull on January 06, 2019, 10:52:12 PM
I didn't have much luck with MACOR ceramic parts. Not sure our machinists had the knack for it. The parts were very fracture sensitive--and thus not usable. But they would have been excellent thermal isolators....
The theoreticians get worked up periodically about building IC engines with a ceramic block and top end. They envision running much, much hotter and benefiting from the thermal efficiency. And yet we still have aluminum and cast iron....
I haven't had to resort to the beer can and wire thermal shield yet. The O-rings are practically de rigueur on F2CN diesels, which suffer greatly from not being cowled, and thus are very difficult to get hot enough to hold a setting. I would note though, that the earlier Nelson 15 diesels with the old metals technologies would hold a setting and perk along perfectly. In contrast, the AAC versions are a battle. For glow, about the coldest weather I've flown in was about 50F, and no real changes were required.
Post by: Lauri Malila on January 06, 2019, 11:44:35 PM
Well .....
Frank
..something like this, Frank..? L
Post by: Chuck_Smith on January 07, 2019, 04:57:39 AM
Interesting. We use ceramic coatings and parts on race car engines, but for different reasons. Mostly we're trying to keep the heat from moving from the top to the bottom or radiating to the CF matrix of the surrounding parts and softening them. This of course causes overheating issues on the top end - leading high cooling flows - leading to the use of mechanical seals - leading to -, you get the picture. It's the old trade-off, by the time you add the required extra parts and parasitic losses to the system to make the new parts work it may be a giant step backwards.
One of the Formula 1 teams we worked with tried to use neodymium in place of samarium cobalt in the ERS system for it's higher magnetic strength, but since the neo doesn't hold it's properties to as high a temp as SmCo they encountered crippling issues that made them uncompetitive and unreliable. So a classic case of where the "better" material doesn't always yield superior results.
Chuck
Post by: Istvan Travnik on January 07, 2019, 05:12:56 AM
Beautiful work, Lauri!
Have you try to mount on this cylinderhead in different positions? If yes, which one was better?
Istvan
Post by: frank williams on January 07, 2019, 07:08:41 AM
Lauri
I agree ..... beautiful work ....
US stunt flyers would rather "eat worms" than run an engine in any other configuration than cylinder down, although it works better in a sidewinder mode.
Frank
Post by: john e. holliday on January 07, 2019, 09:10:44 AM
Especially if the head of the cylinder is pointed towards the pilot. S?P
Post by: frank williams on January 07, 2019, 09:19:14 AM
Doc
Sidewinder is kinda like belly buttons ..... you got your innies and your outties ....
Post by: Lauri Malila on January 07, 2019, 10:34:52 AM
Istvan
Hi Istvan,
If you mean rotating the head in cylinder, then yes. Both by accident and from curiosity.
The wide squish band is supposed to be in rear of cylinder, meaning on exhaust side.
Anything else gives inferior results.
Or do you mean rotating the whole engine around shaft axis? Yes too, 40..45 degrees down from horizontal (cylinder) gives best result; perfect running symmetry. L
Post by: Istvan Travnik on January 07, 2019, 03:28:25 PM
Well,
The (outwards) laying engine gives an unbeatable advantage: the hole on the spraybar (or end of the carburettor nozzle) is at least 1/2 inch outer position than normal inverted, or standing arrangements. By my engines this is more: ca. 20 millimeters (4/5 inches).
Who is ready to make 2 x 1/2 or 2 x 4/5 inches wider fuselage to achieve this???  :)
Post by: Istvan Travnik on January 07, 2019, 03:32:45 PM
Dear Lauri,
Sorry fo that my question was not clear enough: I asked only the cylinderhead position in the cylinder, but you answered already, thanks!
Post by: M Spencer on January 07, 2019, 05:29:34 PM
Seeing stainless steel , theres heat resistant grades . some are useless for exhausts , See some info here , https://www.maperformance.com/blogs/maperformance-blog/77005123-409-and-304-stainless-steel-bet-you-didnt-know-these-details
Likely ' sucking eggs ' for these blokes , but w t h .
also , the spark plug bit , ' Protrudeing nose ' are anti fouling , bit like the four stroke glow plugs . But unsuitable for W F O use , as the nose melts , along with pistons & other bits .
The Lew Woolard Fox 40 set up , has a max. plug to piston dimension . Someone mentioned somesuch earlier .
Post by: Dave Hull on January 08, 2019, 02:16:25 AM
I believe I have related this story before...but some may find it relevant here.
We were testing a .15 powered Goodyear. A local flyer, who is a hard-core stunt guy came over to look. We were kicking around performance ideas and he suggested we try one of his "modified" glow plugs. He described rebuilding the plug with two separate elements to it. Only one was connected to the terminals for starting. The other was more of a flat GlowBee coil (or possibly a grid?) right at the face of the plug, if I recall correctly. My racing partner and mechanic was gung ho to try it out. Why not, it was my engine, not his!  So we connected the battery and it fired right up. After only a few seconds of running, there was a horrible, much lower pitched exhaust noise and we tried to shut it down immediately.
As best as I can figure, once the engine got going the combustion process activated the more exposed element. Since it was further into the combustion chamber--and was adding more heat-- it must have advanced the timing. The engine was already running at near peak and it was suddenly subjected to a radical amount of pre-ignition.
There are several things to learn here, but the one takeaway I won't forget is don't do experiments on your best engine. Even if your mechanic is elbowing you out of the way to get his hands on it. Always try it out on a mule first....  And preferably, his mule.
Divot McSlow
Post by: John Mechura on January 08, 2019, 07:53:07 AM
Greetings, Salutations and all that Rot,
My first post here, so here goes...   H^^
Platinum, rhodium and other dis-similar metals made me think that a glow plug may have characteristics of a thermo-couple.  So I got out my Fluke(R) multimeter that has thermocouple reading capability.  I was pleasantly surprised to see that the temperature readings of several assorted glow plugs was around 69*F at room temperature.  Heating it up with a match increased the temperature displayed, and letting it cool off decreased it back to room temperature.
Unfortunately it was not a "perfect" thermocouple.  When heated up to be uncomfortable to hold in the fingers it registered around 80-82*F.
Later this week I may fire up a nasty .35 Stunt on a test stand.  At such time I will repeat my test and report my observations on the running engine.
The pros are that across several different makes of plugs the room temperature was fairly consistent.
The con is that I have not tested it in a running engine and there may also be something that I have overlooked such as the composition of my test probes may be affecting the tiny voltage reading.
I shall report back later this week.  I may be "full of it" on this issue but it seems possible so far.
Post by: Brett Buck on January 08, 2019, 11:07:58 AM
Well,
   And why would you bother, when the problem is effectively solved (to the degree necessary) with completely conventional means and inverted mount?
    Don't get me wrong, I am impressed and fascinated with with your efforts, results,  and your machine shop capabilities, and what you and Lauri are doing is very interesting. You don't have appearance points to worry about, either.  But we haven't had these sorts of run asymmetry issues for a long time now, 15+ years in my case, and to be honest, it worked well enough in 1990 with a $200 production engine straight off an assembly line, if you set it up correctly. And I am particularly picky about it.
I see two differences - you (apparently) run at extremely low RPM, and don't use nitro. We use no plug shields, micron-fit piston rings, heat reservoirs, etc. We have completely conventional squish band/semi-hemi heads, glow plugs that used to cost 79 cents.  As far as I can tell, there are three relevant issues:
   proper carburetion/mixing (solved by spigot venturi and diffusers, perhaps by Belko's (effectively) plenum, too)
   reduced fuel system flow resistance
   internal gas dynamics around the ports and bypasses
   I would note that I didn't discover #1 and #3 (which were at least first described in print by Frank Williams), and # 2 used to be mentioned in the Fox 35 instruction sheet! I just call up and order them from the manufacturer, anyone else could get the same thing. The only real cost I see is the heroic fuel consumption (6.7 ounces of 10% for the little 61, and 8.5+ for the 75), you definitely have that beat.
   Note that I didn't mention pipe regulation, it resolves *other* issues like allowing you to run a superior prop as a more beneficial RPM, but I don't think it matters to this particular problem. I don't know for sure why anyone wants to run it at 8000 rpm with 6" of pitch, that is a different albatross. Maybe trying to run 60s-91s (10-15CC) engines, capable of maybe 7-8 HP in ideal conditions, at 1/2 horse, is a problem. It's not a problem for me, I am probably running 3/4 horse or so, 50% more, but still nothing compared to what it could do if pushed.
    I would note that we had these sorts of problems, and they drove us absolutely crazy, about 20 years ago, so I get the motivation  - it makes it much harder to fly stunt when the engine is changing all over the place. David, Ted, and I (and to a lesser extent, Paul Walker, I think) got on several engine manufacturer's semi-permanent poo-poo lists over the topic, and I got a particularly histrionic rant about it in person at the 2002 NATs, from someone whose engine screeched into a squeaky lean 2-stroke in every outside turn.
    So please don't interpret this as a criticism, I get why you want to solve it. But I just don't quite get the elaborate lengths and highly unconventional solutions to what we managed a long time ago with pretty ordinary (by comparison) approaches.
Post by: Lauri Malila on January 08, 2019, 12:19:07 PM
Brett,
There is so many ways to spend time with this hobby, you know :)
I know you don’t give negative criticism, and even if somebody does, I don’t really care. I do this (but I think I’ll fail to explain it fully) because: (not in any particular order)
-I’m obsessed with noise. Unfortunately your piped engines are too noisy for european scene, especially when we have to fly against electrics. I see the best potential in 7000...7500rpm range, it’s acoustically straightforward to handle and still does not require too big props that cause trimming issues.
-I find this mechanically and thermodynamically fascinating, and feel that I have something to prove. I’m quite lazy, and have found the best way to deal with it is to do every detail as well and correctly as possible. That way there is less surprises and waste of time. And I have nice tools and skills to use them, so why wouldn’t I?
I also have propably worlds best and most innovative engine people behind me, they find my ponderings equally interesting and help with things I can’t figure out by myself.
And I can guarantee that I don’t do things differently just for the sake of being different. I do it because I know that it’s a better way. I mean my sub-micron rings, integral AAC’s, diamond coatings etc. They all give a solid and super-stable foundation that makes it easier to focus on making the engine work as I want it to.
I think structurally our engine is as good as it can get, I can start focusing on scavenging now. But it takes some time as I’m quite slow.
And as I must drive nearly 200km/direction to practise, I have more time to think and make chips that fly. And if I compare my minimal practise with contest results, twice in row in top 20 of world champs, most of the credit goes to the engine. I’m especially happy with its performance in difficult conditions of France, where the technology that you represent was in trouble. And with no nitro!
I don’t understand your argument about appearance points. Are the models supposed to look like real airplanes or are they looking at workmanship only? L
Post by: Istvan Travnik on January 08, 2019, 03:41:24 PM
Dear Brett,
I am a little bit confused: your anwser seemed to be addressed either me, or Lauri.
Well, Lauri has absolute superior workshop, precisity and comrades (maybe he tell the names), while I have not.
I want to simply enjoy my sport/hobby, as I do it for right half a century.
Sometimes I faced with problems, and that moment I think to myself: "Why I follow the conventional way? Who pays to me to be a goodboy, instead of being a thinking, innovative engineer, as I am? ".
To solve vibration tragedies I worked out my "bluefoam model", to solve engine asimmetries came the laying/slope engine, to keep the model's nose somehow goodlooking, came the the "backwards spinning" silencer below the engine, etc. etc.
If somebody grants me some personal attention, that is my special bonus :)
Istvan
Post by: M Spencer on January 08, 2019, 08:58:18 PM
(https://assets.gocomics.com/assets/apollo-ebf32ed2ad66d0bfcf986c7715ab786480b76efe646a63523fce276ad9264531.js?sampling=100)
Post by: M Spencer on January 08, 2019, 09:01:42 PM
No offence intended . Just a a slight typo . Nevertheless . . . .
(https://image.ibb.co/dhnUvb/potatochipfly.gif)
Deadly Serial now folks .
By the way , the ' FIREBALL ' Plug Seal , back in the 70's , the trick was on NEW Fireballs - to use Aryldite about the post / seal ,
applied with a toothpick . to anchor the post & support the ceramic insulator . on ' B ' team racers .
With the Plug Wire connection fitted , they were pron to blown / broken seals . This seemed to resolve that problem .
Post by: Brett Buck on January 08, 2019, 09:06:37 PM
  You will generally get more points if the engine is neatly cowled in, and using rear-exhaust engines with inverted mounts is a very neat way to do it, and engines hanging out the side are not as neat.
    Again, I am not taking pot-shots at what you are doing, but you will have a heck of a time competing with electric if you are running 7000 rpm and the associated 7.5" of pitch, almost no matter how you go about it. That will require something extraordinary, engines that predict the future...
   I am very impressed with your skills and what you are doing, but as you say, you can certainly partake of stunt however you want, far be it for me to say otherwise. If it's fun, please proceed!  I am trying to inquire so I learn something.
   I am still mystified at how you corrode stainless steel in a model engine.
Post by: M Spencer on January 08, 2019, 09:12:45 PM
To evaluate the effect of heat treatment on the cavitation erosion resistance of stainless steel, an experimental investigation is carried out using a cavitating jet test apparatus complying with the ASTM G134 standard. The jet pressure is 30 MPa and the cavitation number is 0.014. Specimens made of stainless steel SUS630 are aged at different temperatures. Prior to cavitation erosion experiment, the mechanical properties of the specimens are obtained through an inverse analysis method in conjunction with the indentation test. The material's cavitation erosion resistance is represented by the reciprocal of the maximum cumulative mass loss rate. The correlation between cavitation erosion resistance and mechanical parameters is pursued. The variation of cumulative mass loss with the exposure time under cavitating jet impact demonstrates that the rise of aging temperature impairs the cavitation erosion resistance of SUS630. The overall cumulative mass loss rate of SUS630 is lower than that of SUS316L. The correlations between cavitation erosion resistance and mechanical parameters are evident. The parameter of microhardness exhibits the most explicit relevance with respect to the cavitation erosion resistance.
Post by: Dave Hull on January 09, 2019, 04:45:57 PM
Plug elements have variously been reported as platinum, or tungsten that is plated, or contain some rhodium, or.....
Unless rhodium, even in small alloying amounts, would significantly improve the plug performance, I really doubt anyone is using it. It is about 3 times the cost of platinum currently, and about twice the cost of gold. (Strange, I thought platinum was more expensive than gold...?)
Twenty inches of .008" platinum wire is going for about $110, retail, today.  (Sigma-Aldrich: medical grade)  The wire in a dissected OS A3 plug was 0.2 mm (~.0078") and as a guess about 0.7" to 0.8" long. It was also very ductile and "soft."  I doubt it had a tungsten core.
Does anyone know what is being used? I assume most plug makers would declare it proprietary to avoid discussions of whose plug is "better."
They almost certainly are buying the wire from a supplier--and possibly they are all using the same supplier.
Post by: Dan McEntee on January 09, 2019, 05:27:28 PM
    Does anyone remember Iskandar Taib? He was living in this country while going to school years ago and used to frequent the forums years ago. I hope I have his name right. he moved back home to the far east after completing his education and still posted on Stuka Stunt at least. he put out a call for people to donate glow plugs of any age and manufacture so he could analyze them for content and such, as they had the lab equipment where he was working to do that.. This was probably longer ago than I think, but I don't remember him ever posting that he got very far with it, but if he did, any results would sure add to this discussion. Just wondering out loud so to speak.
Post by: qaz049 on January 09, 2019, 09:13:53 PM
Iskandar moved  to Kuala Lumpur, Malaysia I believe. I exchanged messages with him last in 2014 or 15. He was still flying combat locally then. Occasionally posts in other forums, last one was May 2017.  Probably just inactive. I do have a contact channel.
Post by: qaz049 on January 09, 2019, 09:32:02 PM
He did, but on another forum. The details are buried in this discussion.
http://www.rcuniverse.com/forum/glow-engines-114/10626380-glow-plug-patents-design-2.html
Post by: Garf on January 10, 2019, 03:59:20 PM
Garf
Frank
I did not do the butchering. I stole the picture.
Post by: Fredvon4 on January 11, 2019, 12:46:28 PM
I cannot LOG into my Yahoo account...but I still get Combat Group E-mails...Iskandar Taib is still member and still active as of last week
I already deleted the thread so can not provide a back channel e-mail to Iskandar Taib
Post by: Steve Helmick on January 11, 2019, 04:03:09 PM
Back in the '60's, there was a sudden drop in the price of glowplugs, from nearly $2 down to 49 cents or so. I recall some speculation that they were just using iron wire instead of platinum/rhodium/iridium alloy.
My thought was to contact Ohlsson Corporation and ask for any information they are willing to share. It's too bad the guy at Merlin died, because he apparently manufactured his own glowplugs. I don't know about McCoy glowplugs, but Ohlsson Corp. makes so many brands (K&B and Thunderbolt for sure), that it would seem possible they make at least some of the other brands. No? Si? Anybody really know who makes their own and whose are made by somebody else? The only ones I'm against (now that Fox has folded) are Fireballs...bad seals way back in the '60's, but I don't know about current designs. Maybe they're ok now? I am a fanboy of Thunderbolts, for sure.  D>K Steve
Post by: Brian Hampton on January 11, 2019, 04:28:45 PM
Early Enya's #1 and #2 used nichrome coils but switched to platinum alloy with the #3.
Post by: Dan McEntee on January 11, 2019, 06:19:24 PM
     I'm no chemist, but I do not believe that nickle/chromium wire would react with the alcohol in fuel? I have never heard nor read that anywhere before.
Post by: qaz049 on January 11, 2019, 06:36:54 PM
The Enya plugs were possibly Nichrome coated with Platinum. Both Nichrome and Copper will work as Catalysts with Methanol but are inferior to Platinum alloys. Plenty of evidence in the Chemical Literature.
It seems that Isky's work with the Spectroscope indicates that there are only a few different Platinum alloys used in commercial glowplugs, and that the composition of the former does (in some way) effect the degree of "hotness" or "coldness" of the plug.
Post by: Dave Hull on January 11, 2019, 06:50:38 PM
Netzeband, in his seminal September 1960 article, listed two early OS plug elements as "iron?".  He obviously suspected, but did not know that an iron element was being used. If we had one, just break off an element and give it the magnetic test.
I've never heard that iron was a catalyst for methanol, so I'm not sure how well it would work. It would depend completely on the heat from combustion and the mixture compression.
PS--Follow-up on resistance measurement discussion--
For it to behave like a thermocouple, you need a dissimilar metal junction. Using multiple junctions in reverse order might serve to cancel out the induced voltage? I never tried this; I always wanted the best calibrated single junction performance.
Post by: qaz049 on January 11, 2019, 07:03:23 PM
It may have been Ferrite, from the low carbon phase of the Iron/Carbon system (Fe with .008%C). It can be alloyed with Nickel and has Catalytic properties. It's mentioned in the chemical literature and I suspect that it's not magnetic.
Post by: Dave Hull on January 11, 2019, 10:04:05 PM
Qaz,
The use of ferrites/ferrocene looks like a fairly new use as a methanol catalyst. Probably not from pre-1960. Of course, more research might prove otherwise.
In the attached source, they do claim that the effectiveness of platinum, which is the highest of any single element, is improved by alloying with other elements. Hence, the platinum-iridium listed in the original Wild Bill article, and presumably the more recent use of rhodium, as well. I could not find anything that described quantitatively how much more effective, or if it was more effective at lower temperatures, which might help us--but not too low, I'd rather not have spontaneously starting engines.
From the abstract of the paper on catalysts for sensing applications by Donglin Zhang and Yijun Tang,
The key component in chemical sensing is the sensor which often relies on catalysts to oxidize methanol. The most effective catalyst is platinum [8-10], although non-platinum catalysts have also been reported [11-13]. The addition of some other transition metals such as gold, ruthenium, etc. enhances the catalytic ability of platinum [14-18]. The supporting materials for the catalysts are also important in designing new chemical sensors. Various materials have been reported for this purpose including newly-emerging materials such as conductive polymer and nanoscale materials [19,20]. Poly (vinylferrocene) or PVF, a conductive polymer, conducts electrons through successive redox processes or electron "hopping".
Post by: Brian Hampton on January 13, 2019, 04:08:09 PM
From Bob Allan's Enya Compendium
Glow Plugs
The earliest Enya glow plugs that we know of, appeared around the early to mid 1950’s, and were named “CAM-GLO”. These were the familiar Enya shape, and each individual plug came in a small box stating that – “A good engine requires & deserves a good glow plug”. It is not known if these plugs were made by, or for the Enya Company but also written on the plug box was “An “Enya” product “ and underneath, “The Camco Corporation”. These plugs were 2 volt maximum, as were the following (now simply branded as “The ENYA” ) No. 1 and 2.
These later plugs were manufactured by Enya in at least six different types, the very early No. 1 & 2 plugs had a nickel-chromium element (ni-chrome) for use with 2 volt wet cells, and identified by a black body with gold top. These plugs were sold in boxes of 10, the boxes being either red/white or red/yellow.
Post by: qaz049 on January 13, 2019, 07:34:25 PM
Glow Plugs
Brian, sounds reasonable.
