  • June 30, 2025, 01:19:15 PM
Author Topic: glow fuel tubing  (Read 816 times)
Offline Bootlegger
glow fuel tubing
« on: April 16, 2018, 01:35:48 PM »
  Fellows I am looking for some soft 3/32" I D fuel tubing similar to that came the Kraft Hayes tanks, the tanks are small so I need a tubing that will flex in a confined space.
  Any leads/help will be greatly appreciatedly...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline mike londke
Re: glow fuel tubing
« Reply #1 on: April 16, 2018, 01:37:23 PM »
McMaster Carr.
« Reply #2 on: April 16, 2018, 01:41:33 PM »
   I would strongly recommend Sullivan Pro-Flex - it is extremely flexible, almost as much as gum rubber, but doesn't *appear* to self-destruct like gum rubber. I caveat it because I haven't used it for long (since it hasn't existed for long) so I can't say for sure it is as durable as silicone.
Offline mike londke
« Reply #3 on: April 16, 2018, 01:47:51 PM »
Gil, I needed something similar to fit through a shut off bellcrank on a combat plane. From McMaster Carr I bought 2 kinds one clear and one white that are extremely flexible. I use them in Hayes tanks as well. Kind of a pain to get on a barb but it does work. I can send you some of each to try. PM me your address and I get it out to you tomorrow.
Offline Bootlegger
« Reply #4 on: April 16, 2018, 03:33:39 PM »
  Mike I sent ya' a P /M
Gil Causey
AMA# 6964
