  • July 04, 2025, 10:39:34 PM
Author Topic: Glow Clips  (Read 2587 times)
Offline Casey
Glow Clips
« on: August 23, 2017, 09:32:32 AM »
Hi Guys
Regarding glow plug clips, what are the pros and cons of a locking glow plug clip complete with a C or D battery versus a tweezer style glow plug clip
Offline Fredvon4
  • Central Texas
Re: Glow Clips
« Reply #1 on: August 23, 2017, 09:56:38 AM »
I personally am afraid for the self contained with battery lock on type after seeing one vibrate off get hit by prop and embed the tube in the cheek of a fellow starting his engine.... trip to hospitol
I only use lock on clip with cable, in my case a RCATS version   seldom used now is the Tweezer clip on from power panel
BUT Tweezer style also have risk, mostly managing the cable .......IMO tweezer style needs to be good quality and secure.. sloppy use can blow it off and puncture the wing skin ....or get wires caught in control surfaces or prop
The typical yellow plastic ones are junk IMO
Fred von Gortler IV
Offline Cody bishop
Re: Glow Clips
« Reply #2 on: August 23, 2017, 11:03:17 AM »
The best kind of glow plug clip is the one mbs model supply sells (ps when looking at it on there website the best way to find it is press the ordering button then select miscellaneous)
Re: Glow Clips
« Reply #3 on: August 23, 2017, 09:29:13 PM »
I recall being very reluctant to use "glow ignitor" type, but have only had one snafu (or was it a fubar?) with it. Couldn't get it off the inverted engine and finally fumbled it into the APC propeller, thanks to arthritis, etc. Helper tried to shut off the piped engine by turning the plane nose-down, which didn't work due to the clunk tank. But it made it convenient to put a thumb over the end of the rubber ducky. Which worked quickly, at the expense of a blister on my thumb (per Money For Nothin', Dire Straits). The rubber ducky had been shortened, making pinching it closed not much of an option. Better idea to leave it full length.  y1 Steve
Offline Casey
Re: Glow Clips
« Reply #4 on: August 26, 2017, 10:05:21 AM »
Thanks Guys
Re: Glow Clips
« Reply #5 on: August 26, 2017, 10:25:35 AM »
The type clip I use as it is easy to remove from engine with out touching it.   MBS Model Supply also sells these.
http://www.gpmd.com/imaget/s/tsulp2181.jpg
Offline Fredvon4
  • Central Texas
Re: Glow Clips
« Reply #6 on: August 26, 2017, 11:05:24 AM »
MY preferred is the more heavy duty Black versions
Fred von Gortler IV
Re: Glow Clips
« Reply #7 on: August 26, 2017, 04:55:29 PM »
Casey,
I have used the locking NiCad glow battery for over 20 years. This is the type that you push down and turn to secure it to the plug. I use the short length version. There is a wire version that I used for R/C on a power panel and still take to our December contest just in case we get into the 30's (the extra power, the 1.5 volts vs 1.2 NiCad, from the power panel give better starts in cooler weather). I fly OTS and have upright or profile engine mounts so removal is not an issue, even when I fly piped PA we stood up so there was no problem getting it off. I like to do a spinner flip start and can hold the plug driver since this method does not stress the fuse.
If you like the alligator  clip approach COX had a set up that held two "D" cells and the wires screwed on the ends. You might be able to find it on ebay.
Best,    DennisT
Re: Glow Clips
« Reply #8 on: August 28, 2017, 04:23:57 PM »
The best way to eliminate glow connector problems is just fly Old Time with ignition. LOL. Works for me. Now if my back would just cooperate.
Offline Phil Krankowski
Re: Glow Clips
« Reply #9 on: August 29, 2017, 03:57:52 PM »
Best,    DennisT
Both these places have that box with clip.
https://coxengines.ca/
http://www.exmodelengines.com/
Offline Larry Fernandez
Re: Glow Clips
« Reply #10 on: August 29, 2017, 04:53:49 PM »
These don't work very well with a fully cowlled in motor.
Larry, Buttafucco Stunt Team
Offline Steve Thomas
Re: Glow Clips
« Reply #11 on: August 30, 2017, 01:59:45 AM »
It's not hard to make your own remote connectors.  I use these 2.5 mm banana plugs, with the sockets epoxied into the engine bearers (and nowhere near the propeller). The plug clip is bent up from some thin piano wire - much less bulky and obtrusive than the commercial ones. So far, this has worked 100% for me on a couple of different models, and I'd happily do it this way every time.
Re: Glow Clips
« Reply #12 on: August 30, 2017, 10:31:13 AM »
That's a neat idea.   Gets the hand away from the prop.
