  • July 03, 2025, 07:54:46 PM
Author Topic: I guess I didn't think it all the way through.  (Read 981 times)
« on: November 29, 2017, 12:47:03 AM »
I've been thinking about building Dick Sarpolus' Challenger from the December 1987 Flying Models issue for a couple of years.  I'm still a beginner, but I thought that maybe I could try my hand at N-30 competition in the not too distant future.  Not a lot of entrants around here, so not a lot of pressure.  I read the article two or three times, and figure I could build a decent model if I take my time.  The article says that Dick wanted to get flying quickly, so he just got a SIG Super Chipmunk wing kit and built the model around that.  So, I figured I'd do the same and order the $25.99 wing kit from SIG and save myself time cutting everything out.  Probably be more uniform than my hand cut ribs, anyway.
So, the box from SIG arrived today and I was super excited.  I opened the box, and...  A bunch of wood and some rib sheets.  Hmmm... no plans or building instructions.  DOH!!!  Why I figured there'd be instructions in the wing kit is beyond me.  I guess the word "kit" just made me assume.  But, the Challenger plans and building article should work just fine.
Just thought Y'all would get a laugh out of my assumption.
Mark
Offline Joseph Patterson
  • AMA member- Supporter
Re: I guess I didn't think it all the way through.
« Reply #1 on: November 29, 2017, 06:17:35 AM »
  Hello Mark,
                   You can get the plans from Tom Dixon, unless someone here can get a set to you. Dixon is also putting out a short kit of the Challenger. I saw one of these fly many years ago w/an OS48 (4S). It really flew well. He took 1ST in PA stunt that day in some really high turbulent wind. I always said to my self "I got to build one of dose. Finally, someone started putting out a short kit (Dixon), so I've got mine ordered. He gets them done really fast.
                   Doug
Offline TDM
« Reply #2 on: November 29, 2017, 07:48:59 AM »
Mark here is my two cents here.
Since you are a beginner in am thinking the least amount of headaches possible. The least headaches power plant wise is electric. The least amount of headaches win the model is get an ARF. I am thinking a Vector ARF that performs quite well with an electric motor in the nose and you are good to go.
Offline Allan Perret
  • Proverbs
« Reply #3 on: November 29, 2017, 09:40:26 AM »
Get the quick build kit from Tom Dixon no matter what you decide on for power.  Local flyer had a Challenger with a OS 40 Surpass (4-stroke) and it was a great combo.  This guy is an old-timer that flew with Gieseke back in the day. Said he let Bob fly it and he liked it..  That's all you need to know.  I ordered one from Dixon, will put Saito 40 on it..
Allan Perret
AMA 302406
Slidell, Louisiana
