After looking at the diagram of this bellcrank , can i ask is the the 1/8" pivot rod fixed to the bellcrank maybe epoxied,or does the bellcrank pivot on the rod between the wheel collars.Or is the rod and bellcrank all one solid fixed unit and the rod pivots. Do the 5'32 wheel collars clamp onto the rod with grub screws or stay unfixed and can rotate with the washers above and below ...?
Hi Maverick11359,
The wheel collars should be 1/8" not 5/32" as shown in the drawing. My mistake.
The pivot rod is a tight fit through the plywood bellcrank spars but needs to loose enough to slide into place. The wheel collars with the setscrew (grub screw) is tighten to the pivot rod. On the final assembly I use a drop of Loctite on the set screws. The wheel collars act as a retainer to keep the bellcrank from wobbling and from sliding up or down on the pivot rod. Once everything is in place, the pivot rod gets a dab of epoxy on each end to hold it in place. With the wheel collars and the dowel spacer, there should be little to no movement of the bellcrank sliding up or down on the pivot rod or the pivot rod moving up or down.
BTW, this was a bellcrank for a unique situation. Normally on a full built up fuselage I would keep the pushrod from the bellcrank on the centerline of the fuselage and offset the pivot rod as necessary. Ignore the .1875" offset from the centerline of the fuselage to the centerline of the pivot rod.
Attached is an updated drawing. Hope that helps.
Dennis
