  • July 30, 2025, 08:59:57 AM
Author Topic: Garage Paint Shoppe  (Read 5555 times)
Offline dale gleason
Garage Paint Shoppe
« on: June 28, 2015, 04:05:37 PM »
I'm about to the point where it would take the same amount of time to finish this new plane as it would to "pretty up" the old plane for the NATs. The old "Impcat" is tried and proven, this new ship is a "Questionairre", it may not even fly, much less get trimmed out to any reasonable degree. But, dang! I really like the looks of this new one.
dg
Offline Joe Gilbert
Re: Garage Paint Shoppe
« Reply #1 on: June 28, 2015, 04:51:43 PM »
Right wrong or indifferent keep after the new one you know it will fly. Looking good Dale keep after it.
Joe Gilbert
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #2 on: June 28, 2015, 06:42:57 PM »
       Well Dale I just believe you'll get'er done and it will fly right too!
 Doug
« Reply #3 on: June 28, 2015, 06:59:10 PM »
"Thanks, I needed that."*
Canopy gets masked off tonight, sprayed on the morrow. Shoot the clear and start buffin'.
*Robert Stack, "The High and the Mighty", Ernie Gann
« Reply #4 on: June 28, 2015, 07:14:36 PM »
Hey Dale that looks great...I can't begin to imagine why it wouldn't fly great also...Keep on Keep'n on!
Offline Allan Perret
  • Proverbs
« Reply #5 on: June 28, 2015, 07:24:21 PM »
Looking good Dale.  What design is it ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: June 29, 2015, 10:06:28 PM »
It is "Mule #5", an attempt to camouflage Richard Oliver's "Mule #4" design in a "lawn dart" look. It seemed out of scale to me with an "Impcat" look, so I have attempted a "Palladin" look. With the addition of numbers and my usual "Let's Roll" on the underside (in memory of Todd Beamer's last words on 9/11) I should have it ready for clear on the morrow.
dg
« Reply #7 on: June 30, 2015, 06:13:14 AM »
Did the Duke slap you into that!!!!?????
Offline Crist Rigotti
« Reply #8 on: June 30, 2015, 08:21:17 AM »
Looks nice Dale.
Offline Doug Moon
« Reply #9 on: June 30, 2015, 08:27:27 AM »
Looks good!!!!  Keep after it.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Tom Niebuhr
« Reply #10 on: June 30, 2015, 10:10:11 AM »
Looks great Dale... Should be a super airplane.
AMA 7544
« Reply #11 on: June 30, 2015, 05:36:45 PM »
Thanks Tommy Boy. It's been such a long time, you may not remember, but you did the computer files on this wing design and George Hamby laser cut the ribs. I thought I was getting pretty good with posting pictures, but, I was wrong. I'll try to put the pictures here, as opposed to the other thread concerning Dave Roland...
First is underside view....next is top view...
« Reply #12 on: June 30, 2015, 08:01:31 PM »
Looks like it is flying the pattern just sitting there. A plane that looks that good has to be good. Nice Job Dale. Knowing how you build and finish I can imagine it even looks better in person. All the best to you and Linda Bob at the NATS.
« Reply #13 on: June 30, 2015, 08:21:43 PM »
"The Duke" would be a great name for this plane, but, it already has "Mule V" on the wing, so maybe "The Duke" will be next time.
dg
Offline Joe Gilbert
« Reply #14 on: June 30, 2015, 09:17:47 PM »
Looking great Dale get that clear on and go to sanding. Call if you need help will be right down.
Joe Gilbert
« Reply #15 on: July 01, 2015, 07:10:26 AM »
I'm looking into a new product, at least for me..."blender". It "melts" and levels those areas where the clear flashes and blends in seam lines. It can be sprayed with a gun, but also is available in rattle cans. John Hill, Col. McMillan,  and RO have used this with really great results, the reviews I've  found in car painting blogs are mixed.
dg
Offline Doug Moon
« Reply #16 on: July 01, 2015, 07:49:44 AM »
dg
Does blender go in with the clear or do you spray this on afterward?
Doug
Doug Moon
AMA 496454
« Reply #17 on: July 01, 2015, 08:53:11 AM »
I'm painting myself into a corner, Doug....first, a caveat to all, your results may vary! but, here is what I am going to do. First, shoot the areas such as stencil lines, paint mask lines, etc with a coat of blender, wait five minutes and hit these areas again. Give it five minutes then spray the entire plane with blender. (I'm not trying the rattle can, I want to be able to adjust the spray pattern)  After it dries, at least three to four hours, I'll sand the whole plane to a level condition, this stuff hopefully sands real well, powdering off nicely. Then, spray clear on the whole plane.  You know the rest, just like on your Tulsa Gluedobber post on finishing, the fun part...buffing/polishing to bring out the shine. Friends in high places do it this way.
That's it, we'll see what happens....
Just musing here, Bob G used all dope, except the leading edge forward was car-cleared, remember that?  :)
« Last Edit: July 01, 2015, 09:45:54 AM by dale gleason »
  • Proverbs
« Reply #18 on: July 01, 2015, 09:06:57 AM »
Dale, you using dope or 2-part auto ?
Bottom opening looks on small side for a pipe, you using rear muffler ?  What motor ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #19 on: July 01, 2015, 09:43:57 AM »
Hi Allen,
I've  been messing with this plane for over three years and there's a little of just about everything on it. Mostly, it's epoxy primer and then auto paint- base coat/clear coat.
ROJett76/67 on pipe.
dg
« Reply #20 on: July 01, 2015, 09:48:39 AM »
I must apologize to Sparky for using up so much band-width. It's a tool to spur me on to finish this plane. It seems to be working, I've got more done in the last week than in the last two years.
dale g
« Reply #21 on: July 01, 2015, 07:14:06 PM »
The pictures total just under 500kb, not enough to make Sparky wince. Besides, he's rolling in it. What he's rolling in, we can't say...  VD~ Steve
« Reply #22 on: July 02, 2015, 10:49:41 AM »
There are different types of "blenders"....some mix in with clear, others go over the base coat before the clear, which is what I'm trying. It is sprayed over the base coat, allowed to dry, then sanded lightly prior to spraying the clear. It smooths out the masking tape lines and prepares the surface for the clear, making for easier rubbing out of the clear.  So be careful in trying this out, it's easy to make a mess.
dg
Offline NED-088
    • Heartstrings
« Reply #23 on: July 02, 2015, 11:37:20 AM »
You know what? It looks pro-fes-sio-nal. Good job, Dale!
I'm pretty sure you'll have this plane 'in tune' and the engine 'on song' before you know it. ;D
I've had some difficulties with the clear this time, after buffing it, there stil are some non high gloss spots left.
Oh well, we're flying these things at 55mph. Nobody will see it.... ;)
Sunday will be my first contest since 2008. I haven't lost it, but my finesse is out of the window.
Never mind, carefully building it up always worked for me.
Off topic:
By the way, last month I met Alan Munde again for the first time in 41 years: 'Dr. Livingstone, I presume?'
We were playing the same festival, at 2 hours from here. What a nice reunion that was.
« Reply #24 on: July 02, 2015, 10:26:58 PM »
"Banjo Sandwich". Tex Logan used to have an annual pickin' party in Morristown, NJ, where he lived. Linda and I got an invite and Allan was playing with Jimmy Martin. Monroe, all the biggies were there....I especially enjoyed meeting Bill Keith, I doubt if Alan Munde would recall me. Lot'sa good times, I'm, glad he got to see you, Bruno. Maybe we'll get together again sometime, I hope so,
dg
(I don't hold anything against anyone  for going to electric, I've fallen from grace myself and put a pickup on my Granada and I now can be heard if I so desire, not exactly an acoustic band....asked what kind of music we play, I always reply, "LOUD".) It was self-defense.....
« Reply #25 on: July 05, 2015, 06:10:01 PM »
She's almost done, no time left for buffing it out. Just a final picture to show the control surfaces. Lot'sa elevator, balanced, low aspect wing.
Thanks for dropping by.....
dale g
Online john e. holliday
« Reply #26 on: July 05, 2015, 06:15:13 PM »
Hope she flies as well as she looks.
« Reply #27 on: July 05, 2015, 07:51:30 PM »
Looks nice Dale.  All the best.
Offline Mike Keville
« Reply #28 on: July 05, 2015, 09:17:32 PM »
Love that "Let's Roll" on the bottom of the wing.  A fitting tribute!
r
« Reply #29 on: July 06, 2015, 07:30:11 AM »
Thanks to all for taking a look, I appreciate that. I apologize for the "vertical" image, I'm struggling with removing that view, I was fortunate to be able to at least add the proper view.
Again, thanks,
dale g
Offline Steve Thornton
« Reply #30 on: July 06, 2015, 01:39:39 PM »
She's a beauty Dale!  Best of luck, we're all supporting our friends from "Big D"
"Most of us won't make it out of this world alive."
Steve Thornton
« Reply #31 on: July 10, 2015, 10:21:02 PM »
Flew it today, have yet to sort out the prop/pipe/rpm/nitro/etc, stuff. But, the main question is answered....it flies, and flies very well. I had concerns because the stab "looked" to have negative incidence, but, a flat building table and incidence meters begged otherwise. They were right. The vertical C/G was a question, as I had lowered the complete drive-train 3/8ths inch from #4  Mule. All good, no hunting.
It's a big'un, and 75 ozs is actually about as light as I can build it, but the thick wing volume (not squares) has a ton of lift, it is the first plane I've built that actually has a genuine glide... landings are fun!
See all Y'all in Muncie at the Dairy Queen,
dale g and Linda B
Offline Joe Gilbert
« Reply #32 on: July 10, 2015, 11:24:13 PM »
Remember me telling you that thing will glide so nice ,the thick wing dosnt hurt the glide. We are in St Louis going to fly at Buder park in AN then on to Munice tomorrow. See you there.
Joe Gilbert
« Reply #33 on: July 11, 2015, 09:17:09 AM »
     Looks real good Dale! I'm looking forward to seeing it in the air
            Doug
Offline Sean McEntee
« Reply #34 on: July 11, 2015, 09:33:39 AM »
Great Movie!  When I'm " flying" over a layer of big poofy clouds the theme song from that movie always creeps into my head
My " Git er done" movie that I pop in when trying to expedite a build is Jimmy Stewerts "Spirit of St Louis". Love the construction sequences
