to add to this interesting observation,, same airplane, same engine, same fuel, same everything but the prop, establish rpm to provide exactly the same lap times with two seperate props,, ( both or in my case all 4 different props are all the same measured pitch and same diameter with differing airfoils,,and blade planforms),, all four props going the same ( down to the second decimal, or more accuratly than you can actually measure) lap times,, have vastly different line tensions in LEVEl flight, not to mention in overhead manuevers,,
I cannot explain it with any real physical facts,, I just know it is different,, hence the need to theorize,, then FLY it to find the prop that works best,,
