  • June 15, 2025, 02:14:53 PM
Author Topic: How thick do turbulators need to be?  (Read 1015 times)
« on: June 13, 2013, 10:25:03 AM »
Just How thick do turbulators need to be?
is there an optimum thickness of full length vs. fin type ?
When I tried them I used 3 layers of plastic electrical tape layered on top of each other. Then cut from the tri layer strip of tape.
Online Howard Rush
Re: How thick do turbulators need to be?
« Reply #1 on: June 13, 2013, 11:41:18 AM »
Looks like you are mixing boundary layer trips with vortex generators.  They do two different things.  Optimal thickness of either is a function of boundary layer thickness.  I can point you to some references, but I am just sticking things on my airplane to see what happens.
[/quote]
« Reply #2 on: June 13, 2013, 02:39:52 PM »
Hi Howard
Thanks for your reply, I have read many papers on these, and Data gleamed in wind Tunnel test, I do know the difference between the two.
We are using both to help improve the boundry layer (if such a thing exist) or airflow over the wing and control sufaces, The layer trip work either at the LE  or farther back on the wing, They also seem to work at the Stab LE or back more on the stab, they also seem to work installed just before the flap line (hingeline).
I have read test and seen VGs  working right on the LE and again back farther on the wing. One of those is pictured below...
I also read that using the same wing and only changing the material of a LE Trip resulted in a marked change in it's effectiveness.
I am beginning to agree with Howard that it may be prudent to just go out and do actually flight testing of all of these.
I am also confused as to how 2 similar trips can do this... 1 will only slightly improve the flow for our purposes at lower speeds and low Reynolds numbers but keeps the boundary layer laminar .  Then another very similar trip, does the same but with much more effectiveness and changes the layer from laminar to turbulent.???
It also "" seems ""  you could use trips on a heavy stuntship at the LE and then also near the forward part of the wing high point, and then again just before the hingeline
