  • July 03, 2025, 08:14:51 PM
Author Topic: Where are the PA engines made  (Read 6398 times)
Offline Bill Mohrbacher
« on: October 02, 2011, 10:13:45 AM »
Where are the fabulous PA Stunt engines made?
Re: Where are the PA engines made
« Reply #1 on: October 02, 2011, 11:06:30 AM »
Hi Bill
The PA engines were made by Henry Nelson and Randy Smith. I built all of the eninges at Aero products in Georgia
Randy Smith
« Reply #2 on: October 02, 2011, 02:36:28 PM »
Hi Randy,
What do you see in the future as far as continued production of the PA's?
« Reply #3 on: October 03, 2011, 10:25:59 AM »
Hi Randy,
Hi Will
Working hard at getting them back up, but it is going much slower than I would wish
« Reply #4 on: October 03, 2011, 12:09:02 PM »
Randy,
Did you talk Henry out of retirement or are you looking for a new machinist?
« Reply #5 on: October 03, 2011, 12:43:39 PM »
Not to hijack the thread-okay okay it is a sort of hijack, is there a CAD drawing of a PA 65 side exhaust? By the way guys, this motor is a killer-trust me.
« Reply #6 on: October 03, 2011, 12:48:11 PM »
Hi Will
  I am surprised that there's anyone willing and able to take on such a specialty task. Although I expect the "able" part is a lot more of a challenge.
Offline Steve Fitton
« Reply #7 on: October 03, 2011, 01:46:18 PM »
I wonder if one of the great many smaller manufacturers of AR-15s might be an idea.  There is the capability for good castings (used for the upper/lower receiver) as well as machining for all the internal bits.  They are US based shops due to import laws and many are lower volume outfits that might want side work.
« Reply #8 on: October 03, 2011, 02:49:12 PM »
Steve, that is a very astute observation but, I worry about the relatively low volume of such a high end product in such a small niche market. The key to the PA as I see it, is somehow figuring out a way to up the volume-that's the key.
« Reply #9 on: October 03, 2011, 02:57:45 PM »
Who knows.  The thought just popped into my head the other week when I noticed a add at my local gun club for M-16 lowers with the gun club name on the casting.  I figure if shops have reached a point that they can run batches of individualized castings, maybe one might have the flexibility to take on other jobs...
Offline Bill Morell
« Reply #10 on: October 03, 2011, 05:10:11 PM »
I take it PA engines are currently unavailable?
Bill Morell
Vietnam 72-73
« Reply #11 on: October 03, 2011, 05:32:12 PM »
Henry retired. Our loss, but he's allowed. There are talented machinists out there, if management will allow them to be.  :'( Steve
« Reply #12 on: October 03, 2011, 06:22:02 PM »
   I would be surprised of the casting, while challenging, is the the most specialized part. I would think the machining, plating, and honing of the liner to the kind of exacting standards required would be beyond any but the most exotic aerospace machine shops. Particularly for the price point they would have to hit.
Offline BillLee
« Reply #13 on: October 03, 2011, 06:37:29 PM »
I'd heard that a shop in North Carolina had taken over production from Henry. Any truth to that?
Bill Lee
AMA 20018
Online Tim Wescott
« Reply #14 on: October 03, 2011, 07:06:45 PM »
I'm not sure if that's really quite "exotic aerospace machine shop" territory -- after all, more plain jane lapped engines are made routinely in China -- but that's certainly the harder part of the deal than getting the casting right.
Offline Douglas Ames
« Reply #15 on: October 03, 2011, 07:40:25 PM »
Old School Machinists are getting hard to find - Guys that can setup & operate a manual engine lathe. What I mean by that is they can do the "math".
Today, we have CNC Programmers and CNC Operators.
AMA 656546
Offline Dennis Moritz
« Reply #16 on: October 03, 2011, 08:12:13 PM »
Fox? Bad joke, I guess.
« Reply #17 on: October 03, 2011, 08:33:53 PM »
I bet Banjock could make them.  He can machine anything!
Offline David M Johnson
« Reply #18 on: October 03, 2011, 10:48:51 PM »
George Brown, Tempe machine, very familiar with engines and machining processes involved.
My 2 cents worth
David Johnson
We're havin some fun now!!
« Reply #19 on: October 03, 2011, 10:59:20 PM »
Hi Steve, yeah I thought of Dan when joking about Fox. The last Fox Dan put straight involved replacing the crankcase bushing and carefully lapping the piston/cylinder. Even bought a high zoot crank from Randy. Lapping the piston in is common enough. Time consuming. Also means you need the "feel." The Fox castings are also out of square at times. Not the way to begin a high performance build.
« Last Edit: October 04, 2011, 06:16:56 AM by Dennis Moritz »
« Reply #20 on: October 04, 2011, 01:32:38 AM »
    I don't think the plain jane lapped engines from China come close to the standards of repeatability that we have come to expect with jewels like the PA. Its almost uncanny how close they can be to each other. Not perfect by the typically hyper-perfectionist competition fliers but good enough that if you change something on your #1 engine, you change it the same on the backup, and have a reasonable expectation that it will work if necessary without testing.
    I know from long painful experience how difficult this sort of repeatability can be, even with unlimited funds. To get it for $400 is almost unbelievable.
« Reply #21 on: October 04, 2011, 04:58:50 AM »
Agreed.
In Hungary I changed engines early in the week. I had a bearing that was getting loud so at the insistence of Dave I changed engines. I counted the turns in on the needle valve and set the backup exactly the same. The next day when it fired up (on the first flip) it read, on the tach, the exact same RPM as the previous engine. Needless to say I was impressed.
Derek
Derek
Offline david smith
« Reply #22 on: October 04, 2011, 08:53:56 AM »
They took over making the pylon 40s.  Nothing else.
David
« Reply #23 on: October 04, 2011, 09:51:18 AM »
The true beauty of the PA's is the fact that Randy assembles each and every one and blueprints them in the process.  That gives us the best of the best.
Offline John Lindberg
« Reply #24 on: October 05, 2011, 01:43:54 PM »
Are the Ro-Jett Stunt engines available?  D>K
« Reply #25 on: October 05, 2011, 01:50:20 PM »
  Yes.
« Reply #26 on: October 05, 2011, 03:15:47 PM »
You can order direct from Dub Jett. Cool guy.
« Reply #27 on: October 06, 2011, 08:11:10 AM »
Is there really any difference between the cast case and the bar-stock versions, other than $50.00?  D>K
Offline Balsa Butcher
  • High Desert Flier
« Reply #28 on: October 06, 2011, 08:50:26 AM »
Between Dubb Jett's site and Richard Oliver's site Richards Olivers site "rojett.net" there is a lot of info available on these engines. They advise that the engine runs the same but the bar stock case is more stable and breaks in easier. Cosmetically, the machined bar stock case is a jewel, worth the extra $$. Orders are place through Dubb's site.  8)
« Last Edit: October 06, 2011, 10:11:06 AM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #29 on: October 06, 2011, 08:59:39 AM »
    From those who have tried both, the bar-stock case version runs more reliably in terms of inside/outside speed difference, essentially, the difference in speed between the inside and outside maneuvers is essentially zero.
« Reply #30 on: October 06, 2011, 11:24:21 AM »
I'm not sure how "cool" he treats his teenage emloyees........ n1
Derek
« Reply #31 on: October 06, 2011, 11:35:06 AM »
Derek,
No idea about that but he's always treated me well. So has Randy Smith for that matter.
« Reply #32 on: October 06, 2011, 11:37:34 AM »
Derek,
I lost any respect that I may have had for him at the past nats.
« Reply #33 on: October 06, 2011, 11:38:50 AM »
Sorry to here that Derek.
« Reply #34 on: October 06, 2011, 11:44:21 AM »
It happens. No skin off my teeth.
Derek
