" tip vortex "
Crikey :
https://www.dancingwithwater.com/vortices-natures-creative-tool/like the french ' Portance ' being lift ! , and approxomateing ' support '
youve got to watch your poids !
Er, sorry .
looking at alternate synonyms of dymamics , A Twisters about what youvegot , trailing off the ' end ' of the flying surface ! . At Times .
obviously if the wings working ten times as hard , the forces are up a bit .
On a gusty day , the length of the vortice , can have it pulling about . this can drag & rock the tips about . as its attached to the tips , in a sense .
Originates or forms from there. Tho it really originates from the varying forces acting on the wing , and manifests / from the breakaway point .
Give or take . not to disagree with the previous Matt's statement .
Make Vortices Your friend !
https://wes.copernicus.org/articles/8/1369/2023/ Looks like a shakey thing getsem variable . whereas a less vibratory device the airflows more stale / less variable .
SO , Fuselages .
The Canopy / side Area Vs Wheel Spats , is what someone told me the humpy canopys were there for .
Side Area - C.G. - load balance ( about attachment point . Unbalanced presumably the laterl balance would vary with sidewind .
unless it was the folkerts with the area under to blow the sucker outward , comming into - thru the headwind , in the outside loop off the overhead eight . As I saw it when I did it . Back then .
Tho we could run pretty quick , I didnt thiink the judges would want to , as well . If I had to . as it were .
Anybody been in a sailboat in a bit of wind , like 20 Kts odd , will have observed the tension , in sails and ropes . Going About . and the forces restrained . Also often vibration in areas of sail ,
which is where a god keen sailor will be ' trimming ' angles & tensions . Continually in varying winds . tho on longlegs they get em in pretty quick . after a bit of practise .
SO
A nutter with a stunt plane out the window / sunfoof / back of a ute / flatdeck , In the airflow - gets to see theyre no miniscule little things we're dealing with .
I get uptight about bits sticking out . mufflers , fuel fillers , etc . They called it Interfereance Drag . Disruption of airflow at intersection of omponents ! . So the cleaner the better .
Sometimes flying in mist , you can see the wake . of the plane in the air , and the airflow in the damp , or oil / exhaust , fuel , on the plane . Or DUST ( on the plane )
So , the wings designed to fill in the hole , n the atmo sphere .
ahem . all Wing Sections originate from the sphere , tube - form ! ..
Keeping it basic and clean , for the Fuse . We all twirled things round on astring & stick , whilst a nipper . The same thing applies , dirctional stability , and under duress .( orf load / flow )
Higher loaded airflow is denser , so the less loaded flow sort of fits in after it .
