  • July 27, 2025, 01:14:31 AM
Author Topic: Fuselage rear top deck formers ???  (Read 1464 times)
Offline Vincent Corwell
« on: October 01, 2008, 07:45:58 AM »
How do you plot the fuselage formers ?
for the rear top deck, straight line taper in top view
and side view, given the shape of front former
for example, want to draw 4 / 5 formers behind , decreasing in
height and width but keep the shape for sheeting
Forgotten the principle !!
Vincent
Offline George
  • Love people, Use things.
Re: Fuselage rear top deck formers ???
« Reply #1 on: October 01, 2008, 09:03:01 AM »
Assuming not being done on a computer, draw what dimensions you have and interpolate the rest...or am I missing something?
George
George Bain
AMA 23454
« Reply #2 on: October 01, 2008, 12:20:29 PM »
Thanks George
What I am asking is how do I scale down each one after the first please ?
I have always used the same curve applied to each smaller former, but
usually have to sand all carefully before sheeting or adding stringers,
wondered if it could be drawn really accurately
Vincent
Offline Phil Coopy
« Reply #3 on: October 01, 2008, 06:06:08 PM »
Using your PC & printer, you could print the first one full size and then print the succeeding ones, reducing each by (%) according to its corresponding width measured at the base position of each following former. At least that would give you some patterns work with. Of course, this only works if the slope of the turtle deck is a straight line.
Phil
« Reply #4 on: October 02, 2008, 01:07:48 AM »
Good idea Phil, thank you
I used to do this, using drawing tools , but so long ago
George suggested I "interpolate", which the dictionary does not help with
nowadays I forget if I am going upstairs or downstairs !
Vincent
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: October 02, 2008, 07:42:09 AM »
I use a drafting template that has circles of different diameters.  Match the width of the bulkhead with the diameter of the circle and complete the half circle.   Seems to work OK-no computer necessary. Shouldn't this thread be in Building Techniques?
Pete Cunha
Sacramento CA.
AMA 57499
Offline George
« Reply #6 on: October 03, 2008, 08:16:47 AM »
...George suggested I "interpolate", which the dictionary does not help with
Vincent
The last time I had to do this was on a Jr. Nobler plan. The side and top views are shown, but no formers. I measured what was available at the locations and filled in the rest. Same with the wings. The "rib" pattern was extrapolated from the side view where the wing entered the fuselage. I had to interpolate the rib shape at the tip and root position lengths extrapolated from the plans. Am I using the words incorrectly? For these purposes it means to "fill in" the unknown by using the parts you know.
BTW, I still haven't built that Jr. Nobler.  :(
I go upstairs to the computer and downstairs to watch TV (mouse potato, couch potato).  ;D
George
George Bain
AMA 23454
