  • July 09, 2025, 05:45:32 AM
Author Topic: fuse finish...  (Read 885 times)
Offline Bootlegger
fuse finish...
« on: September 23, 2009, 10:19:47 AM »
   Mornin' Guy's, I am tryin' a new to me finish on a profile fuse, I coated the fuse with an epoxy finishing glue.
 When I put the first, and only, coat on it I wiped the excess epoxy off with paper towels.
  Would ya'll suggest a second coat of epoxy, or start with the dope type finish?
  I am gonna use a clear finish to keep the weight down.
  Thanks for the suggestions,
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: fuse finish...
« Reply #1 on: September 23, 2009, 05:23:44 PM »
One coat is usually enough to seal the wood which is all you want the epoxy to do. Sand it and start your finish..
Offline Bootlegger
Re: fuse finish...
« Reply #2 on: September 24, 2009, 05:14:10 AM »
    Thanks Bob, I appreciate your help...
Gil Causey
AMA# 6964
