  • August 05, 2025, 09:26:27 AM
Author Topic: Fuel tank with four ports  (Read 988 times)
Offline Dave Nyce
  • Flying
    • Revolution Sensor Company
« on: March 06, 2020, 01:41:18 PM »
I have a metal fuel tank having four ports (brass tubing).  Does anyone know the purpose for this type of tank? (Please see attached photo.)
Dave Nyce   New Bern, NC
AMA: L356
Offline kenneth cook
Re: Fuel tank with four ports
« Reply #1 on: March 06, 2020, 02:01:42 PM »
          That looks like a Veco pressure tank. I believe the top two are just vents. Obviously the outboard is the pickup whereas the inboard is where the pressure line connects to. If you pressurize the tank through what I'm referring to as the pressure nipple, you may find that there's a inline restrictor in that tube. I have one similar in a vintage combat plane.
Offline frank mccune
« Reply #2 on: March 06, 2020, 02:07:15 PM »
          Kenneth has it correct.  I have one just like the one pictured.  After filling, a length of fuel line was used to close the filler and the vent on the top of the tank.
        Frank McCune
Offline Dave Nyce
  • Flying
« Reply #3 on: March 06, 2020, 05:36:56 PM »
Thanks!
AMA: L356
Offline Peter in Fairfax, VA
« Reply #4 on: March 06, 2020, 08:28:08 PM »
Convenient.  You can leave the draw and pressure lines hooked up, then have both fill and vent lines.
Some Veco tanks also came with one-way valves, which could work out well in a uniflow setup for venting air out while fueling, yet not allowing air in during flight.
Dennis Leonhardi
« Reply #5 on: March 06, 2020, 10:19:47 PM »
        Frank McCune
I much preferred those tanks (4 oz.) in combat models over pen bladders or pacifiers, because (1) you would get a 5 minute flight with a Fox 36X, and (2) they are very, very reliable.
Dennis
Dennis Leonhardi
« Reply #6 on: March 07, 2020, 05:23:08 PM »
Real easy to flood your engine with a tank like that. Best to pinch off the pressure and feed lines while filling.
Motorman 8)
These tanks have a "check valve" - no problem with flooding, used them for many years.
Dennis
