  • July 19, 2025, 09:19:34 AM
Author Topic: Fuel tank hold down  (Read 1243 times)
Offline Larry Wong
Fuel tank hold down
« on: March 01, 2007, 07:45:46 PM »
Just wondering what are some of the ways to hold a fuel tank in/up in a piped engine plane,so that it can still be removeable. ???   n~
Larry
Offline RC Storick
Re: Fuel tank hold down
« Reply #1 on: March 01, 2007, 08:14:38 PM »
All I do is shim it with balsa and a few drops of CA.
« Reply #2 on: March 01, 2007, 09:08:14 PM »
use a velcro strap....glue it to the comartment top.....easily able to adjust and remove.
Offline Jim Morris
« Reply #3 on: March 02, 2007, 12:10:10 PM »
I use balsa and foam to create a snug fit and fine tune the height using playing cards. Works well.
Offline Bootlegger
« Reply #4 on: March 02, 2007, 02:52:43 PM »
 Something that I have used is to solder a right angle piece to the end of the tank and put a 4-40 bolt through it to bolt the tank down. Then when I need to remove it all I have to do is remove the bolt..
  Hope that this helps.......... HB~> #^
8th Air Force Veteran
Gil Causey
AMA# 6964
