Hi Bob,
I used those for years from my Fox 35 days thru ST60's period. Eddy R turned me on to them, with the caveat that I had to wrap them with just about anything handy. I used to use anything from scraps of silkspan, glass cloth, carbon veil, just about anything was fine wrapped over that "spot welded" so to speak, seam, with a thin coat of epoxy. I liked their light weight and small size for sure.
I seem to remember the mesh was a little fine and they would clog more often and they could gel over with dried castor gum, but I was running a more open system back then too... I now keep my fuel jugs sealed once I open them and put on my cap with the fittings and a filter on the pickup in the jug, so no trash is prone to get in the jug at the field nowadays.
For the last several years I'm now a Cr@ptrap convert. Have to agree, I feel they are the best thing out there for a slim fit and double filtration, yeah, they are a little on the long side, but that's good since it keeps me on my toe's to keep my fuel tubing nice and short and neat.
Speaking of closed systems, I will note that I'm a stickler for capping my uniflow vent when I'm done flying for the day, and I truly believe it lowers the issues of junk and dried crud in the tank. An air intake filter helps keep grass, sand (bee's) etc out of your venturi too...
EricV
What,s real sad is that Master Airscrew quit making these.. A piece of shrink tubing fixes the only issue they had. They are small, light and can be taken apart for cleaning. Wished I had stocked up when they were still available.
