  • July 09, 2025, 12:35:00 AM
Author Topic: Cutting a drilling CF?  (Read 1015 times)
« on: August 15, 2022, 09:55:16 AM »
What’s the best way of cutting and drilling CF without damage?
I have some CF gear I need to trim a little and drill some holes for axles and mounting bolts.
Online Howard Rush
Re: Cutting a drilling CF?
« Reply #1 on: August 15, 2022, 10:36:32 AM »
A high speed steel 1/8” drill will go through 2” of carbon composite before it’s defunct. A carbide bit is better. Spin the bit fast. You can use isopropyl alcohol as lube. Diamond scroll saw blade from Amazon works great for cutting composite. Sandpaper works too.
« Reply #2 on: August 15, 2022, 06:48:58 PM »
Thanks Howard.
I need to trim some off. Can I use a Dremel tool with a cut off wheel?
Offline Doug Moisuk
« Reply #3 on: August 15, 2022, 08:13:05 PM »
Mak nd glove up when cutting, drilling and sanding CF.
Doug Moisuk
MAAC 3360L
« Reply #4 on: August 15, 2022, 08:34:08 PM »
I assume you suggesting mask up.
Yep was planning on it. But did not think about gloves. Good idea and noted. 👍🏼
« Reply #5 on: August 15, 2022, 10:50:40 PM »
Dremel tool cut off disk works great on composite stuff. Belt sander is nice too. Cut and sand lightly or you'll fuzz the end. I try not to use saw blades, they go south quick. I use one of those respirators with the rubber face cup from home depot. It's the only thing I've found that doesn't leak. Once that CF is inside your body, it don't leave. That stuff floats in the air for a long time so, do your job then leave the area for a while.
Motorman 8)
Offline John Rist
« Reply #6 on: August 16, 2022, 08:50:53 AM »
Motorman 8)
Harbor freight also has a good mask.
https://www.harborfreight.com/p95-maintenance-free-dual-cartridge-respirator-66554.html
« Reply #7 on: August 16, 2022, 12:33:59 PM »
Good input. Thanks guys.
Got mask and gloves.
Now to find a shady spot outside. 😎
Online Howard Rush
« Reply #8 on: August 16, 2022, 04:46:14 PM »
Good advice on the Dremel disks and belt sander.
