General control line discussion => Open Forum => Topic started by: bob werle on July 18, 2008, 12:17:08 PM
Would someome check me on my math please. I have a fuel that is 20% nitro and 12% caster in a 1 qt can.. If I add 5 oz. of caster this should be about 15% nitrp and 23% caster----I think..
Any math people out out there???
A quart is 32 oz (I hope!).
Currently 20% is nitro, or 6.4oz.
12% is castor, or 3.84oz.
rest (68%) is methanol+synthetic+ "extras".
Now if you add 5oz of castor, you now have 8.84oz out of a total of 37oz of stuff, or ~24% castor, and 6.4/37 =~17% nitro, assuming that you simply added 5 oz to the total. Also I assume these are volume measurements.
This is close to your numbers.
Much would depend on if the 1 quart can were full or not.
assuming it is full you are starting with 32 ounces volume measure.
12% castor works out to .12 x 32 = 3.84 oz of castor.
20% nitro works out to .2 x 32 = 6.4 oz of nitro.
3.84 of castor + 6.4 0z of nitro = 10.24 oz leaving you 21.76 oz of meth.
21.76 oz meth divided by 32 oz (total mix) works out to 68% of meth.
Adding 5 oz of castor gives you total mix of 37 oz and total castor of 8.84 oz
8.84 oz castor divided by total mix of 37 oz = 23.891% castor.
6.4 oz of nitro divided by total mix of 37 oz = 17.3% nitro.
21.76 oz meth divided by total mix of 37 oz = 58.9% meth
If you want to mix in the quart container subtract the amount you pour off and do the math again.
http://www.nitrorc.com/default2.asp?Introduction=http://www.nitrorc.com/fuelws
Here's a great program!! Sroll down and click on add oil
Dwayne
thank you all. I just wanted to make sure of my math.
