  • July 04, 2025, 05:01:53 PM
Author Topic: Fronkensteen 4  (Read 3340 times)
Offline Garf
    • Hangar Flying
Fronkensteen 4
« on: February 11, 2011, 10:26:06 AM »
After the destruction of the short lived Fronkensteen 3, I am ready to do it again. Presenting the Fronkensteen 4. The parts were mostly collected from the vendors at the King Orange Internationals. The wing is supposed to be from a Super Chipmunk, the Fuselage is from an ARF Cardinal. The tail group is unknown. It could be called the KOIsteen, but that might be a little too weird, even for me. All remaining parts will either be scrounged or improvised.
Offline Andrew Borgogna
  • Andy
Re: Fronkensteen 4
« Reply #1 on: February 11, 2011, 10:39:33 AM »
Where are the stiches doctor?  I love it...
Andy ;D
Andrew B. Borgogna
Offline Greg L Bahrman
Re: Fronkensteen 4
« Reply #2 on: February 11, 2011, 11:51:25 AM »
Tail also looks Cardinal?? It'll probably fly great.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #3 on: February 11, 2011, 06:27:24 PM »
Could be. The vendor couldn't tell me what is was from.
Offline George
  • Love people, Use things.
Re: Fronkensteen 4
« Reply #4 on: February 12, 2011, 09:32:13 AM »
IT'S ALIVE! IT'S ALIVE!  ;D  H^^
George
George Bain
AMA 23454
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #5 on: February 12, 2011, 08:50:03 PM »
Not yet, but it's gettin there. I still haven't decided what to power it with.
Offline Bill Heher
  • Fix-it
Re: Fronkensteen 4
« Reply #6 on: February 13, 2011, 01:48:54 AM »
Stab elevator definitely look like cardinal, and makes sense since there was a fuse to match. Wing looks good, knock out a couple different style rudders out of cardboard until one says  " YEAH" and go to town.  LA .46 power, or maybe an ST.51 for current ( almost anyway) engines. Or .45 size classic loop scavenged snarling away.
Nice meeting you at KOI, see you next time around.
Bill Heher
If it's broke Fix-it
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #7 on: February 13, 2011, 06:26:20 PM »
ST G21 46, Johnson SS, OS FP35, OS LA 40, OS LA 46, PAW 29 DS.
Re: Fronkensteen 4
« Reply #8 on: February 13, 2011, 08:56:52 PM »
 I think this one looks way too nice to be of Fronkensteen. Maybe an adopted child, or the beautiful bride! Looks like it should be a good airplane. y1
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #9 on: March 22, 2011, 12:37:21 PM »
Done. Power is an OS FP 35.
Offline louie klein
Re: Fronkensteen 4
« Reply #10 on: March 22, 2011, 12:57:34 PM »
I know it was a lot of work, good job and good air!---LOUIE  D>K H^^
Offline Chris Edinger
  • Hawker Hurricane
Re: Fronkensteen 4
« Reply #11 on: March 22, 2011, 01:28:14 PM »
Garf...LOL ;D  Love the muffler... Ummm does that make it a V8????? Great Job...
Lee's Summit MO
AMA 896082
Re: Fronkensteen 4
« Reply #12 on: March 25, 2011, 09:00:21 PM »
As homely as it looks it should fly great. LL~ LL~ LL~
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #13 on: March 27, 2011, 03:04:17 PM »
I test flew this thing again today. It flies great, but a little fast. In the air, it looks like a large dart. It looks fast. I need to slow it down and try it again. Sometimes when you slow them down, problems begin to show up. This happens to be the best looking of the Fronkensteen series. I hope it stays that way.
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #14 on: May 20, 2011, 12:37:57 PM »
Sure enough, I got a slow flight and lost tension, and put it in again. It needs more tip weight. Also, the Ultracote paint I used is melting off the entire plane. I am now stripping the plane and have replaced the weak rudder I had on it. I have also reworked the flimsy gear mount of the ARF Cardinal fuselage.
Re: Fronkensteen 4
« Reply #15 on: May 21, 2011, 08:26:43 AM »
What length line are you using?  Planes have a happy medium for air speed when flying.   H^^
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #16 on: May 21, 2011, 04:13:25 PM »
.015" X 60'. I use this on most everything.
Re: Fronkensteen 4
« Reply #17 on: May 22, 2011, 07:18:13 AM »
If you have room, try longer lines.   Need to keep air speed up on some planes.  Used to have an Excaliber that I could fly slow enough that people thought it would fall out of the air.  Only time I would speed it up was when wind was blowing.   H^^
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #18 on: May 25, 2011, 08:27:07 PM »
That was GMA's specialty.
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #19 on: June 26, 2011, 09:54:35 PM »
Repairs are finished. Power is now an LA 46 with large venturi. I will most likely need to slow it down some.
Offline Douglas Ames
Re: Fronkensteen 4
« Reply #20 on: June 27, 2011, 04:34:46 PM »
You need a recycled logo on your wing. Nice muffler, can't say I've ever dumpster dived for model parts...
AMA 656546
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #21 on: June 28, 2011, 08:49:22 AM »
The wing cost me $15 and the fuselage $15 and the stab/elevator $5 at the KOI. The rest came from my junk pile. Except the gear and flaps. I had to buy them retail.
Offline Kim Mortimore
Re: Fronkensteen 4
« Reply #22 on: June 28, 2011, 08:07:57 PM »
Phil,
What is the prop in the picture?  It looks like a high-pitch speed prop.  Is that what you were flying with?
Kim Mortimore
Santa Clara, CA
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #23 on: June 28, 2011, 09:21:55 PM »
Phil,
That's one of my favorites, the Taipan 11-5.
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #24 on: July 10, 2011, 04:14:40 PM »
This thing now has an OS LA 46, 25 venturi, Thunder Tiger 11-4.5 prop. Sealing the flap hinge line is the next trick.
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #25 on: July 15, 2011, 07:51:21 PM »
I sealed the hinge line with common Magic tape. Talk about UGLY!
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #26 on: August 11, 2013, 03:45:19 PM »
I finally found some good hinge sealing tape. I'm also using the XOAR 12-4 prop. Last time out, I planted it Yard Dart style in soft ground. Broken prop.
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #27 on: August 11, 2013, 03:50:20 PM »
I will use whatever works. Total cost of Fronkensteen 4 bare airframe. is around $50.
Offline Garf
    • Hangar Flying
Re: Fronkensteen 4
« Reply #28 on: August 11, 2013, 03:54:29 PM »
Bride of Fronkensteen sounds good. If I assemble a slightly smaller model, that is a distinct possibility.
