  • July 09, 2025, 09:35:22 AM
Author Topic: From the past.  (Read 889 times)
Offline Norm Faith Jr.
From the past.
« on: January 22, 2020, 08:27:58 PM »
This came in mail today. My cousin's new neighbor gave all of it to him, to send to me. The neighbor said he had it "forever." The .29 has never been run or mounted, wish it had the box. Early fifties? I've never seen propellers like these. They have never been used. I believe some were made by Olsen and Rice? The gas tank was made by DeBolt in N.Y., I guess the little funnels were used for some fuel purpose? When the weather clears up, I might try and run the engine.
Norm
Circlepilot   AMA9376
Online Peter in Fairfax, VA
Re: From the past.
« Reply #1 on: January 22, 2020, 09:17:25 PM »
Looks like a 1953 Torpedo .29, if I am reading the Tim Daniels book correctly.
Offline dale gleason
Re: From the past.
« Reply #2 on: January 22, 2020, 09:58:39 PM »
Norm, Notice the papers in your post show a four bolt backplate and the motor you have has three bolt backplate.  The paper probably have a six bolt head and your motor has four. I like your motor better.
I think,
friend dale g
Re: From the past.
« Reply #3 on: January 23, 2020, 10:18:25 AM »
I think,
friend dale g
Yep, you are right Dale, about the parts manual that was with it. It shows a six bolt head.
Norm
Circlepilot   AMA9376
Re: From the past.
« Reply #4 on: January 23, 2020, 10:27:30 AM »
Hey Norm. I have several props like those. Need more?  They are indeed from the early 50's.  The funnels were for fueling those old snap lid tanks with white gas and 70 WT non detergent oil. Bark Klapinski collects old props as well and I sent him some like those a few years back. I have some props with VECO painted on them.  H^^
Check out the round tank, It may  have a swivel pick up. I have one just like it in a blue box, I think it is Acme. H^^
You are right TY, I read the box closer...it has an "internal swivel." Says "fuel never leaves the outlet tube." Works like a clunk tank right?
Two of those props appear to be pusher props. Some of them are stamped .30 and .35 cents. Wish props still cost that much.
Norm
Circlepilot   AMA9376
Offline bob whitney
Re: From the past.
« Reply #5 on: January 23, 2020, 10:53:06 AM »
Norm before u run the 29 ,pull the backplate and look at the Rod some of the rods were tubular and brazed top and bottom .another flyer wanted a couple skunky engines I had and offered to trade me a new 3 bolt K&B 29. we were young I thought I had pulled a good one over on him  .first flight on the K&B and the rod exploded taking out the complete engine. the rod was hollow and brazed together  RAD
rad racer
Re: From the past.
« Reply #6 on: January 23, 2020, 06:16:00 PM »
Will do, if I plan on running it. At the moment I'm getting a big kick out of just looking at an engine that old, that doesn't have a tool mark one on it. BTW, the cylinder head screws (looking through the cooling fins) have a yellow substance on them...is that some type of "Loctite," or corrosion?
Norm
Circlepilot   AMA9376
