I’d like to chime in here also. I probably have more time on various 4S engines than anyone here as I’ve been using them for around ten years. From the little OS .20 up to the SAITO .91.
I have never had a failure in any 4S engine – EVER.
Two issues that I will address, however:
I have had to replaces bearings and a valve on one Surpass .40 that I bought used with zero knowledge of how it was run in. The bearings did not fail but were somewhat noisy. The valve was part of a bad batch that, according to the place I bought them, came through on some 40s and 48s.
Also, I bought a new SAITO .30 that had a problem with the cam/valve interface. I sent it back and it was rebuilt but not to my liking, as the valve clearance would not hold and the black discharge got darker instead of lighter. I returned it, requesting a NEW engine and they complied. That engine now resides in my Argus and is as close to perfect as I could ever want.
One thing that I have always recommended regarding lube: NEVER go below 22% total. My friends in Italy, who fly 4S almost exclusively, warned me about lubrication many years ago. When I use the YS 20/20 (all synthetic), I add castor to bring the total up to 23%.
I can truthfully say that I have never had a lubrication related problem on an engine after it was properly broken in (The SAITO .30 was a fluke. I have four of them and have only experienced the problem with the one).
I was recently translating a document from French to English and I read about fellows over there with well over 900 flights with zero maintenance. All my engines, by the way, have not required valve adjustments after initial break in. I usually check the play once a season. And, I have never burned out a plug.
Finally, I should add that, in general, I do not go below a 6” pitch. I have experimented with 4.5 and 5 but the engines seem happiest with 6 or 7. My Surpass .40 now turns an 11 ½-6 ½ and works very well. They just like to be loaded down.
My OS 40 4S turns a Top Flite wooden 10-6 and a Master plastic 11-7 at the same speed but the airplane barely moves with the 10-6.
