Decade or 2 back I decided to try and make my 1993 FXR 80 CI Harley Evo engine (46 HP) perform as powerful as a 93 CI S&S replacement V-twin engine (95HP).
(( I was in Germany where I bought this bike and needed to keep UP at AutoBahn speeds... but she ran out of umph around 96MPH/154Kph while most in that area were running 180~200Kph or 120ish Mph))
So I dramatically changed the final drive rations by the largest available drive gear and smallest available sprocket (belt drive system)...but ran out of umph still 2 around 100Mph
I read and researched and brought to the table skills I learned Drag and Stock car racing at Spanaway, Tenino, Portland and Seattle, Sears Point, Laguna seca race tracks as a motor head/builder/tuner focused on small block Chev and Ford.
I decide on:
My own 1993 Fresh low mile 80 Ci Harley engine had a sound bottom end
New Harley jugs over bored +0.20
New Keith Black Hyper-Utetic pistons +0.20
New lower cc heads from a Canadian source (Head Quarters)
New Cam (Head Quarters) specked for mid band torque
New roller big wheel lifters and roller rockers with adjustable push-rods
New electronic, infinatley adjustable ignition
New very high Kv coils
New Mikuni carb and custom intake header
New Super Trapp (Tuned?) scavenging exhaust header/ muffler system
I contracted Jim's in Axte Tx to mate the pistons and jugs to a 0.025 clearance
I contracted Total Seal for new tech GAPLESS ring sets and sent them the machined and mated pistons and jugs (They had a fixture to pre load the jugs and get fit precise)
I contracted Hyper Tech Coatings and send assys to them for Ceramic top of piston coating as well as their Slippery Dry coating on the piston skirts
Calculated that my original 8.6:1 compression engine would now be in the 10.2:1 to 11:1 range, thus needing the slower burn higher octane fuel
Got 2 legit chassis Dyno runs on the stock engine= 48 HP at 6200 Rpm
Built engine and pre adjusted carbs and ignition to start and run relatively smooth--- bought more dyno time to fine tune carbs and ignition + 91 HP @ 5800Rpm ---torque went double also, but do not remember either value
I drove the FXR motor bike for six months until one day it would NOT start.... factory starter did not have enough to flip it over ... New better High zoot battery.. no soap
new High amp super starter...no soap....assumption; rings finally fully seated and compression way too high
NO room on an FXR for larger stuff (that did exist)
Push starts by friends for a few weeks
Pulled heads and sent to Jim's Harley Axtel Texas for a set of auto compression releases...now starts fine but pretty bad pre ignition when fed right wrist twist too fast...BUT now a 154 Mph top end motor bike ......grin....Texas State patrol not impressed....tho travel time to Tucson (1400 miles) from Killeen on 75 Mph I10 greatly reduced (( only road I was comfortable running 120 mph on) .....still can not out run Motorola...double grin
Add a second head gasket to lower compression a tad... worked to let me run Hi Test pump gas without additive octane booster
Point of all this... relative to the Frank Bowman ring thread... I am curious why some of the racing/ speed guys don't do some of the, NOW OLD school, high tech coatings and such
When I was deep into it, there were a few sources for Nitriding(sp?) parts, super slick coatings, ceramics, extruded flow polish and porting
Perhaps all the high tech stuff is being exploited and it is secret
Perhaps many do not know of the benefits
Perhaps none of this is relevant to modern 2 cycle alcohol fuel engines
