  • July 08, 2025, 02:58:23 PM
Author Topic: FP OS .35  (Read 2801 times)
Offline dagored
FP OS .35
« on: June 30, 2022, 02:52:30 AM »
anyone have a piston and Sleeve for an OS FP .35 or a piston , or who dose motor work for that application ... that would fit a piston to the Sleeve if it's still good ....?
« Last Edit: June 30, 2022, 09:31:01 AM by dagored »
Offline dagored
Re: FP OS .35
« Reply #1 on: July 01, 2022, 06:29:22 PM »
well heck 223 Views Anyone ???? #^ ~>
Offline De Hill
Re: FP OS .35
« Reply #2 on: July 01, 2022, 07:04:20 PM »
There is a company that you can send your piston and liner to. They will squeeze the cylinder and make it give a good fit .
Who are they?
I forgot; maybe someone else knows.
De Hill
Offline dagored
Re: FP OS .35
« Reply #3 on: July 01, 2022, 07:19:31 PM »
 S?P
Re: FP OS .35
« Reply #4 on: July 01, 2022, 08:50:20 PM »
I'd be very surprised if you can find new parts for that engine. You might find some used parts you could fit together if you find a big piston and/or small sleeve but you would need some equipment for that. The place that does the pinching only does up to .28 abc sleeves afaik but you can check, they are RayAracing.
Motorman 8)
Offline dagored
Re: FP OS .35
« Reply #5 on: July 01, 2022, 10:49:42 PM »
Thx Motorman i'll check them out ....   H^^
Offline John Rist
Re: FP OS .35
« Reply #7 on: July 02, 2022, 07:33:51 AM »
I think I would just scrub the idea and find another engine for far less on eBay than what trying to re-work an engine that is not well suited to cl stunt to begin with.  Just my opinion....
Offline mccoy40
Re: FP OS .35
« Reply #8 on: July 02, 2022, 11:54:20 AM »
Doesn't a os40 fp piston and liner fit the os35 fp?
Joseph Meyer
Philadelphia, PA
Offline dagored
Re: FP OS .35
« Reply #9 on: July 02, 2022, 12:41:51 PM »
i am assuming that it is a different size  , but it is possible piston sleeve may fit in the crankcase ....
Online kenneth cook
Re: FP OS .35
« Reply #10 on: July 02, 2022, 03:27:59 PM »
                 The FP .35 was available in iron piston and ABN version. If the engine is a iron sleeve, can it be pinched like the brass version?
Offline dagored
Re: FP OS .35
« Reply #11 on: July 02, 2022, 05:44:50 PM »
Ty Marcucci ,   let me know what i owe you Sir i Appreciate it  ..... H^^ Joe
Offline dagored
Re: FP OS .35
« Reply #12 on: July 02, 2022, 05:54:40 PM »
Yes there is a company that dose this kind of work ,  Ray@rayracing.com check them out
i just don't like to throw engine in the trash especially CONTROL LINE and RC Engine's,.....you know there's always a fix  S?P D>K H^^
Offline dagored
Re: FP OS .35
« Reply #13 on: July 02, 2022, 05:57:37 PM »
Thx to Motorman that's how i got the info ..... H^^
Offline Geoff Goodworth
Re: FP OS .35
« Reply #14 on: July 02, 2022, 09:38:33 PM »
Both the engines in the links provided by John Rist have steel liners.
To those who asked, an FP 40, Tower 40, Magnum GP 40 or LA 40 piston and liner will fit in the crankcase but all three require the head from a Tower, Magnum or FP 40 along with the head gasket.
For info, I have been running a Thunder Tiger/Magnum GP 25 with an LA 25 piston and liner for close to a decade. It is on a Ringmaster so it often only gets one outing each year and it runs just fine.
Re: FP OS .35
« Reply #15 on: July 03, 2022, 10:22:02 PM »
You forgot the Gardner FP 40 P/L ( needs a head ) not to mention the FSR 40 , which has the same hight ports . Ringed or abc .
FP 35 & 40 case & shaft interchangeable .
filched from https://stunthanger.com/smf/engine-set-up-tips/brian-gardner-os-40fp-sets/msg532834/#msg532834
Offline dagored
Re: FP OS .35
« Reply #16 on: July 11, 2022, 11:31:54 AM »
Thank you  Ty Marcucci ,  the OS .35 in today will clean it up see if it's got compression order a needle valve and assembly for it and give it whirl ....Thx Again owe one friend ........ H^^
Tags: piston
