  • July 21, 2025, 12:05:00 AM
Author Topic: Blank  (Read 1462 times)
Offline Rusty
Blank
« on: February 12, 2014, 07:56:53 AM »
Blank
« Last Edit: March 12, 2022, 04:24:29 PM by Air Master »
Offline John Craig
Re: Fox Glow Plugs: Heat Range Chart?
« Reply #1 on: February 12, 2014, 08:50:01 AM »
Not highly advertised, but they do make one specifically for stunt.  It has a black body & is a bit more pricey than the other plugs.  See the Fox Mfg. website.  I normally run the gold R/C plugs & I have not determined if the "Stunt Plug" is really better.  You could always give Fox a call.
http://www.foxmanufacturing.com/index.php?main_page=product_info&cPath=156&products_id=1513
« Reply #2 on: February 12, 2014, 10:26:18 AM »
  I also haven't tried the new one, but the regular RC Idle bar plug is fine with regard to heat in stunt. The problem is the inconsistency from plug to plug. If you find a good one, it will work well.
