  • July 19, 2025, 01:39:22 PM
Author Topic: Tempest with ST60?  (Read 2597 times)
Offline Skip Chernoff
Tempest with ST60?
« on: May 31, 2017, 06:10:05 AM »
I have the opportunity to buy a Randy Smith Tempest kit. The kit is a beauty!....and I can get it very reasonably. The box says it's for a piped 40 to 46. I don't have that set up,but do a some very nice ST 60s. Would the weight of the ST 60 spoil the performance of a plane designed for the 40-46 pipe set up? Thanks,PhillySkip
Re: Tempest with ST60?
« Reply #1 on: May 31, 2017, 08:23:19 AM »
   Randy can answer, but the weight of the ST 60 is probably less than the weight of the 40VF, header, and pipe, so I wouldn't worry about it on that basis.
« Reply #2 on: May 31, 2017, 10:08:59 AM »
Hi Skip
That will work just fine, there are dozens out there  with  ST  60s  flying  now, I suggest  you still  use  the  pipe formers, just do not open the bottom up, they will add a lot to the  stiffness of the fuse structure
« Reply #3 on: May 31, 2017, 03:39:47 PM »
Thanks guys,now let me see if I can close this deal on the kit!
« Reply #4 on: May 31, 2017, 05:42:34 PM »
Here's a picture of mine currently under construction.  Just about ready to begin the covering and finishing process.
Set up for PA65.
Built from one of Randy Smith's kits bought many years ago!  Great kit!
Weighs 46 oz as it sits with engine, tank, spinner, and pipe.  Should come in well under 60 oz when finished.
« Last Edit: May 31, 2017, 08:07:02 PM by Randy Cuberly »
« Reply #5 on: May 31, 2017, 08:12:50 PM »
Thanks for the pic Randy, your plane looks very nice,
« Reply #6 on: June 06, 2017, 02:06:08 AM »
The fellow put the kit on Ebay and is getting very nice money for it.I'll pass on this one.......PhillySkip
Mark Romanowitz
« Reply #7 on: June 06, 2017, 07:31:12 AM »
I saw that kit too. Looks like it was an older kit. It's nearly the same price as a new kit now.
The new kits have Carbon Fiber gear in them. If I had the money I'd just buy one of those. With all the extras that Randy puts in them you would be spending that much or more anyway.
Just my 2c...
« Reply #8 on: June 06, 2017, 12:46:19 PM »
Just my 2c...
Your right  Mark , you will spend much more buy the  kit in pieces  as  my kits are  loaded  with  goodies, and very complete
But I have many people who  buy the plans,  laser cut rib sets, cf gear  parts  etc, and  build  their  own, also  I can do the same with  foam components
« Reply #9 on: June 07, 2017, 07:08:43 PM »
I missed out on that kit ,could have had it for $175 on the day of our club picnic. I just didn't have the money on hand.....PhillySkip
Offline Gary Dowler
« Reply #10 on: June 14, 2017, 03:13:27 AM »
Randy, if I may ask, what is the going rate on a complete kit from you? And what does it include?
« Reply #11 on: June 14, 2017, 09:20:54 AM »
laser cut wood parts  or a foam kit
plans
wheels
carbon fiber gear   kit 299    alum gear kit  275
tissue
cf mat for doubler Smith technique
hinges
bolts nuts for engine
mount bolts/ inserts for gear
lead outs
leadout guide
canopy
pushrod
ball links
H.D. control system
axles
trim tab horn
motor mount
pipe mount
etc.......
