  • July 18, 2025, 09:40:09 AM
Author Topic: FOX Burp  (Read 1694 times)
Offline Phil Coopy
FOX Burp
« on: May 11, 2007, 06:32:26 PM »
Fell into something today.  I have had a bad "burp" on my FOX35 powered Ringmaster. So I tried the trick of putting a wooden insert in the transfer port some time back..but it didn't improve. This week I tried it again....nothing.  Yesterday I tried the trick again but this time instead of aligning the stick in the center of the port I shoved it all the way towards the front edge of the port.......voila...made all the difference in the world...works great!  I'm not claiming that I made any great discovery here but I thought I would just share my experience and maybe someone other than me can explain.  As they say, "I don't know all I understand about this".
Phil
Online Paul Taylor
Re: FOX Burp
« Reply #1 on: May 11, 2007, 07:27:57 PM »
Phil,
Did you do it like this:
http://stunthanger.com/smf/index.php?topic=3878.0
DennisV sent me this pictures some time ago via email. I had a Fox that burped so bad that it almost sounded like it would quit and restart at times. A real butt clincher.
Cured my problem first try.
Paul H^^
Re: FOX Burp
« Reply #2 on: May 11, 2007, 08:15:42 PM »
Phil; You may be onto something here. I have done several with JB weld in the center of the bypass, and they have worked OK for the most part. But on some planes they still go very rich in certain places. They don't burp like they use to, but I would like to try your way just to see. By the way, what plug are you running?
Re: FOX Burp
« Reply #3 on: May 12, 2007, 05:29:22 AM »
Hi Phil,
All of the "VooDoo" surrounding our hobby is not always confined to a certain Goldberg kit combat plane! LOL!!
If it works, it works........ and it is good!
Bill <><
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: FOX Burp
« Reply #4 on: May 12, 2007, 06:20:35 AM »
Hi Phil,
Bill <><
Boy isn't that the truth  HB~>
Offline Phil Coopy
Re: FOX Burp
« Reply #5 on: May 12, 2007, 06:32:11 AM »
Paul,  I used a plug the same size as it shows in your link but in the 6.jpg pic it is shown in the center of the port and my improvement came when I moved it all the way forward against theforward side of the port (had to bevel it a bit to get a good fit).
Jim, after trying lotsa plug heat ranges I just went back to a Fox Std long.
Phil
« Last Edit: May 12, 2007, 07:21:23 AM by PHIL COOPY »
Online Paul Taylor
Re: FOX Burp
« Reply #6 on: May 12, 2007, 06:37:51 AM »
Hey Phil,
In the one picture it shows the plug in the center of the bypass. Then the next to pics looks like the plug was moved to the front side of the bypass. I can not remember if I moved mine forward. But like I said it ran better after the plug was installed.
Re: FOX Burp
« Reply #7 on: May 12, 2007, 04:46:52 PM »
You must be on to something Phil! If you can run without a burp on a Fox standard long plug on a profile, You have done good. I don't think mine even with the center plugged off will run without a burp with that plug.
Re: FOX Burp
« Reply #8 on: May 12, 2007, 06:00:19 PM »
Well, the "Fox Burp" can be a puzzling thing.  Over the years, I have seen stock Fox 35s that would burp and others that didn't.  I have even seen a stock Fox 35 burp on a Dolphin (inverted engine)!  To the point that I thought the engine would die at any time, but the pilot pulled off about a 500 point flight at Brodak anyway.............  doesn't seem to be much rhyme or reason.............
