  • July 16, 2025, 03:59:43 AM
Author Topic: Fox .40 BB Rat Race  (Read 2146 times)
Fox .40 BB Rat Race
« on: November 26, 2015, 01:48:14 PM »
   Hello Again Group!
     Again, I'm just posting this in the main forum for general information and to learn the history of the engine.
    Along with the Elfin, I was given a new Fox .40 BB Rat Race engine that still has the sticker on the side of the main case. It is set up with what I think I recognize as Bill Johnson modifications for throttle for carrier use. The exhaust is cut and slide blade installed, and flapper on the intake with accompanying linkage to a home made pivot for the throttle push rod to attach to. The pivot is made from tubing and has a TEE at one end that looks like fuel line is supposed to attach to it. I got to meet and talk to Bill Johnson on a few occasions when he came into Mark Twain Hobby where I have worked part time for the last 35 years or so and he showed me several examples of his work. I found out that in the sixties, he used to live quite near the house I grew up in! Well within walking distance for me. If O had known that at the time, I may have become more of a carrier flier as time went by!
    Again, not looking for set ups or anything, just genral information on what I have here. I have several plans and kits for vintage carrier models, and can picture this engine in a profile model or even full fuse model. What class would the .40  fall under, clas 1 or class 2?
  Thanks again and HAPPY THANKSGIVING!
Re: Fox .40 BB Rat Race
« Reply #1 on: November 26, 2015, 04:52:06 PM »
Don't know for sure, but he should still be alive and in the St Louis area.  I have two McCoy Redhead .60's he set up for carrier class II.  One quite a few local contest with them.
« Reply #2 on: November 26, 2015, 04:58:17 PM »
.40s for class I ,  .60s for class II,  profile I believe is limited to .36.  I think you could fly the .40 in class II but it wouldn't be competitive with the .60s for top end.
Offline Mike Anderson
« Reply #3 on: November 26, 2015, 05:38:20 PM »
My guess is that this is set up to run crankcase pressure - the pivoting arm with the fuel inlet is most likely a fuel meter to keep from flooding out at low throttle when using a pressurized tank.  It would be legal for Class 1 only, if less than .4029 cu. in.  It would be legal for Class 2 only, if .4029 or greater.  Profiles are limited to .3661 or less and no crankcase pressure.  You could put it on a Profile plane, but could only fly Class 1, and would get no scale points.  It could also be entered in Nostalgia Class 1.
Mike@   AMA 10086
Central Iowa
Offline Bob Heywood
« Reply #4 on: November 26, 2015, 06:02:30 PM »
This engine with the Bill Johnson set-up is ideal for Class I Nostalgia. Not so much for modern Class I.
The attached documents are Bill's write-ups for the theory and set-up of his system.
"Clockwise Forever..."
« Reply #5 on: November 26, 2015, 08:32:47 PM »
The current class II record is held by Burt Brokaw with a Nelson 45.  It's true that you can use up to a 65 in class II but the top guys seem to use Nelson 45's with the tuned muffler. They are awesome!  Class I is pretty much dominated by Nelson 40's with the tuned muffler.  The Profile record is also held by Burt Brokaw with a large case Nelson .36 with tuned muffler.
