  • July 26, 2025, 10:10:20 AM
Author Topic: Fox 36X ABC piston/liner/rod/pin sets  (Read 45490 times)
Offline Fredvon4
  • Central Texas
Re: Fox 36X ABC piston/liner/rod/pin sets
« Reply #100 on: January 01, 2016, 12:55:03 PM »
Bump up so we can ask Brian PUBLICLY  on the status of this project
I am trying hard to remember all the 2015 needs and wants I had asked about here and on other forums
Fred von Gortler IV
Offline Brian Gardner
« Reply #101 on: January 04, 2016, 06:42:38 PM »
Hi Fred, The next run of these has just started. So they will be a few months off. I have you on the list as requested.
Brian
Offline Fredvon4
  • Central Texas
« Reply #102 on: January 05, 2016, 08:09:06 AM »
Thanks Brian
Hoping this progress on the Fox .36X stirs a few more commitments for the Fox .36 MK IV/VI project I started
Fred von Gortler IV
John Leidle
« Reply #103 on: January 05, 2016, 05:15:10 PM »
    Did the Tiger .51 sets ever get finished ?   b1
« Reply #104 on: January 05, 2016, 10:38:03 PM »
Had a few delays John, they should be finished soon.
Offline Fredvon4
  • Central Texas
« Reply #105 on: February 11, 2016, 08:41:19 AM »
Bumping this up as the ST51 project is concluding and this second run of Fox 36X should be starting
I have received more pre orders for the Fox MKIV MK VI series and will add that in the other thread
Fred von Gortler IV
Offline Fredvon4
  • Central Texas
« Reply #106 on: April 29, 2016, 08:23:03 AM »
What is status of the second run for these?
The LA 25 thread made me remember I had asked for tow of these Fox 36X sets
Fred von Gortler IV
« Reply #107 on: April 29, 2016, 05:28:44 PM »
I'm anticipating having these ready to go out at the end of May.
Offline Fredvon4
  • Central Texas
« Reply #108 on: April 30, 2016, 06:40:58 AM »
Thanks for the update sir
Fred von Gortler IV
Offline bob whitney
« Reply #109 on: April 30, 2016, 11:46:21 AM »
  put me down for 2 sets Bob
rad racer
« Reply #110 on: April 30, 2016, 03:56:53 PM »
Hi Bob,
At this point all 30 sets in this run are spoken for. I'll add you to the list though. If someone pulls out you'll get lucky mate.
Brain
Offline Fredvon4
  • Central Texas
« Reply #111 on: June 26, 2016, 11:36:52 AM »
The .25 and .46 threads made me remember this project
Anticipated second run around end of May
Just seeking an up date
Fred von Gortler IV
« Reply #112 on: June 26, 2016, 06:17:01 PM »
Still doing finishing touches. A bit behind schedule. Not far off now.
« Reply #113 on: July 02, 2016, 06:48:22 PM »
I'm in the process of notifying people on the waiting list that I will be shipping these out in the coming weeks.
« Reply #114 on: July 19, 2016, 02:03:56 AM »
These are ready to ship and I've started packaging. All that have paid will be getting shipped by the end of the week. There are some yet to pay but I expect nats prep has them busy.
Offline Frank Imbriaco
« Reply #115 on: August 26, 2016, 08:39:54 AM »
Brian :
My 36xBB runs very well with your P/L/R setup.  Fabulous machine work.
So far,  a few, short duration bench runs using 10% nitro/ 25% castor followed by several flights mounted on my Scrambler  using 10% nitro  and a 22% equal castor/syn blend. Needle not fully peaked just yet, although I'm confident that it could've been.
I'm getting close to feeding it more nitro- maybe  next time out.
All in all, a really neat setup.
Frank
« Reply #116 on: August 27, 2016, 02:34:48 PM »
25% nitro last eve. We're starting to pick up the pace. 35% next time. Still well behind my neighbors who are feeding theirs 50%.
Yowsa ! ~^
Offline Onelife
« Reply #117 on: April 29, 2024, 05:25:44 PM »
Hi Brian,
          Put me down for 5 sets of the Fox 36x BB. This engine has the baffle on top of the piston. The 36x BB has a small relief on the piston to clear the rear bearing in the case. Care has to taking in not making to relief to wide to pervent sub piston induction. I think the baffle should be made stronger something like the K&B 40 because the old piston is made of steel and some of us like to run 40% nitro to hear it crackle. This piston and liner set would work in the needle bearing engines with no mods. You could make a FOX SUPER DUPER STUNT by putting it into a fox 35 stunt by changing the rod & head. The new liner would also fit the 36 shiney case but I think the 36x has a thicker rim at the top of the liner and would give you more head clearance so you would have to do some checking. Motorman is right, the needle bearing crank is slightly larger in diameter than the BB but the crank pin is the same.
Al
I have a NIB fox SUPERSTUNT and I have know ideal what’s in it  except it has a ABC  piston and liner and Hemihead with stuffer backplate is that all there is or is something else different? Is that what Fox in the day called there SS
Offline Al Ferraro
« Reply #118 on: April 30, 2024, 08:20:49 AM »
The factory Fox 35 Super Stunt that I know of was a steel piston & liner which was a higher timed with larger intake and exhaust ports. I never ran a Super Sunt, but our local Fox 35 Stunt expert prefers the original timing. Fox did make a stock timed ABC set that's a good runner. I currently use it to power my Flight Streak and can complete the pattern with only 3oz of fuel with No Burp (can only fit a small tank on the Streak) using a venturi restrictor.
 Post a photo of the engine and the box it came in would help ID the engine.
Al
Offline Onelife
« Reply #119 on: April 30, 2024, 08:39:33 AM »
I am not sure how to post pictures please give instructions thanks
Offline Onelife
« Reply #120 on: April 30, 2024, 09:57:00 AM »
Bummer can’t do it and I would really like to find out what I have
How about pm with email?
On the box it’s hard to see the numbers on the gold sticker but I think it
S5017 Fox Super Stunt white lable black box  has a brass liner stuffer back plt and Hemihead
Hey Al I sent a private message to you.
« Last Edit: April 30, 2024, 10:24:04 AM by Onelife »
